308 V12 conversion begins | Page 20 | FerrariChat
Discussion in '308/328' started by mk e, Oct 9, 2007.
Thread Status:
Not open for further replies.
  1. luckydynes
    luckydynes F1 Rookie
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    Curious how much they are these days . .. back in 1990 I think they were like $25/ea.
    Also curious if there's something else that's re-usable . . . don't think the gas filled seals are.
    Sean
  2. Ken
    Ken F1 World Champ
    Oct 19, 2001
    16,078
    Arlington Heights IL
    Kenneth
    This project is truly amazing to me. The complexity of it boggles my mind at times. To take such a variety of parts and put them all together, plus the logistics of mounting it all is truly a job for a skilled engineer. It reminds me of a NASA space vehicle for all the details that must be addressed!
    If I may as a silly question, when all this gets put together and it's ready to go, what do you think the odds are will it work? Are you expecting just minor tweaking in the tuning end, or do you think it's likely something important mechanical will be amiss and you'll have to tear it all apart again, maybe more than once?
    While I understand the theory behind engines, when I see all the engineering that really goes into these things I can see that this is quite an undertaking, even for experts with all the tools, knowledge and help you have. Or is it really not so bad and it only looks complex?
    I hope everything can be checked and rechecked so it gives you many years of trouble free driving!
    Ken
  3. RVIDRCI
    RVIDRCI Formula 3
    Dec 1, 2005
    1,576
    Long Beach / Phoenix
    Luigi
    Mark,
    Look back at your source on those. I believe VW shims deck height at the base of the cyl, and the head to cyl interface rings are in fact copper (been a long time since I built VW motors, but I think I'm correct) You may just have been shipped the wrong part.
  4. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,813
    The twilight zone
    Reusable is nice but so is compressible because it gives me a bit more tolerance on the heights.
  5. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,813
    The twilight zone
    It’s not as bad as it seems. Most of what I'm doing is really just fab work that relies on ferrari’s engineering. Also, most things interact in only 1 way with other parts, for example as long as
    I get the timing chain straight it will work with the sprockets. There are a lot of parts, but it can be tackled one part at a time and it will get done and it will work.
    I’m pretty confident it will work when I’m done and won’t need to come back out and back apart….we’ll see…..
  6. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,813
    The twilight zone
    I'll take another look....I remember copper rings, but they may be early engines only as was posted a bit ago.
  7. Steve-Race Engine
    Feb 25, 2004
    65
    Oceanside, Ca.
    Steve Demirjian
    Garloc makes Helicoflex sealing rings for this purpose. Catalog download is available at: http://www.helicoflex.com/catalogs/
  8. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,813
    The twilight zone
    They look way cool...any idea on price?
  9. 246tasman
    246tasman Formula 3
    Jun 21, 2007
    1,448
    Will Tomkins
    Great resource, thanks.
  10. davehelms
    davehelms F1 Rookie
    Jan 3, 2004
    4,629
    Dave Helms
    Good source Steve. Not the brand I remember but the O-Flex series has both types I refered to.
    Steve's source looks far better than the one I dealt with as his has very good data and specs.
    Dave
  11. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,813
    The twilight zone
    #486 mk e, Dec 23, 2007
    I hit the timing cover quickly with the die grinder so I could put it on and have a look at thinks. I’m thinking the TR cam cover would look better if I cut the side off that was the oil return on the TR…it looks like an appendage to me. I have to work on the cover any way since it needs a flange to seal to the timing cover and it need a “ferrari” script put on since it’s on top of the engine now. I’m also thinking I’m going to narrow up the timing cover a bit. The 2 changes together should make the finished engine look smaller and also help further confuse anyone who thinks they know what they’re looking at when they see it ;)
    These cams need to be cut at the seal flange and then have the flange machined to accept the timing sprocket. It looks like I'll need rework the sprocket too becasue there isn't enough meat on the seal flang for me to cut deep enough to get the sprocket in line. The fun just keeps coming.
    I'm going to move on to the second head I guess before I go to work on the timing cover. That one is harder becasue it looks very much like I'll cut into the water jackt if I just mill it like I did the first head. Maybe a little off the head, and then a knotch in the timing cover....I could just mill the head and weld a plate in to re-seal it, but I'd rather not do that much weling on the head if I can find another option.
  12. GrigioGuy
    GrigioGuy Splenda Daddy
    Nov 26, 2001
    33,430
    E ' ' '/ F
    Enzo Gorlomi
    Are those the 400 cams, or have you put the gears on the TR cams somehow?
  13. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,813
    The twilight zone
    TR cams, the 400 sprockets are just sitting there....the sprockets have a bore about 1mm bigger than the TR cams so they go on but flop around.
  14. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,813
    The twilight zone
    #489 mk e, Dec 23, 2007
    I cut the second head and rough cut the back out of the timing cover to get it on.
