308 V12 conversion begins | Page 131 | FerrariChat
Discussion in '308/328' started by mk e, Oct 9, 2007.
Thread Status:
Not open for further replies.
  1. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,753
    The twilight zone
    Don't be like that. Painting the house in an unattractive and unplanned way along with other stupid things are what happens when I do sh*t without giving it even a second of though before doing it. I don't mind acknowledging these types lapses in my judgment but I just don’t enjoy discussing them beyond that so I would prefer to return to engine building.
  2. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,753
    The twilight zone
    No splay, parallel so a few less set-ups to deal with.
  3. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,753
    The twilight zone
    #3253 mk e, Jan 6, 2010
    I found I didn't have a long enough boring bar to bore the guide hole...so I bored with an end mill. I left the holes .010" under the planned finish size incase threy move or pull during welding. I have to make the guides so I they don't have to be a round number... it's nice if they are but if things move more than the .010" I can make them whatever size the hole clean up at.
    I started boring for the new seats but I have a couple more cuts to make. Again I will leave them undersize but probably .020 or so since I have the seats I want to be certain the hole will clean up to size after welding.
    The new seats are 35mm, the valve 34mm so pretty close. I just don't want to go any bigger than I absolutely need to on the seats since I'm already changing the valve to valve spacing and going oversize it means cutting out a lot of metal on one side. It shoulf be fine though, the seat ID will be 29mm giving me a 3mm wall. I'm not sure how deep I want to set them exactly so I'm stopping at stock depth for the moment. I'll make a couple temp seats that I can play with for the flow work and get the vavle set where it works, then cut the final depth and dia to put the real seats in....that's the plan anyway.
  4. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,865
    Atlanta
    John!
  5. jimshadow
    jimshadow F1 Veteran
    Feb 19, 2006
    6,252
    Indiana/North Carolina
    JIM
    I'm so glad this thread is back to normal..... ;)
    JIM
  6. Pizzaman Chris
    Pizzaman Chris F1 Rookie
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    This is to tense for me.........................i'm going to bed.
  7. tknobby
    tknobby Rookie
    Mar 12, 2009
    49
    Good Morning Mark,
    Glad to see your progress. Looking very nice.
    I had quite a hard time finding a reamer the proper size for my custom guide holes so I thought I'd send you this link. Didn't know if you were having the same. Reamers over .520" don't seem to be readily available but this place has them. I ordered one .525" and will finish ream my heads this weekend.
    www.eastonsupply.com
    Tom...
  8. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,753
    The twilight zone
    I think the reamer I need is the same one I use for injector ports so I have it but msc has them in .001” steps up to .700 along with common sizes (mm, number, fraction, ect) up over an inch. Mcmaster and enco also have a good selection including all the common sizes to over an inch.
  9. brian.g
    brian.g Rookie
    Apr 4, 2009
    24
    West of Ireland
    Brian Garvey
    Nice work Mark, The mill is a super tool, I know you know this, but I just have to say that they really really are!
  10. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,753
    The twilight zone
    #3260 mk e, Jan 7, 2010
    I finished up the seat pockets on the first head. You can kind of see how much I sunk the intake valve when I was doing the development work, it's about 1.5mm.....so tonight I was second guessing myself and thinking I'd like to leave it a bit higher. The exhaust valves will sit lower to once the seats are cut to the right size....and maybe sunk a bit. The seat profile I'm using likes the valves to sit a bit lower than they would want to with a standard 3-angle seat.
  11. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    #3261 Verell, Jan 8, 2010
    Interesting idea, a milling cutter in a boring head. How accurate did the final holes turn out? From the pix I don't see any signs of tool chatter, was there any?
    Was looking at your milling setup, trying to figure out how I'd do it on my CNC mill. My mill head doesn't articulate, so decided I'd have to tilt the workpiece. Would probably make a big angle plate, either fixed or adjustable to mount the head to the mill bed.
    Hmm, I believe the cam caps and cam cover mounting surface are perpendicular to the valve stems, so maybe I could just make a flat plate that mounts against them & then mounts flat on the mill table.
    In fact this seems like the natural way to setup to machine valve seats, bore valve guide holes, etc, I'm wondering how you're mounting the head to your mill table. It looks like your cam cap surfaces are not at 90 degrees to the valve stems!
  12. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,753
    The twilight zone
    The Cam caps are not at 90 to the valves on the TR, QV, 2v, 360, or 400 heads and I assume the same is true about other models. The cap mount surface is parallel to the deck surface on evevy head I've ever seen or you need an agle plate of some kind.
    I've seen people do it a couple diferent ways. The strongest is a dedicated fixture with the angle milled right in. You just bolt it on the head, throw the head on the mill (normally aligning pins in the fixtur to hit the Tee slots) and start cutting. Usually the same fixture can have both the intake and exhaust angles cut on it.
