308 V12 conversion begins | Page 158 | FerrariChat
Discussion in '308/328' started by mk e, Oct 9, 2007.
Thread Status:
Not open for further replies.
  1. Spasso
    Spasso F1 World Champ
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    MORK is good...........................
  2. Spasso
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    It's the benign looking ones that are the most dangerous.:)
  3. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,729
    The twilight zone
    #3928 mk e, May 12, 2010
    I took the finish cuts and finished drilling the bolt holes in the hole flanges this morning and found a small issue this morning. The top flanges sit about 2* of square making 4* between them. I traced the issue back to the flanges on the heads which I appear to have cut at about 18* instead of 20* for somehow. I don't really want to mess with the angle on the heads at this point becaause the bolt holes are square to the flange face and I would like them to stay that way. There really is nothing majic about 20*, it was just intended to make things easier because it's a round number. So it looks like I;ll be re-cutting the top flange which means it will get thinner and that will make the people who wanted it lighter anyway happy but it also means I'll need to mill the bottom side of the flange as well as the top or it will look stupid.
    Tomorrow I'll profile the lower flange while the mill is still at 20*. Once that is done I'll reset to 22* and fix the top side of the upper flange and do all the machining on that face, then square the mill up, flip the manifold over and try to figure out how to machine the back side of the top flange. I'm still hoping to finish up this weekend....we'll see.
  4. ramosel
    ramosel Formula 3
    Sep 11, 2004
    1,237
    Meadow Vista, CA
    R Moseley
    After you profile the lowers, is the knee on your mill deep enough to just put the assembled block up there and fly cut the top of uppers?
    As far as the backsides...I don't know that it would "look stupid". None of your work looks stupid. Probably just an ugly reminder of a small miss that bugs you like it bugs me. Once you've fixed it... We've always found radiusing edges will hide a few thousandths of side to side inconsistencies.
    Rick
  5. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,729
    The twilight zone
    I'm not sure, I'll measure it.
    yeah...I have to fix it. I can bolt it down and fly cut the outside part that shows easy enough....I may call the part I can't reach easily a support rib ;)
  6. ramosel
    ramosel Formula 3
    Sep 11, 2004
    1,237
    Meadow Vista, CA
    R Moseley
    The stuff we can't get to becomes "Saftey Features"
    Rick
  7. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,729
    The twilight zone
  8. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,729
    The twilight zone
    It looks like there will be a slight delayl next week while I to go to Atlanta to put out a fire.
    Call - "Mark, it breaks when I do this, I broke 3 this morning".
    ..........so I need to fly 1000 miles to say - "Oh yes, that is one of the very best ways to break these and it is also pretty dangerous. You really shouldn't do that". ;)
  9. PittsS2APilot
    PittsS2APilot Formula Junior
    Jun 29, 2007
    857
    Gulfport MS
    Joe
  10. jeffdavison
    jeffdavison F1 Rookie
    Jul 29, 2002
    2,544
    Suwanee Georgia
    Jeffrey Davison
    Hey Mark,
    Drop me a PM if you're going to spend a little time around Atlanta. Maybe we can meet up.
    JD
  11. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    But it doesn't need to be square ... who cares if the throttle bodies sit at a 4* angle to each other.
    Pete
  12. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,729
    The twilight zone
    #3937 mk e, May 13, 2010
    I got the profile on the lower flange cut this morning. I still need to hit them with the sander but they are mostl done. Upper flanges tomorrow.
  13. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,729
    The twilight zone
    I fthey were angled in they would look "right" and I would let it go, but angled out just makes no sense really.
    I want them to sit square because that will let me easily raise or lower the air box (with the velocity stack tops in it)for tuning with just a simple spacer change....angles would make this a bit more difficult.
  14. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,729
    The twilight zone
    hmmm.....I think I've about made the entire thing with bits from the scrap pile so I don't know if putting it back then taking it back out would change anything. :D
  15. jeffdavison
    Jul 29, 2002
    2,544
    Suwanee Georgia
    Jeffrey Davison
    #3940 jeffdavison, May 13, 2010
    Mark,
    This would look cool. Imagine 12 under your hood.
    They are filters that go directly over the trumpet of the velocity stack.
    They come in different sizes. As you can see they are very low profile.
    Pegasus Racing has these available.
    The intake noise would be as satisfying as the exhaust note!
    http://www.pegasusautoracing.com/productdetails.asp?RecID=6252
    http://www.pegasusautoracing.com/group.asp?GroupID=AIRHORNFILTER
    Who needs a pcv valve? road draft baby!
    JD
  16. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,729
    The twilight zone
    They are very cool looking but I'm a big believer in pactual air filters particularly on street cars.....no idea where I'm going to put air filters, but I think I want them.....maybe the trunk sililar to the 355/360 setup??
  17. 246tasman
    246tasman Formula 3
    Jun 21, 2007
    1,446
    Will Tomkins
    This shows you must have faith it's all going to hang together long enough to get a chance to wear if you don't fit them
  18. Spasso
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    I can't imagine NOT running the very best filters, especially after all the work that has been to this engine.
  19. Spasso
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    That has to be the funniest quotes I have ever read in this forum, probably because of who who said it.
  20. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,729
    The twilight zone
    It's funny becasue you're not the one who has to fly to atlanta and lose a couple days in the shop :(
  21. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,729
    The twilight zone
    No pictures from this morning. I quickly cleaned up the profile on the lower flange so it looks the same only better and then did a test cut (1/2 the final depth) at 18* (not 22*, that was 2* the won't way) and it's really close but 18.5* would be better so I'll kick the head another 1/2* then start the finish work.....and get the TBs mounted and on with something else.
  22. Spasso
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    We all feel bad for you Mark, deep inside. We would rather see you have 2 months of uninterrupted time in the shop.:)
  23. Pizzaman Chris
    Pizzaman Chris F1 Rookie
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    Oh yeah, Lana will LOVE that. :)
  24. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,729
    The twilight zone
    I THINK I'm out of the atlanta trip...we'll see.
    I remilled ther tops of the flanges and they look pretty good. I can't show you any pics because little one seems to have wandered off with the wire to download them :(
  25. don_xvi
    don_xvi F1 Rookie
    Nov 1, 2003
    2,934
    Outside Detroit
    Don the 16th
    Well hopefully you're out looking for the little ones!
