308 V12 conversion begins | Page 15 | FerrariChat
Discussion in '308/328' started by mk e, Oct 9, 2007.
Thread Status:
Not open for further replies.
  1. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,753
    The twilight zone
    I don't have any money. The budget for this project is what ever I get selling off the old engine and various parts I have laying around. I paid $4000 for the running but tired 400i engine and another $4k for the TR heads. There are several salvage yards that deal in ferrari parts.
  2. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,753
    The twilight zone
    I got a few hours in on the welding this evening. All 18 of the stud holes that need to move are now filled is! Those stud holes were a bugger. I also now have 5 of the cylinder bores welded up so they can be machined to accept the 348 liners....a couple more hours and the welding will be done.
    I'm going to try to slide the rest of the welding in sometime this week so i can get on to some rough machining next weekend. I don't want to take any finish cuts on the decks in particular until I now I'm done welding.
  3. RVIDRCI
    RVIDRCI Formula 3
    Dec 1, 2005
    1,576
    Long Beach / Phoenix
    Luigi
    Very cool, rock on, and keep us posted ! (as i know U will) Pics too ?
  4. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,753
    The twilight zone
    I'll post some tonight. Yesterday Lana was ebaying and I was ready for a drink - welding is hot work!
    I wasn't sure the tig torch was going to hang in there, it's a little charred. It’s a bugger getting the weld to want to flow into the bottom of the stud holes, it takes about 5 minutes with 350 amps (the torch rated limit) to get it hot enough in there. I have to hold the torch outside the cylinder hole by the cable/hose to keep from frying my hand, the ceramic gas cup starts to melt and sag from the heat, you can smell the torch housing starting to burn, the torch cooling water starts getting hot enough to burn me, then the weld starts to flow, I weld my way out of the corner and the rest goes fine.
  5. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,753
    The twilight zone
    #355 mk e, Dec 3, 2007
  6. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    I seen these last pics and was almost speachless. Youll have some big stories for the grandkids someday, lol.
  7. RVIDRCI
    RVIDRCI Formula 3
    Dec 1, 2005
    1,576
    Luigi
    You are a party viking with a tig, man (does your welding helmet have those horns & big metallic studs?)
    Can't wait to see how the milling process shakes out. I'm assuming your over building material so you won't be adding to fill voids during the milling.
    Whats your current game plan for annealing/work hardening/peening etc. given the previous posts/concerns RE: weld build up material and weld heating vs virgin block material ? (not that I have any experience or opinion there, I just find it interesting,... riveting actually)
    Thanks for posting progress pics.
    Best,
    -Luigi
  8. kens
    kens Formula 3
    1,341
    Kudos. I have been monitoring your project for a few weeks. Suddenly the Ferrari advertising slogan from the late 70's came to my mind.
    What can be conceived can be created.
  9. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,753
    The twilight zone
    Thanks. My 7 month old son now looks at the basement door when you say Papa's coming :)
  10. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,753
    The twilight zone
    I'm trying to over build, but it's not always easy to tell. I'll cut the decks a couple thousands proud so I can see what I’ve got. I also don’t have the 348 liners yet so I don’t know what to do there - I’m just guessing at this point, but I will probably clean things up a little so I can get good measurements and it will give me some new reference surfaces so I know where I am if I need to weld more.
    I don’t know about the stress relief or peening, I need to do some more reading over the next week or so. I’m not at all familiar with the vibratory stress relief Steve suggest and no one I know is familiar with it so I need to do some research.
    Peening I’m sure is a good idea in general, but I have a couple problems here I’m not exactly sure how to handle. 1st is how much is the right amount? Too much will cause cracking. 2nd is how much will it help anyway? Normally peening processes are a surface treatment and I have to get 3/8” to over an inch deep where the threads are for it to help any. Some peening would probably help with stress relief, but again I don’t know how much to do or how much it would help….I need to do some research.
    The default answer will be I do nothing, but I think they are both good suggestions and I want to try to find enough information to make a proper decision.
  11. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,753
    The twilight zone
    Thanks. I never heard/saw those adds, but I like it :)
  12. 246tasman
    246tasman Formula 3
    Jun 21, 2007
    1,448
    Will Tomkins
    I also don't know about stress relief on your block , but the vibratory treatment sounds interesting. If you're going to stress relieve, surely you'll need to do the final cutting after the treatment to allow for any movement that it may bring about?
  13. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,753
    The twilight zone
    Yes, final cuts are the last step after all the welding and any peening or stress relief operation.
    I will do the rough cuts and get the heads on then move on to mating the engine to the trans in case there is any welding there. After everything is done, then the finish machining starts.
  14. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,490
    Canada
    Newman
    I would think the block is a pretzel by now anyway so stress relieve it and machine it so you only do this once....at least with this engine because like you said its not the last.
  15. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,753
    The twilight zone
    I got a chance to do some quick reading on vibratory stress relief today. It’s not ASME (American society of mechanical engineers) accepted yet but appears quite common in several industries, particularly for tooling. There are quite a few papers on the subject, but I haven’t tracked any down yet. It appears it can be effective but there are also some places making some pretty wild claims.
