308 V12 conversion begins | Page 28 | FerrariChat
Discussion in '308/328' started by mk e, Oct 9, 2007.
Thread Status:
Not open for further replies.
  1. D.Mauro
    D.Mauro Formula 3
    Jun 18, 2006
    1,266
    Cumming/ Hlwd Fl
    Dominick
    Chris is doing research at Cavallino!!
  2. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,813
    The twilight zone
  3. RVIDRCI
    RVIDRCI Formula 3
    Dec 1, 2005
    1,576
    Long Beach / Phoenix
    Luigi
    That is an awesome sight, my freind. But, whoa, I thought my SC clearence issues were tight !!! Looks to me like fuel tank mods will def be needed. Have you considered a spare tire well fuel cell, just to open up some space? Not to mention the CG plus to offset for the slightly heavier V12.
  4. Hans
    Hans F1 Veteran
    Feb 17, 2006
    7,734
    Hilversum, Netherlands
    Hans Teijgeler
    Like it was designed by Enzo himself... :D
    Maybe if you try to add some of your in-law's Wodka to the little one's milk, the naps will be XXXX-long, leaving you more time for this project? ;)
  5. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,813
    The twilight zone
    Thanks.
    There's nothing like making the engine 8" or 10" inches longer to eat up engine bay room. There is a little over 1" of clearance to the gas tank on the passenger side, so that's ok I think. I'm not sure yet on the drivers side with the bell housing and drop gears, I'll have a look at that tonight.
    I'm a little worried about where the heck am I going to run the front header out. May up where there is a notch in the gas tank where the AC compressor was??? Maybe over the bell housing? Maybe both :)
    I'm honesty not concerned about the change to the CG with the new engine. It's no heavier than the V8 with the supercharger was, it fact I think it's lighter and I know the weight sits a lower particularly since I just lowered crankshaft about 2.5". Moving the engine 3” forward can hurt either. I don’t think I’ll have to move the fuel tanks.
  6. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,813
    The twilight zone
    Oh man, I am so glad Lana NEVER looks at f-chat. You guys would have me in SOOOO much trouble......
  7. Hans
    Hans F1 Veteran
    Feb 17, 2006
    7,734
    Hans Teijgeler
    Maybe you'll have to do BOTH: keep the old tanks AND put one in the front. At your aim of 600 hp, it will not exactly sip fuel..... :D
  8. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,813
    The twilight zone
    I figure 15 to maybe 20 minutes at full throttle and the tanks will be dry.
  9. luckydynes
    luckydynes F1 Rookie
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    Just a thought and I started a thread about it . .. saw an F1 motor that was running the flow the opposite way thru the heads i.e. exhaust was intake and intake was exhaust . .. I know you're trying to keep a somewhat factory appearance though :).
    Sean
  10. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,813
    The twilight zone
    Yeah, I want this to look stock even to a trainer observer.
    It was a popular mod on the old Triumph motorcycles because the intake ports were way too small and the exhaust ports way too big. The solution was to mount the head on the engine backwards.
    I had that thought for the 400 heads to get the intakes into the V by mounting the heads backwards, but decided it wouldn't help and it would cause a lot of problems. Most any head designed in the last 30 years has intake ports that are higher and straighter than the exhaust ports. The intake valves are much bigger than the exhaust valves and there's not enough metal to open up the exhaust valves to an appropriate size. The intake ports don’t normally have adequate cooling to deal with the heat of the exhaust flow. Problems like that.
    If an F1 car is doing it (I think there was an old Ferrari that did it too) they would have a casting designed for it. They most likely also figure that the aerodynamic packaging is improved enough to compensate for reduced hp flowing up hill into the cylinder would cause.
  11. Hans
    Hans F1 Veteran
    Feb 17, 2006
    7,734
    Hans Teijgeler
    My god man, do you have a death wish????
    I did 2 minutes of full throttle last Sunday and found myself doing 165 mph in my Dino (7800 rpm in 5th). Now that is with a bone-stock weber-fed 308 engine. I don't even want to think about how fast you'll be going full throttle with 600 prancing horses on tap!!!!
    :D
    (go for it!!!!)
  12. GTHill
    GTHill F1 World Champ
    Jul 1, 2006
    14,054
    Double Wide
    GT Hill
    If I had one complaint about my 328, it would be the transverse engine orientation. I know that mounting the engine longitudinally has been mentioned, but what about the use of a "reverser"? Ok, that isn't the best name for it, but it seems like I remember reading about a gearbox that changes the direction of the power for boats. Ok, I know its a bad idea or you would have already thought about it, I'm just curious as to its feasibility. Thanks!
    Gene
    P.S. I'm still upset that I didn't get the answer to your IQ question.
  13. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,813
    The twilight zone
    Like a Vee drive? I hadn't thought of it, but I guess in theory it's possible. The TR trans kind of does that, I suppose you could put a v engine on that if you wanted…or just use the TR engine and save having to do any custom work except a little frame clean-up to get it in.
