308 V12 conversion begins | Page 2 | FerrariChat
Discussion in '308/328' started by mk e, Oct 9, 2007.
Thread Status:
Not open for further replies.
  1. johng
    johng Formula 3
    Oct 23, 2004
    2,298
    northern va
    john g
    cool, i'd like to see what you can do with the testarossa heads. are you talking about original testarossa or 512TR heads?
  2. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    I dont know if youve thought about this, but 363 HP at the wheels would require about 440 HP. A stock 512 TR develops over 420 HP with low compression, mild cams, cats and emission controls. Even the lowly 365 motor, a mere 4.4 liter, easily made 380 HP.
    I submit that engine needs someone who actually knows what they are doing to tune it properly. Bob Norwood didnt get the reputation hes recieved by building engines that made less HP than a stock example.
  3. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,635
    The twilight zone
    The Butcher
    You know....I asked for TR heads thinking 512TR and ASSUMED that's what I bought.....I should have asked the year I need to get that answer. I don't think it really matters too much if I'm going to port and do cams anyway, but it would be good to know.
    Edit: Are there even any differences you know of? The hp bump in the 2 model looks simple what you'd expect by replacing the CIS with EFI?
  4. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,635
    The twilight zone
    The Butcher
    The way the manifold is built it looks very much like it was built to have a couple turbos on it and the billet block also makes me think massive boost application. Everything is too small on the intake for natural aspiration, I think the plan was boost and it's small to reduce system volume, which would improve throttle response. It needs a new intake system at least and probably porting to run naturally aspirated and make hp.
  5. johng
    johng Formula 3
    Oct 23, 2004
    2,298
    northern va
    john g
    i don't know what the differences are. the hp diff between the two models is over 40hp. i didn't think the jump could be that big just from going to EFI. the engine internals are pretty different in the 512. i'd say the heads are probably not swappable without mods.
    john
  6. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,635
    The twilight zone
    The Butcher
    You get about 30hp on a 308QV swaping out the CIS for EFI, so 40 on a 512 seems about right.
    What's different internally on the engines? Nikocyl (sp?)vs iron liners??
  7. johng
    johng Formula 3
    Oct 23, 2004
    2,298
    northern va
    john g
    mark, all i know is that the compression ratio is different (8.8 vs 10.1). so the pistons are different. best thing to do is ask in the tr section. there are a few people there who really know these cars well.
    john
  8. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,635
    The twilight zone
    The Butcher
    The CR change is consistant with what ferrari did going from the CIS 328 to the EFI 348, so that makes sense. I wonder if they added more cam too like the 328/348 change?? more research required I guess. Thanks for the heads up John.
  9. 246tasman
    246tasman Formula 3
    Jun 21, 2007
    1,446
    Will Tomkins
    I've just spoken to Rob Wilson.
    His heads will flow at least 515bhp at 8000rpm.
    He is using cams which are similar timing to the 250GTO.
    I guess you don't want to spend so much but he could supply his very neat slide injection set up for around £5k including the curved P4 trumpets.
    I've just remembered I also have a set of 400 cams, unused since reprofiling to Daytona spec if you go down the 400 head route
    Will.
  10. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,635
    The twilight zone
    The Butcher
    a search turned up this short thread, which I think answers the questions
    http://www.ferrarichat.com/forum/showthread.php?t=106712
    It seems there are quite a few changed 512TR vs testarossa, the key ones for me being the 512TR got
    Nikasil
    Larger intake valves
    Different cams, buckets, springs
    Different head gasket to accommodate revised head coolant circulation.
    The heads I bought are ’89, so testarossa and probably the better choice in that they were on an engine with iron liners, so I’m thinking there’s a better chance of coolant/oil passages being in the right places…..maybe.