    The way to save metal is to make 2 slotted fixtures to set the anlge and some kind of adapters to bolt them to the head so you grab cyl 1 with the first and cyl4 with the other, square it up on the table (again it could have alignment pins) then you you need to indicate the ange in and lock it, tghen you's ready to cut. The cuts we're talking about are very light so as long as you use at least 1/2" alum couple 1/2" bolts to lock each end it will work fine, it just takes more time to set up.
    As for the endmill in the boring head it's not prefered but it does work and will make a decent finish. You have to make sure that down at the end the the flute pointing the right way or yo can get some taper at the bottom of the hole...not a bit deal if its a through hole like I was working with. For the finish hole I'll bore with a boring bar from the other side so I can reach then probalby finish up with a reamer and maybe a light hone.
  13. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,753
    The twilight zone
    #3263 mk e, Jan 11, 2010
    I plotted the cam lobes with the planned timing to get the top dead center lift number I will need for valve pockets in the pistons and also to get the lift point the valve cross at so I can check the valve to valve clearance. I need to know the valve to valve now so I know the valve seat height I pick actually works and doesn’t crash the valve into each other…..it’s probably fine even with the big valves but I really need to measure it because it looks like thess cams have all 4 valves opened almost exactly .100" at the same time and the intake at opened about .130" when the piston is at TCT.
  14. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,753
    The twilight zone
    I didn't get a lot of time in the shop tonight so there is nothing pic worthy. Tomorow I'll have more time and should have the temp intake seats finished and be on to making templates and maybe grinding.
  15. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,753
    The twilight zone
    When I started talking about the temp seats who's job was it to point out that a V12 has 2 heads and I'd only cut the seats/guides in one of them? Luckily I realized before I tore down the set up so the temp seats are on hold and head 2 is under way but little one got bored so we had to come up stairs. It looks just like head 1 so I didn't bother with pics.
    I also realized that today is 5 weeks on the cams so in theory they are done now :)
  16. Pizzaman Chris
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    And if it was Joe the Plumber,that 5 weeks = 5 months X 3 +..........ah who cares.
    At least you got them out of his hands and the ball is rolling now. :)
  17. vincent355
    vincent355 F1 Veteran
    6,518
    Wine Country
    Vincent
    I almost forgot this engine has cams. :)
  18. NeuroBeaker
    NeuroBeaker Advising Moderator
    Moderator
    Oct 1, 2008
    40,043
    Huntsville, AL., USA
    Andrew
    Is this particular cam order exceptionally difficult to fulfil? It seems like forever and a day that these cams have been on order and not yet arrived. :eek:
    All the best,
    Andrew.
  19. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,753
    The twilight zone
    I think deceptively difficult is a better description than exceptionally difficult but I think the hard part in now in the past.
    The first guy had great pricing and had masters for full race TR cams so he didn’t see any problem as I was talking about a street engine so he was thinking worst case he gives me the race grind..…… but I mentioned in a post some time back that the specs I am looking for require much more aggressive ramps on the cams than were used in full race TRs back in the day. This caused a lot of head scratching, test grinding and…… failing because he just didn’t have anything in his master collection that would meet my specs on a cam over bucket engine and work with the Ferrari 24mm base circle. He could give me the lift if I took 20-30 degrees more or the duration if I gave up .050”-.070” on the lift, so he gave up.
    At Web cam I knew they had a couple masters that were at least close so I move the cams to Web. They gave me 5-6 options, but only a couple good ones and all required test grinds because they had never tried them on the small Ferrari base circle. My first choices on both intake and exhaust couldn’t be used because they produced a “razor sharp” nose on the lobe (this is the problem the first cam grinder kept running into), but luckily my second choices looked good.
    The whole delay was picking the lobes. Now that I’m past that hurdle things are rolling but still a bit slow because billet steel cams require more steps than other cams and Web subs out a few or the step so there are lead times at multiple places to deal with along with the holidays. They should be getting close now.
  20. Ferraripilot
    May 10, 2006
    17,865
    Atlanta
    John!
    That is a ton of steps indeed. I had no idea. No wonder it is impossible finding any other place besides megacycle and webcams to hard weld.
  21. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,493
    Canada
    Newman
    #3271 Newman, Jan 13, 2010
    I think you should go all out (why stop now?) and go for pneumatic valves. Whadda ya think?
  22. Basura
    Basura Formula Junior
    May 1, 2008
    266
    Santa Monica, Ca
    Michael Basura
    Just found this page.
    Is there a way to save it so I can view it later without trying to find it again?
  23. Kravchak
    Kravchak Formula Junior
    Oct 17, 2005
    850
    Northeast
    Ken
    Top right "thread tools" Subscribe to thread... you'll never lose it...
  24. Basura
    May 1, 2008
    266
    Santa Monica, Ca
    Michael Basura
    Thank you kindly
  25. KKRace
    KKRace Formula 3
    Aug 6, 2007
    1,052
    Rockville/Olney MD
    Kevin
    Just a bump on the Cabin Fever Expo this weekend!
    HybridIIA likes this.
