308 V12 conversion begins | Page 33 | FerrariChat
Discussion in '308/328' started by mk e, Oct 9, 2007.
Thread Status:
Not open for further replies.
  1. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,794
    The twilight zone
    I was mid 90s and a couple teams were doing that them.....foolishness. We hit F1 stiffness to weight ratios with a steel space frame for a fraction the cost and effort. F1 needs the aerodynamics which requires flowing shapes that you can only really do in composite and add in the safety requirements of a 200+ mph car and you need carbon fiber. Formula SAE is a 60 mph game were aerodynamics are nearly irrelevant…....but you can’t tell college kids that.
  2. Pizzaman Chris
    Pizzaman Chris F1 Rookie
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    Mark, i would but i'm all tapped out. Tapped out i tell you!:)
  3. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,794
    The twilight zone
    It is huge. I've done a few ECU installs over the years, but honestly it has to pretty straight froward for me to handle. I was thinking a haltech E11 for $1500 plug 6 ignition modules would be about $2000K. The VEMS ecu is something like $700 and has the ignition drivers built in but it's not well documented enough (yet) for me to feel good about doing the install, but with Jason's help it should be good.
  4. Tiger_Carrera
    Tiger_Carrera Rookie
    Jun 15, 2005
    42
    Gatineau, Quebec
    Gary Corbett
    Mark - I'm sure you've got this detail covered, but I'm curious to ask since I don't know that much about the different V12 engine families. Is the firing order the same for the 400 engine as it is for the Testarossa? If not you'd need to do something with the cams to get the valves opening and closing properly relative to the pistons. I'm just reliving some bad memories from many years ago. Fantastic project - a compliment from one engineer to another.
    Gary
  5. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,794
    The twilight zone
    #805 mk e, Feb 17, 2008
    You know, until you asked I ASSUMED they were the same......but looking at the cams clearly they are not and the TR cam are not compatible with the 400 crank.
    On the bright side I wanted to have the cams re-ground for hp but wasn't sure I wanted to spent the money, now I don't need to agonize over the decision
  6. 2dinos
    2dinos F1 Rookie
    Jan 13, 2007
    3,060
    This is the greatest thread I've ever read. I wonder if the Ferrari factory will take notice and appreciate this. I recall the single cam V-12 that was put in a 308 years ago triggered some positive response. Wasn't the response by Enzo himself? Good luck, and please keep the pix coming.
  7. Far Out
    Far Out F1 Veteran
    Feb 18, 2007
    9,768
    Stuttgart, Germany
    Florian
    We had a steel frame in our first car, too, but with the monocoque we were able to halve our chassis weight, compared to the lightest steel frame car... it's pretty crazy when you can hold up the body of a whole car with two hands! Anyway, don't want to hijack your thread. Keep your great work going! :)
  8. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,794
    The twilight zone
    Our final steel frame weighted under 30 lb and included the engine and suspension mounts (no additional sub frames or brackets of any kind required) as well as the seat frame work, meet all the roll and impact requirements and had a 3500 ft-lb/degree torsional stiffness between the F/R axles. The body that went on was under 10 lb and met the energy absorbtion requirements. So at 40 lbs, it only took 1 hand to hold it up ;)
  9. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    Are you sure the firing order is actually different? It looks to me (and it hard to tell in the pictures) that the right side lobes are pointing the same direction and the rest of the lobes are all 180* out. That leads me to the question - do the cams turn opposite directions and the firing order is the same? I'm not sure that it matters to your project, just curious.
    Edit - oops nevermind. #4 is definately not 180* apart.
  10. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,794
    The twilight zone
    Yeah, 1 and 6 are good, but 2-5 appear to be out 120*......not a useful number. So really I only need to get the lobes on 8 cylinders fixed.
    In theory I might be able to put a TR crank in the 400 block instead of fixing the cams.....but I hate to buy one then have to jump through a bunch more hoops because of it. I did want to have the intake cams welded up anyway to add some more lift, I just hate to spend the money but now it looks like I have to....but it will add $4k-$6k to the project.
  11. Spasso
    Spasso F1 World Champ
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    You are headed in the right direction. Changing the crank is just a solution to a timing problem, changing and improving the cams is accomplishing two important things, tune compatibility for the NEW bore and stroke and the resulting HP increase. Yup, 4 to 6k well spent....................
