308 V12 conversion begins | Page 159 | FerrariChat
Discussion in '308/328' started by mk e, Oct 9, 2007.
Thread Status:
Not open for further replies.
  1. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,729
    The twilight zone
    The one manifold is pretty much done but still no wire for the camera so I can't post the pics I took.
  2. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,729
    The twilight zone
  3. hotrod406
    hotrod406 Formula Junior
    Sep 18, 2007
    540
    Grand rapids area,MI
    Tim
    Nice. What did you use to do the profiling? You don't have a cnc mill, do you?
  4. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,729
    The twilight zone
    I blued it, scribed it, and cut to the lines the best I could......like being back in 3rd grade again :)
    The profile doesn't actually do anything but remove metal so milled to scribe lines and sanded to make it pretty is plenty good enough.
  5. hotrod406
    Sep 18, 2007
    540
    Tim
    You must be pretty good with those knobs then. Doing curves like that ain't easy. Good job!
  6. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,729
    The twilight zone
    #3956 mk e, May 16, 2010
    And then there were 2.
    I still need to weld around inside the top flange and do a LOT of grinding but I think I'm going cut down the rest of the TBs first because I want to see them on the engine. These are tucked in about as tight as they can be tucked I think and I think with a little angle back cut on the upper flange the cam covers will clear to come off.
  7. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,729
    The twilight zone
    Thanks.
    For me the key is to only move 1 direction at a time. I move away, move about over, move back to the line. I like to come up to the line from whichever axis is more sqare to the line, it seems easier that way. These took me about 1.5 hour each to cut the shape on.
  8. Jdubbya
    Jdubbya The $10 Trillion Man
    43,161
    PNW
    Oh man it's starting to look so good!! I love this thread :)
  9. PittsS2APilot
    PittsS2APilot Formula Junior
    Jun 29, 2007
    857
    Gulfport MS
    Joe
    Man, that is going to be ONE BAD A$$ MOTOR! I along with the others following this build can't wait for you to finish it. Perhaps a road trip for the initial startup is in order for some of us? (hint hint) :)
  10. f308jack
    f308jack F1 Rookie
    Jun 7, 2007
    4,300
    Cape Town, South Afr
    Jack Verschuur
    Mark,
    That's starting to look pretty spectacular!
    I'm trying to imagine that big lump in the back of a tiny 308...
  11. harmitc
    harmitc Karting
    Nov 2, 2003
    207
    England
    Bernard R
    Love it! Best thread by far!!
  12. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,729
    The twilight zone
    #3962 mk e, May 17, 2010
  13. Pizzaman Chris
    Pizzaman Chris F1 Rookie
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    Looks great Mark.
  14. tknobby
    tknobby Rookie
    Mar 12, 2009
    49
    Wonderful execution Mark. Looks like it is supposed to look.
    Tom...
  15. ramosel
    ramosel Formula 3
    Sep 11, 2004
    1,237
    Meadow Vista, CA
    R Moseley
    The Frankentwelve has nostrils!!!
    Looks GREAT Mark!
    Rick
  16. airdelroy
    airdelroy Formula Junior
    May 10, 2007
    420
    Austin, TX
    Aaron Richardson
    Looking good. I guess there is enough clearance above this for a cleaner under the deck lid?
    Aaron
  17. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,729
    The twilight zone
    I don't know...maybe. I've done all I can to keep it short, but at this point it is what it is. I'm going to do another test fit once I get the other 10 TBs modified and on so we'll know in a few days if it fits.
  18. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    Flippin beautiful :).
    Amazing work. I've got to get myself a lathe and a mill so I can have as much fun in the shed as you are. Man I'm jealous!
    Pete
  19. KKRace
    KKRace Formula 3
    Aug 6, 2007
    1,052
    Rockville/Olney MD
    Kevin
    How about we just setup a live webcam in your shop?
  20. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,729
    The twilight zone
  21. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,846
    Atlanta
    John!
    We don't wanna see Mark naked working on that engine.
  22. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,729
    The twilight zone
    #3972 mk e, May 18, 2010
    Erik whos been over to help a couple times made a suggestion I like yesterday. The QV looking air box should pop off quickly/easily to show off the TBs inside and I think I can make that happen without a lot of effort. I was planning to make the bottom removable anyway to be able to get the injectors in, so this would just mean using ball plungers in detents or similar to hold the top/sides on instead of screws.
    Here’s a picture that shows kind of what I’d have……it’s kind of an optical illusion, but it you stare at it long enough you should notice there is an F1 engine in the pic with the top of the air box removed ;)
  23. Protouring442
    Protouring442 F1 Veteran
    Sep 5, 2007
    8,723
    Harriman, TN
    One Stupid SOB
    Hey cool.... if squint long enough, I think I can just about make it out... I wonder how they make those sort of photographs?!? ;)
    Still loving this project! Simply amazing my friend!
    Shiny Side Up!
    Bill
  24. 308nut
    308nut Formula 3
    Jul 22, 2002
    1,881
    NOLA/Covington
    Wade
    where's the damn engine, I can't find it.
  25. VIZSLA
    VIZSLA Four Time F1 World Champ
    Jan 11, 2008
    41,692
    Sarasota
    David
    And its for sale. Might have been easier to go that route;)
