308 V12 conversion begins | Page 138 | FerrariChat
Discussion in '308/328' started by mk e, Oct 9, 2007.
Thread Status:
Not open for further replies.
  1. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,747
    The twilight zone
    With the heads moving along nicely it seems like time to think about ordering pistons. I’ll need to get a CC number from the combustion chamber then I think I’m ready…after I make the big JE v Wiseco decision that is.
  2. Conquest351
    Conquest351 Karting
    Mar 13, 2008
    110
    Central Texas
    Brian Hamilton
    JE and Wiseco are both fantastic pistons. In my experience, Wiseco's seemed to be just about all we ever put in the engines we built. I don't know if my boss was just a Wiseco nut or what, but they seemed to hold up fantastic under high boost and decent compression. We built most of our turbo motors at about 9.5:1 and ran 20+ lbs of boost on top of that on street cars and never had an issue with the Wiseco's. I think they were a little heavier than the JE's but they had much more meat in them and that's why we used them. The spiral locks can be daunting to some people but I'll give you a trick to install them quick and easy...
    Take a regular writing pen with a square shaped cap/top. It needs to be flat and square shape to work properly. All our promotional pens were like this and they worked so much better than the pens with round caps/tops. Don't know why, they just did. LOL Once you have that, put the wrist pin through the piston and rod and put the spiral lock in and start it in the groove. Put the pen on top of the spiral lock and just follow it around the perimeter of the wrist pin hole and you're golden. Flip the piston/rod over and do the same on the other side. Check to make sure it's all down in the groove and that's it. Works like a charm every time.
    Laters,
    Brian
  3. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,747
    The twilight zone
    The JE order form seems a lot easier to understand......but the wiseco form has "F1" as one of the application choices to circle......
  4. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    Are you gonna go with 4032 or 2618 aluminum? Knowing your crazy but, you may end up booting it anyway, so I'm gonna guess 2618? :D :p
  5. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,747
    The twilight zone
    2618. Did you really need to ask?
  6. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    No.
    I just wanted to bust your balls. :D
    Oh yeah and that was supposed to read "boosted". ;) I'll bet you can fit a Procharger in there somewhere. Oh my...........I didn't suggest something to prolong this even more did I? Hahahahaaa!!!
  7. KKRace
    KKRace Formula 3
    Aug 6, 2007
    1,052
    Rockville/Olney MD
    Kevin
    The new "inverter" tig machines claim to get much more heat per/amp using a higher frequency claiming they need much less of a cleaning cycle of the squarewave. I think they weld around 300hz or more vs 60 cycles for a standard transformer machine. A much smoother arc as well. I feel sorry for the guys in the EU welding at 50hz.
  8. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,747
    The twilight zone
    No boost.....maybe a little nitrous if I can't get it to make 150mph in the 1/4, but no boost.
    I can't find any of my stuff for CCing the heads......it'll keep unitl tomorrow I guess. The rest of the order sheet is done. I may have to pull a combustion chamber casting too I guess and that will mean either making thre cylinders or at least a temp cylider.....I need to stuff in the right exhaustt valve quickly too.....distractions.
  9. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,747
    The twilight zone
    This morning I set up the mill to cut the exhaust seats and got the head on. Tonight or tomorrow morning I'll actually cut the seats on one cylinder so I can CC the chamber.
    I'm going to be changing valves a little bit. Originally I planned to use 5.5mm stems but I couldn't find any off the shelf retainers to go with them that were set up for shim under bucket. The suzuki stuff I ordered uses 5mm stems and the blank valves with 5mm stems have a different head angle and are available in slightly different sizes. My intake will still be 34mm but instead of having to decide between a 28mm or 29mm exhaust which I was really strugling with I now have the choice of 28.5mm or 28.5mm so I'm thinking I'll go with the 28.5 :)
    I aksed for a price quote on the vavles, buckets, stem seals, seats ect. We'll see how painful it will be.