  12. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,794
    The twilight zone
    Yeah...it will make more hp, no question. I need cams if I expect to hit the 600 number.
  13. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,794
    The twilight zone
    #813 mk e, Feb 17, 2008
    I realized`today while machining the right end face that the 3 original studs across the top went all the`way thru the case and would need to be welded. I got them ready and did a little sanding on some of the welds on the new pan. It looks like it will clean up pretty well the a quick sand blast over the whole case to match the finishes and no one will ever know its been worked on.
  14. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    This thing is really going to be an art-piece when you're done. It'll be a shame to hide it in an old 308.
  15. jimshadow
    jimshadow F1 Veteran
    Feb 19, 2006
    6,257
    Indiana/North Carolina
    JIM
    If you want to have a LOT of fun, stuff it in a GT4! :)
    JIM
  16. Spasso
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    That will be the last time a person looks down their nose at a Dino!
  17. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,794
    The twilight zone
    If everything goes to plan there will be nothing on the outside of the old 308 to clue anyone about what's hiding inside. All the edmounds reads that are expecting their mini vans to out run it will be in for a surprise. With the old engine the whine from the blower let them know they'd been had, but this one this one should leave them wondering.....if it ever gets finished and in the car that is, I don't think I'm even at the 1/2 way point yet.
  18. istanl
    istanl Formula Junior
    Apr 30, 2004
    662
    Melbourne, Australia
    Ian
    Amazing project! I can't believe you can make that much power from an NA 400i engine. All about the breathing eh. God knows what a 550/575 engine would be capable of.
  19. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,794
    The twilight zone
    Thanks.
    It's all about getting air in and the TR heads are going to be a big help. I've got a feeling it will still need to spin over 8000 to make 600 hp and that means new rods I guess....I was hoping to avoid that expense as well.
    I think I'm going to have a look at what it would take to make a set of billet blanks for the cams. It would make better cams and would also let me design the nose to accept the 400 timing drive with no adapting. It might be the way to go.
  20. jwa
    jwa Karting
    Feb 23, 2003
    108
    Enschede
    So you'll be changing back to the 390 wheels than? :D
  21. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,794
    The twilight zone
    It came with 16s ;)
    I keep eying GTO wheels to go with the GTO valance, but I like the 550 wheels and wheels would never lead anyone to suspect they come with an extra 400 hp.
  22. pincusa
    pincusa Rookie
    Dec 4, 2007
    3
    NY
    Aaron
    I was thinking. I've known Mark since 1996 (WOW!), and have watched the projects getting bigger and bigger with more and more HP. And for me, it's amazing just how UN-shocking this project is. Just seems like a natural progression. Much like the time I showed up at his house to see a crashed airplane in the driveway. When asked what he was going to do with it, "Fix it up and fly around the property." "But Mark, do you know how to fly?" "No, but really the only hard part should be landing!"
    So I'm just worried about what the next project is. And do not believe him when he says this is the last project! I've heard that a few times already!!!
    -Aaron
    PS Looks great Mark! Hope to come down for a visit soon! May send the wives off with Victor for an afternoon.
  23. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,794
    The twilight zone
    I found a TR crank today for $1000, the guy is sending me pictures of the flywheel and damper ends along with journal diameters so I can decide if it will fit the block or not.
    As a bonus I got the name of another camshaft place, American Custom Cam Grinding, who told me if I send them blanks off the lathe, they will grind the journals, give me any lobe I want and heat treat them for about $1500 for all 4 cams. I’ll have to buy the material and pay to have them gun drilled, so about $500 for the blanks making the total $2000 instead of the $6000 I expected. This is probably the way I’m going to go, but I want to see the pictures of the crank before I make any final decision.
    I also finally broke down and ordered 1 348 liner to measure and make sure I can get it in the block before I buy the other 11.
  24. jimshadow
    Feb 19, 2006
    6,257
    JIM
    Why am I not surprised? :) :) :) (I'll bet nobody is...LOL!)
    JIM
  25. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    It seems to me that a TR crank (even if it dropped right in) would be a problem because of the angle difference between the flat vs Vee style block. I think that using the stock crank that came with the block and making up cams with the same lobe configurations as the cams that went with the block would have the least R&D associated with it. Then you are left with lift & duration choices. This should keep you busy a while.