    I don’t really have any preference for which way the engine gets mounted. It’s easier to make the frame strong I think with a longitudinal mount, and in the case of the 12 cylinder, easier to sit the engine low in the chassis but thoughs are the only things that come to mind. Transverse should be better for acceleration as the reaction loads to the engine torque distribute the load evenly to both rear tires and traction out of a right hand turn is the same as a left hand for the same reason. I think it’s all about packaging.
    Don’t worry about the other question, the average person doesn’t get any part of it right and I have no idea how long it was told before it came to me and got the south pole part added to the answer. It’s any thing but obvious and you're the only one that even tried.
  14. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,813
    The twilight zone
    #689 mk e, Jan 29, 2008
    The good news is the passenger side looks pretty good and there should be 1/2" clearance to the frame when it's all done.
    The drivers side....well it is a tad tight to the gas tank. I think it will go will a little bit of work on the bell housing that I was planning to do anyway....if not as Hans pointed out 15 minutes of gas is probably way too much anyway so no harm reworking the tank for the required clearance.
  15. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    I'm so glad I'm not the only one juggling little kids with Ferrari garage time. Mark, take my advice on this one. Stop at one kid!! You will never get SQUAT done if you have another!!
    Birdman
  16. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,813
    The twilight zone
    Lana always had a plan for 2, but I'm pretty sure one has cured her of that. We love him, but the Chinese have it right, one is enough. Now we just need to get the rest of the world on board and there will not only be time for the Ferrari but there will still be gas available when I finally finish the thing :)
  17. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    Mark,
    The trouble is that when your son is about 3 and he is really fun and not too much work, you will have complete amnesia about what a pain in the ass babies are. Lana will also have complete amnesia about how much labor hurt. Then she will suggest another!!
    I also hate to break it to you, but at 8 months, he's not easy, but he's also as difficult as he will be soon. Wait until 18 months. The time between learning to walk and having a good grasp of speech (roughly 10 months-20 months) is the most work IMHO because he is mobile, clueless of danger and has no fear. You can't take your eyes off of him except when he is imprisoned in the crib for basically a year.
    Jonathan
  18. Mbutner
    Mbutner Formula 3
    Aug 11, 2005
    1,689
    Bay Area / Washington DC
    Quick Draw
    This is a hilarious view of child rearing. I totally agree!!
  19. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,813
    The twilight zone
    Don't be like that man......he actually just graduated to jail this past weekend. Not quite walking yet, but crawling surprisingly fast, standing and walking while holding the wall, sofa and such then falling and screaming.....and clearly understanding "NO" only means "NO" if you are within arms length of him. Lana came home Saturday with a big playpen to lock him up in.
  20. atlantaman
    atlantaman Formula 3
    Mar 31, 2002
    1,726
    Roswell, Georgia
    Charles
    Mark--interesting problem with the water pump. on my 330 block it is higher on side and i have to cut a section out of the gas tank. how much room do you have on top without hitting deck lid? what is you put 1/2 inch spacers under motor mounts to raise it just a tad?
  21. Hans
    Hans F1 Veteran
    Feb 17, 2006
    7,734
    Hans Teijgeler
    +1!!!!
    My boy is 5 now, and still quite the hand full. But not like he was during those 10 to 20 months :D
  22. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,813
    The twilight zone
    The picture doesn't show it that well, it's really hard to take a picture the shows what you can see looking at it, something always seems to be lost.
    I think I'm OK with the water/oil pump. It clears the gas tank by over an inch. I was a little concerned about frame clearancefor the oil pan, but I think I'm ok there too. On the stock 400 pan there is about a 1/4" step up right behind the flange and if I build mine the same way I get about 1/2 clearance to the frame.
    What's been going through my mind is actuall sliding the engine another 1/2" to the right to make more room for the bell housing. I still have to add flanges on both ends or the rails I just made, so a small shift wouldn't add any work I don't think. I'll have a look at the tonight.
  23. GrigioGuy
    GrigioGuy Splenda Daddy
    Nov 26, 2001
    33,429
    E ' ' '/ F
    Enzo Gorlomi
    Again, I'm clueless and you've certainly already considered this, but will the difference between the longitudinal stock positioning and the transverse position it's in now change your oil pan needs? The 308 is known for oil starvation in turns.
  24. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,813
    The twilight zone
    Yes the pan need to be different. With the extra length the oil starvation issue should get much worse so I will be converting to a dry sump.
    In frame clearance problem area the only purpose a step in the pan could serve is to trap a little oil near the chain, and I would still need that so just copying or even slightly increasing the step should be a good thing....I think.....
  25. Interestedbystander
    Dec 16, 2007
    2
    Mark,
    Please note that subsequent children also often turn out well.
    Dad
