308 V12 conversion begins | Page 72 | FerrariChat
Discussion in '308/328' started by mk e, Oct 9, 2007.
Thread Status:
Not open for further replies.
  1. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,816
    The twilight zone
    #1776 mk e, Dec 4, 2008
    I decided I should shift gears a little tonight and do another test fit in the car before going any further with the bellhousing. Over all I guess it looks pretty good but there are a few areas of concern.
    The width of the thing without the bellhousing is just over the width of the opening in the engine bay, with the bellhousing it's about 3 inches over. I'll pull it with the bellhousing on and see how that goes....if I have to I could always install the bellhousing after dropping it in and before it's sitting down on the mounts.
    The flywheel to frame clearance I was so worried about is easily over 3/16", nothing to worry about there :)
    The drop gear case is well clear of the gas tank and the tire so that's good however it appears there may be a problem with the lower A-arm. I'll need to pull the spring and stroke the suspension and see what I have, I may need to alter the A-arm.
    The silly long damp only misses the tire by maybe 1/16" so that needs attention. I may make a whole new one with a fluid filled damper but it looks like just removing the outside pulley will solve the problem and I could also remove the inner most pulley and shorten the hub to get a little more room.
    I'm also back to pondering the drysump return pump location as it is clearly not going on the end of the crank. I've got a couple ideas.
    1. I could just live with it being belt driven and mount it to the side of the engine. I think this would be the easiest, but I don't love the way it would look, I don't like the belt, and I don't like how high I would have to mount it.
    2. I could probably pull the waterpump and stick the oil pump in its place. I'd have to belt drive the new water pump but that would be a v or serpentine belt, not a toothed belt like I'd need for the oil pump.
    3. I could make a way cool custom pump that arranges the pump gear sets radialy instead of axially….this one would fit neatly but it sure seems like a lot of bother.
  2. Hans
    Hans F1 Veteran
    Feb 17, 2006
    7,734
    Hilversum, Netherlands
    Hans Teijgeler
    Wow, looks great Mark!!!
    How about an electrical water pump? Even some OEM applications (like newer BMW's) have this.
  3. Protouring442
    Protouring442 F1 Veteran
    Sep 5, 2007
    8,723
    Harriman, TN
    One Stupid SOB
    Yes, and you're always taking the easy way out! = )
    Lookin' good!
    Shiny Side Up!
    Bill
  4. Protouring442
    Sep 5, 2007
    8,723
    Harriman, TN
    One Stupid SOB
    Perhaps a textured powdercoat? There are some other textured paints out there that might look more like a casting, though some research into their abilities to withstand the heat will be necessary.
    Shiny Side Up!
    Bill
  5. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,816
    The twilight zone
    #1780 mk e, Dec 5, 2008
    An electric water pump means a bigger alternator, but it's doable. I didn't realize anyone was running them as OEM....that makes in more appealing knowing someone has done the work to prove it works in all conditions like the mechanical pumps do.
    I took a few minutes tonight and held a 360 pump that's sitting here for the moment in place to see if there was room...and there is assuming it's the return pump only and I keep the original pressure pump because the whole pump is too long so that can be done.
    While looking at the waterpump spot it occured to me that I could also mount it right on the bottom and leave the water pump alone.....we might have a winner here.
  6. plym49
    plym49 Karting
    Aug 3, 2008
    61
    Harley has several types of engine case paint in rattle cans. Black with several different types of textures. Handles heat very well (you need this on these tractor motors), resists oil and grease, etc. Available from your local friendly Harley dealer or chopper shop.
    Harley dealers/bike shops use this paint to touch up the original factory coatings after a mishap. Saves a lot of labor breaking the bike down. Works well, blends in; this is a real nice product.
  7. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,816
    The twilight zone
    Today's thought is the ideal return pump is 3 stages to give me 1 pick up on each side of the sump and 1 in the timing cover since it's so far to the right and probably won't drain right in hard cornering. The 360 pump (which isn't mine anyway, although I can probably hunt one up) is 2 stage....but it fits pretty well. I like the idea of using the 3650 pump because I know I can alway get another one if it ever fails vs an after market thing that could be hard to find again. More to think about.
  8. wildegroot
    wildegroot Formula 3
    Nov 19, 2003
    1,522
    Frenchtown NJ
    Wil de Groot
    [/QUOTE] It all looks great Mark! In case you're interested, my 308 has two remote Meziere electric coolant pumps (one is a smaller unit for the intercooler system) and 3 Spal type electric fans up front (2 for the intercooler heat exchangers). The Ford, 100 amp, single wire alternator, which was fairly simple to adapt to the car, (and cheap) is not having any problems keeping the battery up.
    Wil
  9. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,816
    The twilight zone
    #1784 mk e, Dec 7, 2008
    Today's first task was to pick up the shop a bit....so 3 hours later I finally got some work done.
    The engine came out...barely. It will be a lot tighter with the heads on but I think it's possible.
    I hit the bellhousing with medium then fine scotchbrite and it looks pretty good I think.
