308 V12 conversion begins | Page 155 | FerrariChat
Discussion in '308/328' started by mk e, Oct 9, 2007.
Thread Status:
Not open for further replies.
  1. Spasso
    Spasso F1 World Champ
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    2011, (sorry Mark, I had to)
  2. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,735
    The twilight zone
    Yes, spring 2011 is when it should actually drive but it might make noise fall 201
    I got my grinding done. Machining the flanges tomorrow I guess....although I probably should touch up that drill nicks befer the machining.....welding tomorrow I meant to say.
  3. ramosel
    ramosel Formula 3
    Sep 11, 2004
    1,237
    Meadow Vista, CA
    R Moseley
    Like you need our help.... <grin>
    Rick
  4. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,735
    The twilight zone
    After more looking and comparing between the 2 heads I decided the best answer on the bottom of the ports was to grind not weld. I did weld up the little nicks and started the finish cut on the flanges….I cleaned up the first one but the second didn’t clean up at the same height so now head 1 has to go back on the machine. I should have this finished up Sat morning and be back onto the intake manifolds and stuff worth taking pics of.
  5. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,735
    The twilight zone
    #3855 mk e, Apr 30, 2010
  6. Spasso
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    This set-up should make it easier to add lower injectors at a later date, no?
  7. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,735
    The twilight zone
    yes, MUCH easier.
  8. duck.co.za
    duck.co.za Formula 3
    Jan 9, 2007
    1,005
    Cape Town South Afri
    Dave
    Mark that came out very nicely , job well done !!
  9. Jon Hansen
    Jon Hansen Formula Junior
    Feb 6, 2007
    509
    Grand Rapids, MI
    Jon Hansen
    I'm impressed. Nicely done!
  10. randyleepublic
    randyleepublic Formula Junior
    Dec 2, 2007
    825
    Beautiful Reno
    The Leonardo of Aluminum! Wow!
  11. Spasso
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    Of course you know the project won't be complete until you do.
  12. tazandjan
    39,164
    Mark- I cannot wait to hear this thing at 9000 rpm. Once Leonardo is finished painting, of course.
    Taz
    Terry Phillips
  13. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,735
    The twilight zone
    #3863 mk e, May 2, 2010
    Maybe...but I'm really hoping that between the new million dollar a piece 12 hole injectors, the multi-MAP board, end of pulse timmed sequential injection, and not using a bypass air system for idle so all the air is flowing past the throttle plate I'll get a good result with just 12 injectors. With 24 injectors I wouldn't need to hope, I'd know....but we'll see.
  14. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,735
    The twilight zone
    Yesterday I sawed the metal for the lower manifold flanges...then decide I had to clean up a bit and that burned up the rest of the time I had.
    On past manifolds I've built I've tried doing things a couple different ways. The first one I drilled the mounting holes...and then found that the flange got about .040-.060" shorter after welding and I had to egg the holes to get them back where they belong. The next time I drilled the holes undersize (I needed holes to put the flange in a jig) and then re-did them after welding and that worked ok.
    I think what I'm going to try on these is to drill only the center hole and leave all the port holes short by about .06-.08 per side and then try to figure out how to do the finish machining when the welding is done.....so, to the shop.
  15. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,735
    The twilight zone
    #3865 mk e, May 2, 2010
  16. airdelroy
    airdelroy Formula Junior
    May 10, 2007
    420
    Austin, TX
    Aaron Richardson
    Can I come out and help too?? Ill bring beer and more! How far is it from Austin? :D
    Aaron
  17. Spasso
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    Well, since you put it that way.......................................
  18. rossocorsa13
    rossocorsa13 F1 Rookie
    Jun 10, 2006
    2,557
    Nashville, Tennessee
    M
    When all is said and done, will you consider taking bids to do similar work for living room centerpieces?
    :D
    It's just so cool to see something like this built from such a ridiculous amount of scratch.
  19. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,735
    The twilight zone
    #3869 mk e, May 3, 2010
    I had actual work work I had to get done this morning so I only got a few minutes in the shop today :(
    The first thing I noticed was that the manifolds will need to held on with bolts not studs becasue they tuck slightly under the cam cover flange....I guess the fact that I needed to cut the head with a cutter that could reach under the flange should have given me a clue. Not really an issue but still.
    I quickly bandsawed a couple runers to about right on the bottom end and they look good I think. Tomorrow I'll cut the rest of them and start welding them on. Once the bottom is tacked on good I'll probably throw it in the mill and cut the tops all the same and tack the top flange on. This should all go pretty quickly and hopefully be done this weekend.
  20. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,735
    The twilight zone
    Sure! it's only 1641 miles ;)
  21. 350HPMondial
    350HPMondial F1 Veteran
    5,325
    Edwardo
    Only, 8.2 hours ,
    @ 200 MPH
    Better, take the 550.
    Edwardo
  22. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    Notch the manifold flange, as surely you are going to lighten this piece anyway? ;).
    Infact it would look real cool if you chucked it in the mill and milled it thinner with ribs for strength ... or is that the plan anyway. It would look like a sliding throttle. In fact have you thought about turning this piece into that? :D
    Also are your manifold lengths now longer ... ?
    Pete
  23. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,735
    The twilight zone
    maybe. the ears on the head might be far enough off the port centerline that I could cut enough off the falnge to make it clear
    I'm in get it done mode. The flange will get the same shape I put on the head I think but both sides....I think.
    The length isn't set yet. I want to put the TBs as low as I can and still be able to get the cam covers off so the runners will get shorter in the next couple days.
  24. 2dinos
    2dinos F1 Rookie
    Jan 13, 2007
    3,023
    The rib idea is very cool, and I do like the machine look as well. So here goes: What if you could machine in some ribs or weld in some stiffeners / supports, then blast the bulk of it with some media that would make it look cast or use a wrinkle finish, leaving the flange ends with the careful machined look.
    BTW - Sorry to suggest a time consuming effort on top of this incredible project :)
  25. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,735
    The twilight zone
    #3875 mk e, May 4, 2010
