308 V12 conversion begins | Page 161 | FerrariChat
Discussion in '308/328' started by mk e, Oct 9, 2007.
Thread Status:
Not open for further replies.
  1. Pizzaman Chris
    Pizzaman Chris F1 Rookie
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    Oh man, I just made it to work. I'm out of breath.
    Did I get the 4000 reply??
  2. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,731
    The twilight zone
    No no, that's mostly done.
  3. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,731
    The twilight zone
    Sorry, I wasn't even paying attention for you.
  4. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,731
    The twilight zone
    There plenty of flow area so flowing enough air flow is no issue. The volume is about tuned frequency and that will have to be what is unless I want to alter the deck lid.
  5. Jdubbya
    Jdubbya The $10 Trillion Man
    43,167
    PNW
    That looks AMAZING!!!!
  6. Tiger_Carrera
    Tiger_Carrera Rookie
    Jun 15, 2005
    42
    Gatineau, Quebec
    Gary Corbett
    Mark - All the detail work has looked great all along this thread and now the final product is starting to crystallize and look fabulous. Pretty cool how much your little guy has grown and can help you out - there are all sorts of great lessons you are already passing on to him by setting a fine example.
    A thought on the cylinder heads now that you are at the point of fabricating the airbox. Will the fit be tight enough that the thickness of a compressed head gasket (X2) would upset the spacing? It would only be .010" or so each gasket, but you did mention things were really tight. Just a thought.
    Gary
  7. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,731
    The twilight zone
    #4007 mk e, May 20, 2010
  8. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,731
    The twilight zone
    Yes the gaskets will matter, they are .055 compressed and that will change things a bit.
  9. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    What about when the heads need skimming, etc. maybe in the future?
    How ever you design this airbox you need to take that all into account.
    Pete
  10. PittsS2APilot
    PittsS2APilot Formula Junior
    Jun 29, 2007
    857
    Gulfport MS
    Joe
    Sorry Pizzaman, I got the 4000 and didn't even notice! (grin) Joe
  11. PittsS2APilot
    Jun 29, 2007
    857
    Gulfport MS
    Joe
    Since you will be modifing the rear hatch anyway, you could have the plentum attached to the rear hatch so that when you open it up, it would lift off the TB's to expose the engine for viewing? My guess is you will doing a lot of "viewing" and taking the plentum off and on will be a pain. All that would be needed is a custom compression type gasket to seal when the plentum is lowered to the TB's. Not sure if you thought of that much work but at this point....:)
  12. Pizzaman Chris
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    No worries Joe.
    5000 is just around the corner. :)
  13. Denman_Honda
    Denman_Honda Karting
    Sep 3, 2009
    123
    DFW, TX
    Chris Denman
    No one really pointed out that page 200 was opened by Mark, lol. Congrats on the headway thus far. I love this project!
  14. NeuroBeaker
    NeuroBeaker Advising Moderator
    Moderator
    Oct 1, 2008
    40,010
    Huntsville, AL., USA
    Andrew
    Cool idea - I wouldn't have thought to make the cut diagonally. :)
    All the best,
    Andrew.
  15. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    I really do understand good filtration, and the work youve done/doing is beyond ambitious and certainly worthy of good preservation. However, that motor is not only one of a kind, its montrously pretty. If it were me, and I know its not, I would risk a somewhat shorter engine life/faster cylinder wear and put some decent foam filters on those throttle bodies rather than hide its beauty and your amazing workmanship under that huge plenum. Its not like its going to be a daily driver taking excursions down occasional dirt roads. Or is that what your planning? And the sound that monster would make with those throats allowed to breath should be equally monstrous.
    Perhaps Mark would allow a poll vote to decide? Marks V-12 conversion: Plenum, or bella machina?
    It really looks incredible. Any gear head worth his dirty fingernails should be drooling. Makes a guy wanna go bankrupt buying machine equipment and welders.
  16. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,731
    The twilight zone
    I love the look of open TBs too……but covering them is really the best answer. Think of it as lingerie for the engine ;)
  17. PerKr
    PerKr Formula Junior
    Oct 10, 2007
    278
    Mariestad, Sweden
    Per Kristoffersson
    if it was me I would build a clean laboratory environment to run it in and filter the incoming air twice to avoid having to re-do anything :D
    whatever Mark decides to do, once the car is parked at a show he could remove the airbox to show off those throttle-bodies.
  18. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,731
    The twilight zone
    Yes. The plan is to build the cover of the air box to just pop off/on.
  19. Hans
    Hans F1 Veteran
    Feb 17, 2006
    7,734
    Hilversum, Netherlands
    Hans Teijgeler
    #4019 Hans, May 21, 2010
  20. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,731
    The twilight zone
    What I'm doing will look at least as good and will work much better. You guys have to remember you're looking at pictures I took at an angle that shows the air box idea well but from the side you get a completely unobstruct view of the TBs .
  21. tknobby
    tknobby Rookie
    Mar 12, 2009
    49
    Mark,
    Make a mold of the air box top when finished and have one cast in lexan.
    Good filters are the best idea.
    Tom...
  22. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,731
    The twilight zone
    #4022 mk e, May 22, 2010
  23. tajaro
    tajaro Formula Junior
    Mar 22, 2009
    686
    Gulfport Florida
    Erik V
    Looks great Mark and still shows off some T&A (throttles and airbox...).
    I think the stock ribs, Ferrari and QV badges and perhaps a pony will give the exact "could it be stock?" look you're going for.
    You are an artist... Cheers
  24. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,731
    The twilight zone
    #4024 mk e, May 23, 2010
    Saturday endup hot rod day in my shop when a couple friends stopped by with projects but I did get to spend a couple hours welding and grinding the air box. I'm thinking I'll put the air inlets on the ends,,,but if I want the top to pop off easily I guess they should be on the bottom part no the top part......which will make the seal a little harder to do. I'll need to think about it a bit I guess.
  25. Conquest351
    Conquest351 Karting
    Mar 13, 2008
    110
    Central Texas
    Brian Hamilton
    I'm thinking I am going to have to agree with everyone else who's STRONGLY suggesting the lexan top on the plenum. I know you want this thing to look stock and like Enzo himself built this as a mad scientist edition and everything, but that would just be amazing. Maybe as an optional plenum? You've surely got enough aluminum laying around there to make 2 of them. LOL
    Laters,
    Brian
