308 V12 conversion begins | Page 154 | FerrariChat
Discussion in '308/328' started by mk e, Oct 9, 2007.
Thread Status:
Not open for further replies.
  1. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,450
    Canada
    Newman
    I tried to save you money with the TR engine idea lol.
  2. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,739
    The twilight zone
    #3827 mk e, Apr 23, 2010
    After looking at the 400 vs aftermarket 365 bearings and thinking a bit I think I can make them work. The 365 bearings have what looks like a 1/2+ mm chamfer so most of what I would want to remove and maybe all that I need to remove won’t change anything bearing surface wise and if I need to go more the oil groove can be widened to balance the bearing surface side to side.
    So now I’ll call GT parts back and ask when they will have the right bearings in stock for me to buy. :)
    edit: no more after market 400 bearing from GT parts ever....they sell way to slow for it to make any sense....so I will be machining it apears......
  3. tazandjan
    39,167
    Mark- Have you checked with Brian Crall? The machine shop he uses has a pretty good handle on US replacements for Ferrari rebuild parts including valves, guides, bearings, etc. Might be worth a phone call and see if there is something suitable you do not have to machine yourself. Might be nothing, but you never know.
    Taz
    Terry Phillips
  4. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,739
    The twilight zone
    I don't want to call Brian...we'll scold me for even THINKING about machining on the bearings :eek:
  5. Spasso
    Spasso F1 World Champ
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    I have a feeling he would scold you about a lot of the things you are doing.
  6. PerKr
    PerKr Formula Junior
    Oct 10, 2007
    278
    Mariestad, Sweden
    Per Kristoffersson
    why not cut 0.5mm on each side? sorry, I'm probably missing something obvious, I'm not really that bright anyway :D
  7. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,739
    The twilight zone
    There is a locating notch in the bearing the sets where the bearing sits. One side is correctly located leaving all the extra sticking out the other side of the cap. If I cut both sides of the bearing I would need to move the locating notch in the caps and block and I’d prefer not to do that.
  8. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,739
    The twilight zone
    probably.......
  9. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,739
    The twilight zone
    I got the inside around the ports welded on the first head today. Hopefully I'll have some time to get to the othert one tomorrow.
    I noticed something odd about the wider 365 bearings....the appear to fit the 400 crank jounals as is. I'll have ot drop the crank in the block and see whats going on but I'm thinking I'll move the notches in the block and caps so it accepts the unmodified 365 bearings and say I need the wider 365 bearings to handle all the power I'm making and not say I was too cheap to just buy the right bearings :)
  10. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,739
    The twilight zone
    #3835 mk e, Apr 25, 2010
    I finished the second head this morning. Here's a few pic. First comes grinding a weld prep so the fill material has some place to go, then comes melting the torch a bit by running about 50% over it's rated amperage....the teflon gasket was gone after 1 port but the gas cup last through 10, not bad. Then a couple of the finished weld. Next I'll give it a quick grind so it looks like a port then get going on the actual intake manifold.
  11. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,849
    Atlanta
    John!
    Looking fabulous.
  12. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,739
    The twilight zone
    #3837 mk e, Apr 26, 2010
    Not much time this morning....I got up late them had to load the Argon tank into the car, but I did get started grinding the welds on a couple of the ports.
    The top and side seem good, but I'm not sure about the bottom....I'll need to look at it a bit more to figure out exactly where the cruve should be and whether I should weld more or grind more. The first thing I noticed was that I completely forgot to fill the nick in the bottom of the flange from drilling at the wrong angle, I'll get that after I decide on a bottom shape.
  13. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    Thus cut 1mm off the offending side ...
    Pete
  14. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,739
    The twilight zone
    That would leave the oil notch out of center so the short side would get more oil flow than the long side. I think I need to move the notches, but I'll take a good long look at it once I finish the intake stuff.
  15. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,739
    The twilight zone
    I got the top and sides of all the ports on the first head done and moved on to head 2. I decided to let the bottoms go for now and decide what to do when I start fitting up the manifolds and have a better sense of how everything wants to blend.
    Tomorrow I'll finish grinding on head 2 and move on to the finish cut on the flange faces so I'm ready to bolt manifolds on.
  16. Protouring442
    Protouring442 F1 Veteran
    Sep 5, 2007
    8,723
    Harriman, TN
    One Stupid SOB
    Did you ever wonder what this man's lawnmower must look like? :)
    Great work!!!
    Have you considered publishing a book on how you did all this? I know I would buy it! Perhaps you could get these guys to do a book on your car: http://www.buildbookusa.com/
    Shiny Side Up!
    Bill
  17. don_xvi
    don_xvi F1 Rookie
    Nov 1, 2003
    2,934
    Outside Detroit
    Don the 16th
    I remember back when he set the land speed record for lawn mowers under his psuedonym. "The current 80 MPH record was set by Bobby Cleveland at the Bonneville Salt Flats in 2006. " It may fall soon, so the 308 V12 may have to be put on the back burner to build a new land speed mower! ;)
    "Lawnmower Aims To Set 100 MPH World Speed Record"
    http://jalopnik.com/5524870/lawnmower-aims-to-set-100-mph-world-speed-record
  18. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,739
    The twilight zone
    Funny.
    You know, when it comes to things like a lawn mower or daily driver I just use them. No modifications, no cool wheels or expensive tires, h*ll they’re lucky to get oil changes or tires with legal tread left….all my time and money to into the projects that matter to me and at the moment that is the V12.
  19. KKRace
    KKRace Formula 3
    Aug 6, 2007
    1,052
    Rockville/Olney MD
    Kevin
    Not to sidetrack too much but did you decide if you are using the stock fuel tanks? I just bought up a bunch of stock on a tuner car place that went belly up and one of the items is a new 16 gal plastic fuel cell w/sender and foam.
    http://www.jegs.com/i/JAZ/547/252-016-01/10002/-1?CT=999
  20. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,739
    The twilight zone
    I'm keeping the stock tanks.....I'm in get it done mode and just can't add anything new to the list.
  21. KKRace
    KKRace Formula 3
    Aug 6, 2007
    1,052
    Rockville/Olney MD
    Kevin
    I could remember if the stock tanks where going to fit? I remembered there was some discussion early on and you where debating getting rid of the spare tire if you had to. I was thinking of you first before putting it on Ebay.
  22. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,739
    The twilight zone
    There was some dicussion.....but that was mostly you guys trying to see if you could talk me into anything else foolish :)
  23. rossocorsa13
    rossocorsa13 F1 Rookie
    Jun 10, 2006
    2,557
    Nashville, Tennessee
    M
    May I then tentatively ask if there is a similarly tentative projection for a start-up date? :D
    Just been following this for a while, and I know that it must be infinitely more of a patience test for you than for us, but...
    I am ready to see her run!
    Keep on truckin'. :)
  24. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,739
    The twilight zone
    Sep/Oct....or spring.
  25. Pizzaman Chris
    Pizzaman Chris F1 Rookie
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    Really?? What year??
