308 V12 conversion begins | Page 142 | FerrariChat
Discussion in '308/328' started by mk e, Oct 9, 2007.
Thread Status:
Not open for further replies.
  1. duck.co.za
    duck.co.za Formula 3
    Jan 9, 2007
    1,006
    Cape Town South Afri
    Dave
    #3526 duck.co.za, Mar 17, 2010
    Here's what holds the TPS in ! Not sure how to remove them with out destroying them . Maybe I can remove the butterfly and use the spindle shaft to tap them out ?
  2. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,747
    The twilight zone
    Ummm…clearly not meant to come apart. It looks like the only way they come out is broken. I’m thinking I’ll leave 2 in place for now and go from there.
  3. duck.co.za
    Jan 9, 2007
    1,006
    Dave
    I see it's a Panasonic component ??
  4. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,747
    The twilight zone
    OK, the new swicht I ordered for the grinder came today and fixed the grinder.....so I can grind ports again in the morning.
  5. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,747
    The twilight zone
    Oh I had so much fun grinding this morning.....I'm getting close on head 2 but it's going to need a little more touch up welding mid esction on the bottom of the port than head 1, but they both need it....this is where I couldn't get to with the big touch.
  6. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,747
    The twilight zone
    I just about finish the rough grinding on head 2 this morning and the new welding torch parts showed up today. Good timing and I'm thinking I'l be ready for the flow bench early next week it the new valves show up.
  7. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,747
    The twilight zone
    #3532 mk e, Mar 18, 2010
  8. Pizzaman Chris
    Pizzaman Chris F1 Rookie
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    Oooh, very nice.
  9. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,747
    The twilight zone
    I spend my morning hour fixing Wil’s mini-torch with the parts I got yesterday so nothing cool got done and Lana says I need to do the taxes this weekend :(
    The WP-24 torch is just a little too big to work don near the seats in a 4V port it look like, I bet it would be just fine in a 2V port though.
  10. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,747
    The twilight zone
    I measured the chamber in a hurry so I’ll re-check this weekend to be certain…..I was thinking about dome height but I just got this from JE
    “Since this requires a dish I would suggest doing a zero deck so the dish depth is minimized.”
    We were talking about deck height.....and dished pistons popped out. I hadn’t even looked at the numbers, but a 23cc chamber and 8cc for the head gasket on a 453cc cylinder means 15.6:1 with a flat top piston. I only want 10.5:1 so I need a dish… I expected a dome. Re-measure.
  11. Pizzaman Chris
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    Oh no no, you're not getting my heads. :)
  12. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,747
    The twilight zone
    No hp for you! Get out!
    :D
  13. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,859
    Atlanta
    John!
    Come on you big baby. Give in the to the fchat peer pressure and send em down.
  14. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,747
    The twilight zone
    I re-checked the chamber....I measured right. I think I'm going to have them add 3ccs to the number though to give me more margin in matching all 12 chambers.
    I'm going to ask for the deck height to be +.010" , or .010 above the deck. this will get the piston to within .045" of the head which makes a nice squish zone. Also I’ll ask that the dish be only under the actual chamber and not the flat head areas to keep the chamber to keep the chamber as compact as possible while extending that squish zone which together in theory should help make turbulence in the combustion chamber meaning it will need less ignition timing and make more hp……maybe.
  15. Ferraripilot
    May 10, 2006
    17,859
    Atlanta
    John!
    that theory seems to be the norm nowadays for an acceptable quench ratio in a non-racing engine. I believe racers are going for .020 nowadays.
  16. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,747
    The twilight zone
    15 years ago I was runnig .030", but that was with steel rods. the piston guy said they don't like to go under .040".
  17. jratcliff
    jratcliff Formula 3
    Sep 7, 2004
    1,024
    Texas
    We use a freon sniffer for A/C work and a can of freon, block off all passages and then expose the bore to freon and then shop air. We use the freon sniffer to test the outside or welded joint for leaks, no buzzing, no leaks.
  18. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,747
    The twilight zone
    I finished up the rough grinding on head 2 tonight. Hopefully tomorrow I can get the touch-up welding done.
  19. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,747
    The twilight zone
    I got 2 ports touched up this morning. I tried the wp-24 but it's just too big for the 4V ports. Hopefully I'll get the rest later.
    Completely unrelated to ports, the desing fo my MAP sensor is done so I'll be ordering the board Monday. This set-up will use 1 MAP sensor per cylinder then selected the strongest signal (which will be the cylinder in intake) and pass it to the ECU. I was worried about exactly how to get the ECU to worl well at very low power with my monster TBs and I'm pretty sure this multi-MAP set-up will do the trick.
  20. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,747
    The twilight zone
    Touch-up welding complete. After they cool a bit I'll do a quick clean-up then I guess I'm holding for the valves......or maybe I'll get going with the valves I have and hope because I want the heads done and I hate the thought of setting them aside.
  21. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,747
    The twilight zone
    Head #1 is ground. I just realized when I was welding I bugger the bottom of some of the guide holes so the heads will need to go back to the mill to re-bore them quickly once the grinding is done then they are ready for the flow bench.
  22. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,481
    Canada
    Newman
    Now I know why I need sun-screen up here!
  23. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,747
    The twilight zone
    More grinding this morning....almost finished on head 2, just 1 port left.
    I need to make new temp guides to go with the new 5mm stem valves vs the 5.5mm I had. Then I need to make the actual guides, I guess I'll get the material so I can move on to guides until the valves arrive.
  24. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,747
    The twilight zone
    I ordered the guide material. I decide to go with C630 bronze (ampco 45) for the guides. It appears to be pretty commonly used for valve guides. It’s about 80% copper for heat conduction and 5% Nickel and 3% iron for wear, and 10% Aluminum so they are good and light….no, I think the Al helps the hardness bit.
    Making guides will take some time so I’ll get going on these while I hold in valves. I need to make the intake manifolds too, but I want to get the ports pretty close to right before putting manifolds on because it’s much easier to work in the short ports as they are now than it would be in the long port/manifold combo (the manifolds are going to be welded on because I lost the mounting flange in the port move)
  25. duck.co.za
    Jan 9, 2007
    1,006
    Dave
    #3550 duck.co.za, Mar 22, 2010