  10. unojung
    unojung Karting
    May 18, 2006
    112
    Copenhagen, Denmark
    Uno Junghans
    Mark,
    What brand are the small torches you are using, and where do you purchase them?
    Uno
  11. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,747
    The twilight zone
    The brand is weldcraft and I ordered from www.arc-zone.com
    I honestly didn't do any more research than to look at the sticker on the torch Wil send and go to their web site, but the stuff looks good.
  12. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,747
    The twilight zone
    #3437 mk e, Mar 5, 2010
    It seems little one found my seat cutter.......now I'm not able to find it. I was able to grindthe exhaust seats to set the valve for the ccing, but I've got so hunting to do it appears to find that seat cutter.
  13. Conquest351
    Conquest351 Karting
    Mar 13, 2008
    110
    Central Texas
    Brian Hamilton
    Don't you just love it when kids get into your important stuff? LOL
    Oh, BTW, did you figure out what Lana's having this go-round? Our Dr. appt is next week and we may be able to find out. If not, it'll be next month. I was about a month off. LOL
  14. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,747
    The twilight zone
    Yeah, he was eying it a couple weeks ago and I took it…apparently he was more persistent and faster than I realized. I needed to clean up again anyway I guess…..
    Think we find out the boy/girl thing about the 15th
  15. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,747
    The twilight zone
    Yesterday I settled on JE for the pistons (for no other reason than I’ve used then in the past and was happy) so that is rolling now.
    I may have to cast the combustion chamber for them as it’s not exactly standard TR any more…..they said they’ll let me know. If I have to make a casting I’ll also need to either make a cylinder liner or a temp liner more likely because the casting needs to include at least ½” of bore so they can get a good chamber v bore position. We’ll see
  16. Conquest351
    Conquest351 Karting
    Mar 13, 2008
    110
    Central Texas
    Brian Hamilton
    Damn, sounds like fun/more work. LOL Well I guess after all this welding and fabrication, a little plaster work shouldn't be too challenging.
  17. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,747
    The twilight zone
    Everything about this project is "more work". They like the castings to be body filler or similar so it doesn't chip or crack in handling. I may not need to make it...but I'm guessing I will once they fully understand the project.
  18. Conquest351
    Conquest351 Karting
    Mar 13, 2008
    110
    Central Texas
    Brian Hamilton
    Just ask for an email address and send them the link to this thread. Tell them to take a day or 2 to completely scan through so they get the full appreciation of this project. Once they finish that, you may get the pistons cheaper if you put their sticker on your car. LOL Sponsorships are great!!
  19. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,747
    The twilight zone
    #3444 mk e, Mar 6, 2010
    This morning I took a look at the port bottoms. I was thinging fill plates, but I'm not filling enough so it'll have to be weld. I decided to do most of it with the big torch but I ground the gas cup a little so I could reach in better....the Lava cup grind fast and easy, the Alumina cup don't grind at all. I got a couple done before little one was bored with the shop and we had to go upstairs. I'll do a rough grind and fill any low spots once the new smaller torches get here.
    I got a quote on the valves and buckets.....the buckets are about double what I expected :(
  20. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,747
    The twilight zone
    10 filled, 2 to go then I think it's time for the flow bench.
  21. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,747
    The twilight zone
    All 12 are welded and I started grinding. It looks like I most likely will need to get down in witht he small torch and add a little bit more....we'll see.
  22. Pizzaman Chris
    Pizzaman Chris F1 Rookie
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    Oh man, WTF!
  23. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,747
    The twilight zone
    I know......
  24. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,747
    The twilight zone
    #3449 mk e, Mar 7, 2010
    I had at head 1 with the die grind for a couple hours and the ports are starting to at least look like ports again. I'm trying to be carful aboutr matching the port shapes to the test port so the grinding is kind so slow, a couple more hours maybe before this head is ready for the flow bench....but it is lookin like a head again I think and not so much like scrap metal like it did :)
  25. duck.co.za
    duck.co.za Formula 3
    Jan 9, 2007
    1,006
    Cape Town South Afri
    Dave
    Coming along nicely , ports look good .
