308 V12 conversion begins | Page 157 | FerrariChat
Discussion in '308/328' started by mk e, Oct 9, 2007.
Thread Status:
Not open for further replies.
  1. jgoodman
    jgoodman F1 Rookie
    3,267
    Central PA
    Jay Goodman
    How many hours do you guess you have in this engine project so far Mark? If I had that much left on my "to-do" list, I too would have two beers next to me at all times! Looks great! I'm so impressed. Keep it up!
  2. tknobby
    tknobby Rookie
    Mar 12, 2009
    49
    Mark,
    You Are a master at welding... just a bit of fill in the dish, a gentle cut on the mill and voila! the correct chamber shape on the pistons. ;)
    Just kidding.
    Everything is looking just marvelous.
    Tom...
  3. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,732
    The twilight zone
    I don't know...a lot I guess......
  4. NeuroBeaker
    NeuroBeaker Advising Moderator
    Moderator
    Oct 1, 2008
    40,010
    Huntsville, AL., USA
    Andrew
    How about a picture of our central protagonist with a tool in one hand and a beer in the other? ;) :D
    All the best,
    Andrew.
  5. Ossie
    Ossie Formula Junior
    May 20, 2009
    666
    Melbourne, Australia
    Owen
    Yeah I agree, after 327,743 views it is time to face up Mike! Like 100's of others I've been kicking back at night and waiting in anticipation for your latest posts and pictures, but I am constantly wondering "who is this masked marvel of the mill and welder?"
  6. Mike Florio
    Mike Florio Formula Junior
    Jun 19, 2003
    599
    NW Rural Nevada
    Mike Florio
    I want to see a picture of Mrs. Mike. In my 63 years I've never encountered a woman with such patience and understanding. I had come to doubt any such creature existed. Just once, before I go to the Great Pitstop In The Sky I would like to lay my eyes on the visage of this woman of legend. She is as rare as a Unicorn. As revered as the Taj Mahal, Victoria Falls, and a certain Industrial Estate in the small town of Maranello, Italy.
  7. Spasso
    Spasso F1 World Champ
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    I BELIEVE IT'S MARK
  8. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,732
    The twilight zone
    I get called Mike so often I don't even notice any more :)
  9. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,732
    The twilight zone
    #3909 mk e, May 9, 2010
    You guys will have to settle for manifold pics for the time being.
    I finished welding on the last 2 runners, milled the end and welded on what will be the top flanges.
    The TBs have what was their a mounting snout that is about 5/8" long which would stick right out the bottom of my flange but since I'm only going to be using it to locate the TB so I'll cut it down it 1/4"....maybe 1/8". I'll do that next so I can fit the TBs once I start finish machining the intakes.
  10. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,732
    The twilight zone
    #3910 mk e, May 10, 2010
    This morning I chopped 1 or the TB snouts down to 1/8". Then milled the top flange on 1 manifold from 4" wide to 3.5 (finish will be about 3.75 with some profile) and cut the thickness down from 1/2" to 3/8"....I may go a little thinner before I'm all done. Tomorrow I'll bring manifold 2 to the same condition as the first one and I think mill the bottom flanges flat...then I guess it's tim to start putting holes in for bolts and TBs.
  11. jeffdavison
    jeffdavison F1 Rookie
    Jul 29, 2002
    2,544
    Suwanee Georgia
    Jeffrey Davison
    watcha gonna do for velocity stacks, air filter, and / or airbox?
    JD
  12. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,732
    The twilight zone
    For the air box I’m going to try to use one of the QV plenums I cut apart then never used for the supercharger project. The top of the velocity stacks will be in the air box then I will have a spacer that goes between the TB and air box to make adjusting the length possible….I think. I may change my mind when I try to build it next week.
  13. f308jack
    f308jack F1 Rookie
    Jun 7, 2007
    4,300
    Cape Town, South Afr
    Jack Verschuur
    Mark,
    Maybe it was discussed, I may have missed it, but I'm a little puzzled||:
    Initially when you had cut the bottom flange, I thought you were going to do all the shaping and drilling and then split the material in half, but it looks like you're starting to mill stuff to the required thickness: Why so heavy?
    Also, are you keeping the flanges all attached to eachother in one row of 6? That's an awfully long strip of material (and quite a lot of it) to create tension when it starts expanding at a different rate as the head. Is this not a problem?
  14. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,732
    The twilight zone
    I want the bottom flange relatively thick because I couldn’t fit as many bolts as I would have like and I don’t want leaks. I am going to cut away quite a bit of material between the ports, but the thickness will be about 7/16” when it’s done.
    The top flange I’m still pondering a bit as I think about the TB linkage. I’m thinking I’ll leave a web or rib between the ports but probably drop down to ¼” or 5/15” thickness.
    Thermal stresses, I’m not sure. The lower flange will be pretty close to the head temp so that shouldn’t be a problem but I need to think about the top flange.
  15. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,732
    The twilight zone
    I made the 2nd one look like the first one this morning so no real point in pics. Tomorrow I shpuld be able to get the bottom flange cut and drilled of both manifolds and maybe get them flipped back over and get going on drilling the tops but that will most likely be thursday.
  16. NeuroBeaker
    Moderator
    Oct 1, 2008
    40,010
    Andrew
    #3916 NeuroBeaker, May 11, 2010
    Wait a minute... who's that in the background?! :eek:
    Could it be... is it him?? Was our Masked Mechanic caught out by the camera timer?? :D
    All the best,
    Andrew.
  17. Ossie
    May 20, 2009
    666
    Owen
    Nicely done, but damn that image is going to flash in my mind everytime I read one of Mark/Mike/Mork's posts...!
  18. bert308
    bert308 Formula 3
    Nov 30, 2002
    1,776
    Roermond Netherlands
    Bert Kanters
    Someone posted a pic of Mark and his kid on this site, maybe it was not in this thread I sure don't know where/how to find it. But he looked quite normal, like Superman in his Clark Kent clothes.
  19. Pizzaman Chris
    Pizzaman Chris F1 Rookie
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    I remember that picture, Verell had taken it while paying him a visit. Cute little guy.
  20. bert308
    bert308 Formula 3
    Nov 30, 2002
    1,776
    Bert Kanters
    #3920 bert308, May 11, 2010
    Ah, I searched this thread for posts from Verell, here is the pic.
  21. NeuroBeaker
    Moderator
    Oct 1, 2008
    40,010
    Andrew
    Well, Mark does need an avatar... ;)
    All the best,
    Andrew.
  22. NeuroBeaker
    Moderator
    Oct 1, 2008
    40,010
    Andrew
    Aha - it's always nice to put a face to a name. :D
    Many thanks,
    Andrew.
  23. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,732
    The twilight zone
    I didn't think anyone would remember that.....
  24. Protouring442
    Protouring442 F1 Veteran
    Sep 5, 2007
    8,723
    Harriman, TN
    One Stupid SOB
    You know, he looks normal...
    Shiny Side Up!
    Bill
  25. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,732
    The twilight zone
    That’s exactly what makes all the psycho type movies so scary too ;)