    I found a place the makes machines for it in Philly, I’ll give them a call and see it they also do treating. I really don’t want to ship the block all the way to CA and back and then ship it again for final machining. I guess once I get it fit to the car I could ship it to the stress relief place and have them ship it to whatever shop I decide to use to do the decks and line bore.
  16. GTHill
    GTHill F1 World Champ
    Jul 1, 2006
    14,054
    Double Wide
    GT Hill
    Mark,
    I think the better answer would have been to use J.B. Weld. No warping of anything then. Living in Arkansas may cloud my judgment so I may be off base... :)
    Gene
  17. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,753
    The twilight zone
    ahhh to live in Arkansas.....
    Heck why waste the jb weld on a simple job like this? I could have just sawed the studs off clean and just wrapper a couple rolls of duct-tape around the engine to hold the heads down :)
  18. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,753
    The twilight zone
    #368 mk e, Dec 4, 2007
    A little brute force in the form of a collet tool holder (thanks sean) and a 3 ft pipe with some help from the oxy-acetylene removed the last stud! The torch was key, I should have started there. I had to hold the torch in one hand and turn the pipe with the other becasue if I set the torch down, it cooled enough to make the collet slip....but it's out now.
  19. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,753
    The twilight zone
    #369 mk e, Dec 5, 2007
    I didn't feel like actually working tonight, so I just looked at stuff for a few minutes instead. The timing cover looks like I’m going to need to narrow it a bit to look right with these heads. I need to add a flange to the heads to seal to the timing cover, but I thought I’d get away with a basically stock timing cover…oh well, another thing on the list.
    I’m ¾ thinking I’ll finish the timing cover and valve covers in a semi-gloss bare aluminum and put a wrinkle red air box on top so it looks very similar to the OEM QV engine….and tell people it’s the rare 1984 only v12 option. Red valve covers are nice too but then I’d have to do something else with the air box…maybe carbon-fiber would look good, but not very OEM for 1984.
    I'll try and do some actual work tomorrow so I can get a little closer to needing a color decision :)
  20. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,753
    The twilight zone
    A little more welding done. 7 cylinders finished and 3 more 1/2 way. 2-3 hours left it looks like.
  21. buzzm2005
    buzzm2005 Formula 3
    Aug 23, 2005
    1,739
    NYC
    Buzz
    Won't all this welding and fitting of 348 liners require really, really precise positioning so that the piston/rod/crankshaft geometry works properly? The pictures look like the cylinder bores aren't, um, cylinders any more.
  22. Spasso
    Spasso F1 World Champ
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    Everything will be aligned off of the crankshaft bearing saddles for starters.
  23. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,753
    The twilight zone
    This is the part of the project where it looks it’s worst, but it looks worse than it is. The beauty of the design of an engine is that most stuff doesn’t actually have to be all that precise. The bores have to be round and to size, but machines are good at round holes so that’s pretty easy to get right and since the 348 liners are bigger diameter than the 400 liners (in most places) there is matal to cut to make then round. If the bore position is off a full mm in any direction it wouldn’t be ideal, but the engine would still run just fine, it's not all that important, but I'll be able to get them within a couple thousandths of an inch without all effort at all.
    You’re right that most of the cylinder is no longer a cylinder, but the bottom inch or so is untouched and right where ferari put it. I can either bold the block flat on the machine and tip the head to 30 degrees or I can trip the block to 30 degrees. It’s an easier and stronger set-up to tip the machine, but then I have to trig all the y direction movements when I start drilling the stud and pin holes. Anyway, after I pick a set-up I’ll indicate the crank journals parallel. Then I just need to put a dial indicator in the spindle and center up on what’s left of the bore, throw in the boring head and cut the hole round again. I’ll record the location of all the bore centers and use that information to decide where to drill the head studs and pin holes.
    I’m planning to use the 348 liners, which are bigger than the 400 liners so I have metal to remove and that will make the clean-up much easier. Cutting metal out is easy, putting it back is a pain. The problem at the moment is that I don’t actually have the liners so I have no idea what size to cut anything. For now I’m just going to cut off the heavy weld and get back close to the original 400 size at the bottom and QV liner (I have those) size up top. I want to do the finish liner bores after the block is final decked anyway so I know how deep to cut the holes.
    There is a solid day of rough machining I think (which probably means 2 days), but I should have the heads on the block this weekend and be on to the timing chain and cover issues. At that point is will start to look a lot more like there is any hope of it ever running again.
  24. Protouring442
    Protouring442 F1 Veteran
    Sep 5, 2007
    8,723
    Harriman, TN
    One Stupid SOB
    Mark, my friend, you are totally insane! I mean that in the best of ways however! =-)
    Keep up the pics and story, this is great!
    Shiny Side Up!
    Bill
  25. 350HPMondial
    350HPMondial F1 Veteran
    5,326
    Edwardo
    AAARRRrrrrrrggggg,,
    Mark!
    What did you do to my M11.0 X 1.0mm collet-stud puller,,,
    it's now,,,
    "Frankinpuller!" (wink)
