308 V12 conversion begins | Page 39 | FerrariChat
Discussion in '308/328' started by mk e, Oct 9, 2007.
Thread Status:
Not open for further replies.
  1. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,813
    The twilight zone
    Yes, exactly. It would be a pretty easy mill job that way.
    The right angle head would just let me cut from the side instead of the top, so it wouldn't really add anything I don't think....I'll probably use it to put the center drill in the end and drill the hole pattern for the sprocket though.
  2. Hans
    Hans F1 Veteran
    Feb 17, 2006
    7,734
    Hilversum, Netherlands
    Hans Teijgeler
    For crying out loud man, don't you know when to stop?
    You're about to mill your own cams????
    Compared to your FrankenEngine, that TR with turbine project really is childs play....
    My hat's off to you!
    Hans
  3. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,813
    The twilight zone
    no, no, no I'm not milling cams, that would be crazy ;)
    I wanted new cams to make hp but didn't want to spend the money until I realized that I need new cams because the firing order on the TR cams doesn’t match the 400 crank unless I somehow reverse the rotation direction of the cam.
    The cam company wasn’t interesting in making the entire lobe out of weld (they’re much smarter than me), so I need to make billet blanks for them. The blank just has a diameter where the lobes go and is +.020 oversize in all the journals. The cam company will harden it, grind the journals, and grind whatever lobe I ask for.
    One of the heads in particular has some scoring in the in the first journal (the drive end) so I will probably clean it up oversize and make the cam to match. I’m also thinking about changing the spacing between the intake valves a little to flow better with bigger valves that will now fit in my bigger bore….it’s a viscous cycle.
  4. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    Cams are easy to make ... not that I have made them personally, but I have found a little engineering shop many years ago and they quickly made a couple of cam blanks for me with just lumps where the lobes were/are. Then off to the camgrinder for final profile/hardening, etc.
    Didn't cost much at all ... I do remember hand drilling a hole in them when they came back for something ...
    Pete
  5. KKRace
    KKRace Formula 3
    Aug 6, 2007
    1,052
    Rockville/Olney MD
    Kevin
    Any chance of flipping the old ones end over end and machining it to except the cam gear somehow? Would swapping them side to side help? I'm not sure if both timing chains go the same direction on the TR?
  6. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,813
    The twilight zone
    You can't swap side to side becasue ever cam in the engine looks the same, but starts in a different timing position, they have to be becasue there is only one crank.
    If I could flip them end to end it would solve the problem, but I can't because the bearing journals are not symetric about the cam lobes.
    If I had to save the cams I could put the lower chain sprocket directly on the crank instead of thru the gear drive cauing the cams to turn the opposite direction and solving the time problem.....but that's a lot of bother to keep cams I never really liked anyway.
    New cams are the answer. It's not going to be a ton of money and will pay big returns in hp.
  7. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,813
    The twilight zone
    Exactly. I'll start making the blanks in a couple weeks it looks like.
  8. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,813
    The twilight zone
    Tonight I got the bushing holes in the block re-cut. I had to go .020" oversize to get it to work out right. The next time I get into the shop I'll re-cut the caps the same way and make the new bushings then this problem is fixed and on to the next.
  9. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,813
    The twilight zone
    I just had another (crazy) thought. If I took the 24 37mm 400 bucket out of the 400 heads and put them in the 24 intake side 33mm hole in the TR head I could move the valves up to 4mm farther apart. That is coincidentally the same 4mm I lose if I replace the 29mm valves it has with the 33mm valves I think I want.......hmmmmmmm
  10. Spasso
    Spasso F1 World Champ
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    You know Mark,
    You remind me of a few engineers here at work, "Taking something simple........... (putting TR heads on a 400 block) and complicating the HELL out of it!".................... (changing the spacing and size of the valves).
    I understand why you are doing it, you have to utilize and maximize every aspect of this engine if you are going to reach your 600 HP mark.
    Astounding!:):)
    Keep good records and pictures, that way when you are done with it (IF you are ever done) you can write a book about it. I'll buy one.
  11. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,813
    The twilight zone
    Now I haven't decided anything about it just yet, it's still a hypothetical with plusses and minuses to think about.
    In the Plus column I think we have:
    A bigger diameter will tolerate a higher lift cam
    Moving the valves should improve the flow with big valves
    I have them so they’re free
    In the minus column:
    They add weight to the valve train
    3-4mm is a LOT of over sizing the bucket, the valve guide, valve seat, and port holes in the head…. I’d be a little worried about wall thickness remaining.