    Then back to the bellhousing. I cut the housing down to make room for the flange and cut off the unneeded clutch lever boss off. Spent some time doing a little more bending on the flange, trimmed it and tacked it on. I want to double check the measurements before full welding it, maybe tomorrow.
  10. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    I'm starting to wonder if it would have been easier to simply design and cast your own bellhousing, etc. ... ?
    Atleast then you would not have to worry about surface finish :D
    Pete
  11. plym49
    plym49 Karting
    Aug 3, 2008
    61
    It looked like the bar stock you are using for the flange puckered when you shaped it. I was wondering how you were going to face it true. Did you face the side facing the engine before the step shown above, or will you face that side of it after you have welded it to the bellhousing, using the other side of the bellhousing to register it? I'm assuming that the bellhousing side of the flange does not need to be faced.
  12. 2dinos
    2dinos F1 Rookie
    Jan 13, 2007
    3,066
    My favorite thread ever! Are you planning to dyno this masterpiece before the final fitment in the car? Georgeous workmanship! I think the 308 is a tremendously beautiful car, and with engine you are setting up, she'll be the ultimate.
  13. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,816
    The twilight zone
    The flange did pucker and twist when I bent it. I think I've left it proud by about 1/8" (that's the main thing I want to confirm befroe I finish weld it) so there is plenty to cut off after welding to clean it up and also make it flat and square to the clutch shaft. The clutch shaft bearing is the only feature I'm not planning to remachine, the plan is to use that as ther reference and cut everything else to match it.
    I will probably do some cutter on the back side to to remove some extra material. I need the thickness for the bolts, but in between I don't and I plan on removing it.
  14. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,816
    The twilight zone
    Thanks.
    I will dyno it but probably not until it's in the car. Chassis dynos are much easier to find and set up on and I'd like to have time the break it in slowly, get it tuned well, and generally make sure everything is working right. Until dyno day the answer is "Oh it's well over 800 hp" :)
  15. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,816
    The twilight zone
    #1790 mk e, Dec 8, 2008
    Thanks.
    I'm thinking more and more replacing the stock oil pump with the dry sump pump then do what you did and put an electric water pump up front. There are a lot of options, I'm thinking something like this:
    http://www.hrpworld.com/index.cfm?tpc=EWP_Electric_Water_Pump_Kits&form_prod_id=747,587_3529&action=product
    with the optional electronic controler probably:
    http://www.hrpworld.com/index.cfm?form_prod_id=747,52,363_4363&action=product
  16. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,816
    The twilight zone
    I'm starting to wonder if buying a TR was the better answer :)
  17. Hans
    Hans F1 Veteran
    Feb 17, 2006
    7,734
    Hans Teijgeler
    No, it wouldn't have been. What would you have done to scratch that obvious itch you have??? ;)
  18. wildegroot
    Nov 19, 2003
    1,522
    Frenchtown NJ
    Wil de Groot
    Yeah, I looked at the Davies pump and controller too. It's a great idea having the thing pump on demand only but I chickened out and went for the simpler Meziere pump which is on at full speed all the time but an energy waster. I originally tried controlling the pump with the Electromotive ECU but it was too slow to react to temperature variations so now both pumps just run non stop (sitting next to the battery) and a standard Chevrolet 190*F thermostat (with a small hole drilled in it), in a remote housing but close to the engine, controls the temp. So far the set-up has been stone reliable. I also run waterless coolant and a big aluminum radiator with an efficient fan. Cooling is definitely not an issue.
    There is also an American made variable out-put pump with electronic control that I was looking at originally but the name escapes me at the moment.
    Wil
  19. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,816
    The twilight zone
    #1794 mk e, Dec 8, 2008
    I wasn't happy with the way the flange was sitting so I cut it off and repositioned it, much better this time. It's full welded now and seems good. The one picture shows the 1/8" gap caused by the flange sitting proud to allow me to machine the face to final position. Now I just need to fill up a few holes here and there and weld in a new boss for the idler gear that has to move about 3/16" becasuse of the gear swap then I'm ready to machine it.
    The flange looks a bit...well bad right now but I'm pretty sure that once I do the machine work and final clean up it will look like it belongs there.
  20. Etcetera
    Etcetera Two Time F1 World Champ
    24,319
    C6H14O5
    Wow, a year later and you are almost halfway there.
  21. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,816
    The twilight zone
    Tell me about it :(
  22. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    Can't wait to see this piece after machining. Personally, I want to see more strengthing ribs for strength and to make the bellhousing more intricate ;)
    Very clever ... you sir will never be bored!
    Pete
  23. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,816
    The twilight zone
    I hate dealing with ribs, they are a bugger to weld around and not burn away.
  24. randyleepublic
    randyleepublic Formula Junior
    Dec 2, 2007
    825
    Beautiful Reno
    Of course it was, but then you'd be bored ****less. :D
    (And so would we...)
  25. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,523
    Canada
    Newman
    Just the powertrain remember? :)