    To make the hp numbers I’d like to make will mean the making peak power up around 7500-8000 and that will require reworking the ports, fitting larger intake valves, and probably higher lift cams regardless or which set of heads I started with so none of the 512TR improvements would still be there after the rework anyway. I’m guessing the 512TR heads/cams are probably very similar to 348 because 300hp from 3.4 liters is 88hp/l, just like the 512TR which are very minor changes front he QV/328 engines and nothing to worry about…..see how I convince myself I did the right thing even though I didn’t mean to :)
    Hopefully tonight I won’t find anything else on the shelves to ebay (I don’t see you guys bidding by the way, except Verell that is :) ) and I can get to actual work on this. The first thing I need to do is get my trans cleaned up and throw it up on the milling machine so I can use the digital read out to map the bolt patter, which I’ll need to design and make the adapter to mount the 400 engine on the trans. I’ll post some pics when I get rolling.
  11. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,635
    The twilight zone
    The Butcher
    One think that REALLY bothered me with supercharged 3.0 engine was the gear ratios….it made so much power/torque that first gear was only good for idling around the parking lot, so I rarely used it making the car effectively a 4 speed. And in 5th gear the engine is reving way more than it needs to be on the highway. I expect the 12 to have very similar torque to the supercharged 8 and a little more hp, so I really want to address this problem
    There are racing kits to alter the final drive ratio, but they are straight cut gears, so loud, I don’t want that. One place said they could make a set of helical gears, but it was $5k for 1 ratio if I remember right, way out of my budget. The other problem is those kits make the drop gear case about an inch wider and I’m going to need to move that case over as far as possible to fit the 12, so I think that is just not an option.
    I think that if I take the existing gears and cut a new larger hub into then, I could make new center hub for them that would let me put the trans gear up on the clutch and the clutch gear on the trans. That would change the final drive ratio by 23% and get me pretty close to where I think I want to be. Of course I’d also need to move the idler center, but I don’t think that would be to hard. If I ever get this conversion to a “kit” stage, it would be easy to do the basic which leaves the drive ratio alone and only means messing with 1 gear or the deluxe that messes with everything in the drop gear case.
    Anyway, I’ll need to get all the casting in the milling machine to amp them so I can make CAD models it looks like….busy, busy, busy……
  12. 246tasman
    246tasman Formula 3
    Jun 21, 2007
    1,446
    Will Tomkins
    I didn't mention also that Rob is using standard size (but improved) inlet valves.
  13. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,635
    The twilight zone
    The Butcher
    Will,
    Has the engine run and dyno'd yet?
    Alternatively, would it be possible to get the actual flow numbers or at least the peak flow number and test pressure?
  14. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,635
    The twilight zone
    The Butcher
    Will,
    You've probably seen this, but Carobu did a 412 and were happy to see 406Hp at 6400 rpm. That is with webers, so I'd guess 430 or so with EFI. Looking at the dyno graph, the engine is very clearly flow limited, which could be heads, carbs, cams, exhaust. The exhaust looks about right, the carbs are a part of the problem I'm sure, The cams are about as big as I'd go on a street engine...maybe another 5 degrees.
    The heads though....the right flow for an engine that size with a 7700 redline is about 120-130 cfm at 10" water, or 205-220 at 28" water, if the heads hit these numbers, the engine with the cam it has would be making about 500-550 hp at 7200-7500 I think.
    http://www.carobu.com/html/ferrari_365_c_4.html
    They ported the heads and got them up to 13%....to not quite as good as stock 308QV heads. This build is really the main source of my concern. Do you know of a 400/412 engine that been dyno'd and made up it the 500s?
    Mark
  15. 246tasman
    246tasman Formula 3
    Jun 21, 2007
    1,446
    Will Tomkins
    No it hasn't run yet.
    I'll see if I can get the flow figures and what the hell - a photo too!
  16. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,635
    The twilight zone
    The Butcher
    Sweet!