    It’s time consuming. Not just the actually moving everything but also all the port design work to go with it.
    I’ll need to decide exactly what I’m doing with the head before I can even start the cams blanks
  12. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,813
    The twilight zone
    The more I think about it, then more I like the idea of separating the intake valves and running bigger buckets. I've now convinced myself that +2mm would still work with the 37mm buckets while not causing as much wall thickness concern, although there it's still a concern.
    I would love to have a TR head I could saw opened and see how much metal there is where.......I want them to flow good but I don't want to find the water jackets in the process.
    I sent the cam guy an email explaining what I've got and asking for recommendations for what we can do that will live on the street. My computer thinks around 235*-240* at .050” lift is about ideal but that I also want .420”-.450” lift for the intake lift and I’m not sure those 2 numbers work together, at least not for very long. The bigger buckets will help some……I’ll see what he comes back with but I’m guessing I’ll need to take more duration on the intake side at least. I'm not too worried about the exhaust side as I think the stock TR intake grind of .348" lift with 222* at .050" lift which clearly works since it's stock is about the right lift and adding duration doesn't make it any harder on the valve train.
    It’s really a little early to be picking cams but I need to make cams to finish the timing chain fitting so I don’t have a choice. I’ll most likely err toward the aggressive side because it’s way easier and cheaper to have metal ground off then it is to have to weld it back on.
    I also asked the cam guy about the shim under vs shim over. I have the shim over buckets and would like not to have to replace them if I don’t have to for both cost and ease of maintenance reasons….but now would be the time if I need to.
  13. 2000YELLOW360
    2000YELLOW360 F1 World Champ
    Jun 5, 2001
    19,800
    Art
    Who's grinding the cam? I used Megacycle in San Rafael, when we were making them up for the Ducatis. Jim Deour (sp?) is the owner there, and is willing to undertake quite a bit of experimental work.
    Art
  14. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,813
    The twilight zone
    I'm talking to American custom cam
    http://www.americancustomcam.com/
    They were recomended by the shop I bought the head and engine from as doing good work and the prices seem really good. They quoted about $1500 to finish to the blanks (heat treat, journals, lobes) which is about 1/3 what webcam would charge. They said they had about 3000 masters to choose from
  15. Spasso
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    I wouldn't be too afraid of increasing duration, just don't go too long on the overlap or you will loose bottom end and drivability.
    Learned that one the hard way.
  16. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,813
    The twilight zone
    It's hard to add duration without adding overlap though.
    The intake and exhaust are separate cams and can be timed any way I please so I don't need to decide that up front, but it just always seems to turn out that the balance is a good thing. By balance I mean the same or nearly the same lobe centers on the intake and exhaust. Something around 108 will probably make the best hp but around 110 for best overall and 112 or so for the best low end. Then the overlap is what it is based on the duration of the cams.
    This will be an EFI engine so it is much less sensitive to then it would be with webers which are kind of primitive carbs really. I think I could go to 260* or even 270* duration at .050” lift and still have it be perfectly drivable since the engine is plenty big now….but it just won’t be quite as nice. The longer the duration the high the torque peak moves but the hp peak will be flow limited by the heads so it will hit an rpm wall and the power band will just get narrower and narrower as duration goes up.
    I’ve got a bike with similar bore/stroke (2v though) and 270 at .050” duration on both intake and exhaust and it pulls hard from about 1200 rpm and idles at around 800, torque peak around 6500 and the hp peak at 8500 limited by the slightly too small carbs. That is pretty much the engine I’d like this to be I think so taking the 2v vs 4v thing into account and the relative valve area I’d guess I’m talking about 255-260* at .050” to be a comparable cam for this engine.
    We’ll see what the cam guys feel good about making and go from there….it’ll all work out in the end I’m sure.
  17. Spasso
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    So true. It's question of compromise.
    I have a 375 HP 5.7 liter with a 270* cam using 110* separation IIRC. I am running an ancient 650 cfm carb on it. A little bit of a lump at idle but still has good torque down low. The power drops off around 5800 RPM but then that could be because of the heads I'm running and tune.
  18. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,813
    The twilight zone
    Is that 270* total? That would be around 230-240 maybe at .050" lift. The 270* at .050 cams I have in the bike are about 310 total degrees.
