308 V12 conversion begins | Page 74 | FerrariChat
Discussion in '308/328' started by mk e, Oct 9, 2007.
Thread Status:
Not open for further replies.
  1. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    You'll have to excuse me for not trusting you on this. Remember that's what you said about the TR heads that got you here!
    "Pretty easy" to one guy is not easy to another!!
  2. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,870
    The twilight zone
    I can understand but this is different. It looks there are only 2 issues, the pin/oil feed on the 360 is on the top of the head vs the bottom on the QV and the 360 has 3 oil rerturns vs 2 on the QV, everything else looks like a match.
    It's not a bolt on, but its not TR heads on a 400 either :)
  3. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,870
    The twilight zone
    Sure :D
  4. wildegroot
    wildegroot Formula 3
    Nov 19, 2003
    1,522
    Frenchtown NJ
    Wil de Groot
    Mark,
    The TIG torch is ready to be picked up by UPS today so you might get it tomorrow. It's a WP-125 if you want to look it up at arczone.com. The amp capacity is only 160 but it will weld inside 5/8" (16 mm) I.D. tubing. An extended wand version of the same torch is also available. I think you can do something useful in your ports with this one.
    Wil
  5. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,870
    The twilight zone
    Great. Now I won't be limited by flow to a lousy 750-770 hp :p
  6. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,870
    The twilight zone
    The trans gear adapter got started Saturday on the wire EDM and should finish up tomorrow if all goes well. Then they'll cut the cut to match and I can machine and get the stuff out to heat treat by next week hopefully. Very cool.
    I guess I'll move back on to the engine shaft tonigh so it's ready at the same time.
  7. Pizzaman Chris
    Pizzaman Chris F1 Rookie
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    Oooh this sounds interesting. I want to learn more on this.;)
  8. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,870
    The twilight zone
    Chris, put your car back together and drive it man!
    Put the 360 engine in the next one :)
  9. wildegroot
    Nov 19, 2003
    1,522
    Frenchtown NJ
    Wil de Groot
    I just remembered the name of the company that makes the other electronically controlled water pump I was talking about. Go to www.stewartcomponents.com and take a look at Electric Water Pump # E558A.
  10. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,870
    The twilight zone
    #1835 mk e, Dec 15, 2008
  11. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,870
    The twilight zone
    I found that pump at summit after I'd post the other one. It looks like a better deal and they claim a 10k hr life which is an OEM type life number.
  12. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,870
    The twilight zone
    #1837 mk e, Dec 16, 2008
  13. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    Mark, for the dummies (me) what is a wire EDM machine?
  14. gcmerak
    gcmerak Formula 3
    Mar 17, 2008
    1,665
    Engine Bay, Georgia
    George C.
    Absolutely Amazing!
    Ciao,
    George
  15. rizzo308
    rizzo308 F1 Rookie
    BANNED Silver Subscribed
    Sep 12, 2004
    2,784
    Perth, Australia
    riggio
    it's a wire cutter .... it has 2 reels of wire that has small electrical charge going through it and the wire passes through the and cuts the metal...... i had the small cavallo rampante cut out of alloy so i could press into my new headrest the detail was awesome
  16. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,870
    The twilight zone
    #1841 mk e, Dec 16, 2008
    Yes. Both the wire and the part erode but since the wire moves so fast only the part is cut. The wire over burns about .001" so the .004 wire cuts a .005 slit. After the chunks are cut the machine goes back for a couple finish passes to get it perfect. The top and bottom heads (wire guides) can move separately to make angles up to about 30 degrees.
    When the hub comes off the wire it will have the trans splines and splines to lock the gear to the hub. Then it will go to the lathe to get the diameters and threads cut. The plan is there will be a .0002" clearance between the hub and gear, so it will go together but won't have where to move once it is together. The assembly should act like a 1 piece part......at least that's the plan.
    http://www.edmmachining.com/wire_edm.htm
  17. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,870
    The twilight zone
    #1842 mk e, Dec 16, 2008
    I finished up most of the lathe work on the new clutch shaft. The only thing left is the thread and I can't cut a metric thread on my lathe so I'll ask a friend to do it for me then I can get started cutting the splines tomorrow night. These splines need to be cut not wired because the wire is a line of sight machine that needs a straight line in one side and out the other and that is just not the way the shaft is and there is no way I can make it that way like I could with the hub.
    This shaft has the shorter length I need and the gear mounting section is a copy of the trans shaft to work with the trans gear. The trans gear has a longer flange than the engine gear which will put it in the wrong spot and that will never do so I'll need to cut that flange down to match the engine gear lenght.
  18. wildegroot
    Nov 19, 2003
    1,522
    Frenchtown NJ
    Wil de Groot
    EDM stands for Electric Discharge Machining. The electric current coming of of the moving and chilled wire, erodes the metal of the part being cut, one tiny piece at a time. It's usually done in a climate controlled environment to keep dimensions stable. The process is so accurate that the male and female parts of a big blanking die (for cutting sheet metal car parts for instance) are often made from the same billet of steel. You get the donut and the hole piece, so-to-speak, in one pass. It's a slow process and, of course, is a Computer Aided Machining process.
  19. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,870
    The twilight zone
    #1844 mk e, Dec 17, 2008
  20. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,870
    The twilight zone
    #1845 mk e, Dec 17, 2008
  21. wildegroot
    Nov 19, 2003
    1,522
    Frenchtown NJ
    Wil de Groot
    #1846 wildegroot, Dec 17, 2008
    Excuse me if I'm going over territory covered before ( I have not read all 95, or so, pages) but what alloy did you turn that shaft from and are you going to heat treat and grind it?
    EDM is truly amazing isn't it?
  22. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,870
    The twilight zone
    It's 4340 and will be case hardened and I left a couple thou for grinding.
  23. jimshadow
    jimshadow F1 Veteran
    Feb 19, 2006
    6,269
    Indiana/North Carolina
    JIM
    WOW!!!!!!!
    I think that from now on when any owner is fretting over a DIY project, they should be referred to this thread!
    I'm so very impressed by what you are doing Mark! This is such a cool project. it makes me want to go out and start working on my GT4. :)
    JIM
  24. tazandjan
    39,402
    Mark- You are just unbelievable. You should have been working in the Ferrari prototype shops in the 1960s. In your element even if not making enough money to pay for pasta. Thanks for this great thread. I want to make sure I hear a video of your unique V12 firing up when completed. Should be music, and unheard music at that.
    Taz
    Terry Phillips
  25. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,870
    The twilight zone
    #1850 mk e, Dec 17, 2008
    Thanks for the kind words guys....now I just need to learn the difference between what I can do and what I should do ;)
    I got started on the splines tonight but I got off to a slow start. It's been a while since I've used some of the tools so I had to find it, had to find bolts to set it up, had to clean off some rust. Anyway it's together now and making chips. I got the first groove cut and it looks pretty good. Tomorrow night I'll start by cutting the one opposite so I can get the minor diameter measurement so I can get the cut depth just right and finish this end off hopefully.