    I’m thinking I’m going to make the 2 little top covers for the timing cover part of the cam cover for a couple reasons. 1st is then I don’t need to fix the big hole in the front of the 2nd head and 2nd because it will make it much easier to keep the width of the 2 covers the same in spite of 1 head sticking out 5mm farther than the other.
    I think that’s it for today….it’s starting to at least look a bit like it could be an engine some day now.
  15. buzzm2005
    buzzm2005 Formula 3
    Aug 23, 2005
    1,739
    NYC
    Buzz
    Looking at the second pic makes me cringe. I watched in shock and awe as you fearlessly went into the block armed with nothing more than a welding rig and extraordinary courage, but the mismatch in size between the cam cover and cam guides looks daunting. Can you share your strategy here? Perhaps I missed a post on this.
  16. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,813
    The twilight zone
    #491 mk e, Dec 23, 2007
    The plan is actually quite simple, cut out what’s there now with the holes all in the wrong places and weld in new metal so I can put the holes where I want them. This is the easy part really and most of the work I’m going to be doing over the next few days will be more cosmetic than anything else. I want to get it looking like the parts were all made to be together and not an afterthought…..and that will mean changing the shape of the top part of the timing cover, shortening the 2 top covers to match and attaching them to the cam covers. None of it’s very hard, it just takes a bit of time.
    I started some of the sawing tonight (got bored with TV). I knocked off some mounts I don’t need, I still need to clean them up on the mill, but it was faster to saw than to mill the whole way. Also, here’s a picture of the hole I installed in the back of the timing cover to clear the head, it needs a piece of plate welded in now.
    The last pic is where I was looking at the water situation. The 400 heads were fed by the 2 round holes in the back of the timing cover that flowed into the front of the heads. The big feed on top, just goes into the cover and then out the 2 hole into the heads. The TR heads have feeds in the middle for more even distribution so the 400 set-up isn’t much use. I’m going to just cut that hole section right out of the timing cover and run a coolant manifold/tube from the connections on the head straight out the front of the engine….of maybe straight out the back and run the oil lines in/out the front, I need to think about that, but either way I’m cutting that section out of the timing cover.
  17. Steve-Race Engine
    Feb 25, 2004
    65
    Oceanside, Ca.
    Steve Demirjian
    The only ones I have used are the ones that Cometic sells with their Phuzion gaskets. They should be somewhere around $50 each depending on size.
  18. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,813
    The twilight zone
    Thanks.
  19. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,813
    The twilight zone
    #494 mk e, Dec 24, 2007
  20. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,813
    The twilight zone
    #495 mk e, Dec 24, 2007
    I picked a shape for the cover, cut it out and test fit it. I think it will look pretty good….but first I have to fill all the holes I made and move the cut-outs for the cams and that means it needs the Frankenstein treatment. Once it’s machined no one will ever know it was ever this ugly.
    I have to decide how I’m going to finish it too. I can't leave it as a bare casting because it’s a pretty rough part but the machined areas are smooth so they stand right out. Wrinkle paint is the easiest I guess because it hides almost anything. It would need a quick sand but that should be about it....but I don't know if it would look right. It would probably look nice if I sand the whole thing to a satin polish similar to the original QV timing covers…..that seems like a lot of work though and the weld and plate area may be a slightly different color. I'll need to think about that.
  21. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,813
    The twilight zone
    #496 mk e, Dec 25, 2007
    There's 1 corner fixed, 3 to go.
    The bores are still small for now, I want the back cut large enough to be able to pull the cover without pulling the cams and the front bore needs to be finished with cover in place so the plug will seal properly.
    Also, I need to cut some kind of pattern in so it doesn't look like I welded a plate in. After I rough in the second side, I'll decide what I think might look nice to add some shape.
  22. jimangle
    jimangle F1 Rookie
    Nov 5, 2003
    2,506
    Haverford
    James
    Mike,
    Great work! I have to see this thing when it's finished.
    Jim
  23. 2000YELLOW360
    2000YELLOW360 F1 World Champ
    Jun 5, 2001
    19,800
    Art
    Having built a few motors, some very, very custom, I'm amazed at the speed that Mark is going on this. Absolutely amazed. BTW: was reading an old post by Mark and see that he used Jerry Branch for his porting. Interesting, I used Kenny Augustine, who claimed to have been better, but then again, I never beat Cook Neilson's duck, and Branch did those heads.
    Art
  24. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    Blasting with a coarse media might give the machined areas a finish that matches the sand cast finish.
    Hmm, alternator rebuilders tumble clean the cases, everything ends up a a uniform finish. Looks like a sand casting, but also would be a good base for either powder coating or wrinkle. But you'd need to fasten something over the surfaces you want kept machined smooth...
  25. buzzm2005
    buzzm2005 Formula 3
    Aug 23, 2005
    1,739
    NYC
    Buzz
    Ahhhh.... I get it now. You just cut out the metal around the semicircle, weld in a new piece of bulk metal, and recut the semicircle to match the dimensions of the heads. I like the black Sharpie line on the left side that shows where the companion cut will be made.