    The word I'm get from he who knows (Dave Helms) is that I really need to move to shim under buckets if I want anything like reliability at 8500 rpm so I guess that will be on the list too.
  19. atlantaman
    atlantaman Formula 3
    Mar 31, 2002
    1,726
    Roswell, Georgia
    Charles
    My V-12-308 motor has been sitting for 3.5 yrs now in the garage stalled at the rebuild point.
    Where to start is my issue.
    block first? heads first?
    After long deliberation, I resolved that the cams should be first, then rocker/rollers, then heads, and lastly new pistons to match the heads. I have 12 new titanium connecting rods from a BBLM and a set of new piston, but need another set now. I made the mistake of ordering a set of venolias 15 yrs ago for this project that are now useless to me ( ebay baby!).
    Anyway, to start this rebuild the cams come first, and there I hit the roadblock. In the last few years there has been soo much negative stuff coming out in chatrooms on Elgin, Webcam and others that I was afraid to make a move. And even though I am an engineer and do a ton of car and machineshop design work( including all of my v-12-308), camshaft profiles is a gray area with me that I have never studied, and confess that I look at a camshaft like it speaks Russian and it is not meant for me to understand. Obviously the principals are easy, but I need to change these 330 cams to a better grind for performance but just how much additional lift and to what durations is something that just gives me a headache. Originally I was planning on shipping them off to Elgin since they were known for a lot of Ferrari custom work, but now I have killed that idea.
    I really need to find a solid cam expert to discuss this with and do more research on 330 race cams. Maybe the p3/4 had better cams that I could copy the profiles??
  20. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,523
    Canada
    Newman
    What stories have you heard about WEB? Ive heard a few things about elgin myself as well. As for profiles couldnt you look to a 250GTO or a 330LM/TRI for inspiration? Nostaligic in sound and the specs should be available to simply duplicate.
  21. 2000YELLOW360
    Jun 5, 2001
    19,800
    Art
    Jim Doeur at Megacycle Cams in San Rafael California. Builds primarily motorcycle cams, but has built cams for just about everything.
    Art
  22. regisgtb4
    regisgtb4 Formula Junior
    463
    tx
    willis
    I put Alfa P6 type grind cams in 2 330GTCs that I had yrs ago.They had a Maserati Mistral type power shelf @ 3700 rpm. Isky welded and reground the stockers.I also put 365GT2+2 dfi larger carbs on them.I found that the big carbs with stock cams was best,the hot cams burned more feul and was fun to run to redline but not more than a couple of tenths faster.Stripping the GTCs of all excess weight gave the best return when all was said and done. The hot cams were also rough on the roller rockers and screws and required too much attention. All said the Car wasnt faster,was alittle more macho and zoomie and in the end that old proverb stood up "if you want a faster Ferrari,buy one". Thanks Mke
  23. Spasso
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    I built the engine in 1992 so it's old tech, hydraulic flat tappet, for an early 70's Chev 350.. It's 270* total, both sides (advertised).
    It was made by Com cams, http://www.compcams.com/DefaultWide.asp
    They currently post the durations of their cams @.050" on the website and shows duration for the same cam considerably less than 270*
    I DO remember that the cam was designed to produce power up to 5500 RPM so it wasn't that radical
  24. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,813
    The twilight zone
    #974 mk e, Mar 9, 2008
    The first cap fits again and looks pretty good if I do say so myself :)
    6 more to go.
    I've been talking to Dave Helms about the buckets. He's been working very hard to find an affordable solution to the shim under conversion and I'm confident something will turn up. If I'm only moving the intakes 2mm I could go to a 35mm bucket instead of 37 and I think I've found one but I need to get pricing to see if it's a viable option.
  25. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,813
    The twilight zone
    There are lots of option and really no "right" answer but a lot of wrong ones. The cam place I'm going to go with is american custom cam, I should be doing that in a month or 2 so I can let you know how it went. Over the phone they sounded quite knowledgeable.
    Going straight to the cam grinder may not be the best plan. You might give Dave Helms a call or PM, I've been very impressed with his knowledge and connections and I guess he’s worked on plenty of SOHC engines over the years. Carobu is another place to try. Either place should be able to get you a cam source based on their experience that will meet your needs. In my case I feel pretty good about picking a cam I’ll like, but the I’m leaning on Dave quite a bit to help me sort out the buckets which I know nothing about.