  17. james patterson
    james patterson Formula Junior
    Dec 8, 2003
    417
    Dallas Texas
    James Patterson
    Mark - You have a great imagination! This will be a great project to watch go down. Are you planning on running chains or belts. If you go belts you could get rid of the entire front cover and run the cams direct off the crank and shorten up the whole assembly by several inches. The trick is - I think- getting the oil drain backs in the block. There are 'lugs' in the TR head castings that Batten used to install tube drain backs for the motor in the P4 picture but they don't lineup with the original drain backs in the 400/412 blocks. But I am sure I'm not telling you anything you haven't already thought out. And you are right about the intake on the P4 pictured. It was originally/maybe going to be a turbo but was also restricted to fitting under the deck lid and Bob wanted to run common plenum on it. Keep us posted.
  18. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,635
    The twilight zone
    The Butcher
    My plan was to try and use the chain just so I don't need to worry about belts anymore....but the idea of ditching the timing cover is pretty good. When everything gets here I'll have to see if there is anyway to do that....I'm thinking the pulleys on the heads/pulleys may stick out too far to make that possible, but it's sure worth taking a look at.
    You are telling me stuff I didn't know for sure, .....I like to use the ignorance is bliss school of thought at the start of a project, it's the only way I would ever start anything and I was still hoping the heads would just drop on. If it turns out to be just the oil returns though, that shouldn’t be too bad. The easiest thing would be to tap the head and run external lines I guess, or if the 400 block is anything like the 308 block, adding new lugs to the block and closing the old ones looks pretty easy too, I’ve got plenty of welding rod :)
  19. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,306
    Surely the easy way to solve this is just with wheels & tyres - maybe some 17" rims with 40 or 50 profile rubber. Havn't done the sums but it must take you a good way toward where you'd want to be.....
    ....and besides that it'll give you tons of room for some nice big brakes!
    I.
  20. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,635
    The twilight zone
    The Butcher
    #45 mk e, Oct 11, 2007
    Tonight I got going on some actual work on project. First up was measuring where the crank is relative to the flange so I’ll know how think to make the adapter.
    Next was to get the trans cleaned up a little and up on the mill, I’ll map it out tomorrow.
    Then there was looking at the oil return lugs to see how they’re made because James scared me a little…..but it doesn’t look too bad. The ribs inside the block are the same at each stud and just a little tube looking thing on the outside that would be pretty easy to weld on so no worries.
    Progress!
  21. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,635
    The twilight zone
    The Butcher
    yeah, but it's already got 18s :)
  22. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,635
    The twilight zone
    The Butcher
    I paid for the 400i engine today, so it should be here in a week or so and then we'll finally know if it fits!
    Actually, now that the QV engine is parted out, I know the 400 engine fits....one way or the other, it's going in the car if I ever want to drive it again :)
    The TR heads are due tomorrow. When they get here I'll make up a rough CAD model of them so I can design intake/exhaust system and have the specs to start sorting out the timing belt/chain and water/oil passage issues.
    I still need to model the bell housing, drop gear cover, and trans/engine end cover…..I’m just getting started and already a week behind schedule…..
    I did throw the trans back in the car and measure a bit. It looks like it is possible to put the v12 centerline in the same place the v8's was and still have about 1-1.5" clearance between the drop gear cover and the inside of my 10.5" wide rear wheels. So that's good. I may not move it over that far, but I would like too and at least now I know I can. With that piece of information I'm 3/4 thinking the easiest thing to do is make up a new input shaft for the trans instead of trying to extend the original somehow like the goldsmith conversion did......we'll see.
  23. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    this is so cool.
    What I am looking forward to is the sound.
  24. duskybird
    duskybird F1 World Champ
    12,553
    29 Electoral Votes
    Bill B.
    Just found this thread. I'm subscribing to this as I don't want to miss anything.
    Mark I like the way you think, on a different scale I'm in the process of stuffing a Viper engine into a 69 Plymouth Satellite convertible.
    Please post plenty of pics!
  25. jimshadow
    jimshadow F1 Veteran
    Feb 19, 2006
    6,241
    Indiana/North Carolina
    JIM
    This is just way too cool not to watch!!!
