308 V12 conversion begins | Page 94 | FerrariChat
Discussion in '308/328' started by mk e, Oct 9, 2007.
Thread Status:
Not open for further replies.
  1. randyleepublic
    randyleepublic Formula Junior
    Dec 2, 2007
    825
    Beautiful Reno
    You will get it. We all know that and have no doubt. This is like when God was making the universe. All the lesser and lazier gods were watching him struggle but they didn't doubt that soon enough there would be poodles and Ferraris, and a bunch of other weird stuff. No doubt.
  2. wildegroot
    wildegroot Formula 3
    Nov 19, 2003
    1,522
    Frenchtown NJ
    Wil de Groot
    Uh......right.
  3. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,819
    The twilight zone
    I was actually pleasantly surprised that the flow didn't go down. The port was still pretty rough at it was late and I was rushing (and guessing where to grind) the bigger valve is sticking into the flow more and is probably a tad big for the seat ID I cut which is smaller than I started with....all of these are bad things for flow as a general rule.
    What I need is about 10 uninterrupted hours on the flow bench…..which is just not going to happen. I start a new job in a couple weeks that adds 45-60 minutes to my commute which means I need to get up earlier, so I may not even get my 1 hour at night anymore :(
  4. randyleepublic
    Dec 2, 2007
    825
    Beautiful Reno
    Sounds like things are going to slow down on the project for a bit. Well, you'll have lots of time to contemplate on that commute. I am sure that you will make the best of it.
  5. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    Motorcycle required!
    Pete
  6. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,819
    The twilight zone
    Maybe....i would make passing easier.
    Well I got the flow up to 161 tonight....by removing the TB and the vavles and the valve guides. Something is not right with the port.
  7. randyleepublic
    Dec 2, 2007
    825
    Beautiful Reno
    I think that those throttle bodies are too small. My basis for this wild guess is looking at the picture in thread #2272. You got better flow with them off, but the throttle bodies should be part of a runner that aids flow, not hinders. Yes?
    (I hate to say this as I know that they were a workable solution to a difficult problem, but, well, ...)
    (Hey, I am probably wrong so that's not so bad, is it?)
  8. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,819
    The twilight zone
    Maybe. 3/4 of the gain was the valves and guides. I think I've got something not good about port....I think I'd expect to see 180+ cfm, it's just a tube now that the valves, guides and TB are removed, but honestly I don't recall ever trying the everything removed test on a head before. I opened the seat up to 29mm first thing last night and gained a little so now the head should in theory be able to flow about 165 with the valves, guides and TB installed and good ports tend to flow about low 90s% of a tube...so 180ish. The next time I get a chance to play on the flow bench
    The problem with the TB is the throttle plate and shaft usually...which is why they make flat slide TBs. These TBs really need to have the shafts milled and the screws ground flush....but I need to actually buy them before I do that to them. I should probably try a run with the shaft removed too to be sure there is no restriction form the body itself because as you said it should act as a port extension/velocity stack
  9. Alucardtnuoc
    Alucardtnuoc Rookie
    Aug 19, 2008
    10
    Nottingham
    Frank Daniels
    #2334 Alucardtnuoc, Mar 28, 2009
  10. wildegroot
    Nov 19, 2003
    1,522
    Frenchtown NJ
    Wil de Groot
  11. 246tasman
    246tasman Formula 3
    Jun 21, 2007
    1,448
    Will Tomkins
    First I've heard of the PolyQuad. As usual David Vizard's writing & research are very thought provoking.
    Will Mark be able to resist it??
  12. atlantaman
    atlantaman Formula 3
    Mar 31, 2002
    1,726
    Roswell, Georgia
    Charles
    you realize that if you and I BOTH show up at an FCA national event, they may have to start a new class of cars--the Franken-Ferraris.....
  13. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,819
    The twilight zone
    We have to make sure that happens!
  14. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,819
    The twilight zone
    OK, I played a little more and the flow is going in the right direction again. I was avoiding grinding on the top of the port around the guide to keep the port as straight as possible....but that was a huge mistake it turns out. Everytime I touch the top the flow goes up 2 cfm. It's at 154 now (with the TB off) and rising. It's time to watch to re-rur of the F1 race, but I'll get back to it monday and should be able to finish up this week.
  15. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,819
    The twilight zone
    #2340 mk e, Mar 29, 2009
    Well, my elation was premature…….154 was all it had in it and no grinding anywhere was going to give me any more. I did find that after sinking the intake valves enough for the 34mm valves to fit, the exhaust valve sitting at stock height was sticking up and interfering with the flow at around .250-.350 lift, my buddy Vic had pointed out that the flow graph didn’t look quite right which send me hunting for the problem.
    I think it’s pretty good now honestly. I still need to flow it with the TB on but I’m sure it’ll be fine. The peak flow number is lower then I’d hoped for but the lower lift numbers are better than I’d been using in the simulations so the computer says I’m up about 5 hp over the estimated head I was using. You can see on the graph the flow is pretty much all done going up by .450 lift....exactly the lift I'm planning to run. I think I’m done….well except for welding shut a small hole I put in the water jacket.
  16. randyleepublic
    Dec 2, 2007
    825
    Beautiful Reno
    #2341 randyleepublic, Mar 29, 2009
    Mark, would it be possible to test the port's flow with a long runner instead of those throttle bodies? I would be really curious what the effect would be of various lengths and tapers. I know that you don't want huge stacks poking out of the engine compartment, but it seems like the data might still be useful, and not too much trouble to gather. I think that with a few pieces of stiff cardboard or thin sheet plastic, some tape, and some scissors, you'd have the data.
    Maybe it doesn't make any diff at all. OK, that is good to know.
    Maybe it makes a huge difference in the positive direction. Well, maybe then you re-think your aesthetics...
  17. 246tasman
    246tasman Formula 3
    Jun 21, 2007
    1,448
    Will Tomkins
    Hey Mark, no comment on the PolyQuad concept?
  18. randyleepublic
    Dec 2, 2007
    825
    Beautiful Reno
    I guess one thing that I am thinking about this is that let's say you establish that a cone 6" long with a bottom diameter of say, 50MM and a top diameter of 100MM gives optimum flow. So then you can look at that cone and see where and what size throttle fits into that ideal conic profile. Does that make sense?
  19. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,819
    The twilight zone
    I clicked on it and saw it was long and didn't have time to read it carefully and work on my port, I chose the port. At first glance it looks about 1/2 right but I'll give it a good read today.
  20. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,819
    The twilight zone
    It does andc that is basically what I've already done. It always works out that the cone angle should be 4-5 degrees so a simple calculation is all thats needed vs a lot of testing time. The throttle plate itself though buggers up the flow so there needs to be at least a 2mm step at the plate and upto a 8-10mm step often works. The 54mm ducati TBs give me about a 6mm step which I would say is about idea.
    The issue with the TBs is 2 fold I think.
    First the manifold makes a slight curve and the TB has a slight taper bercause of the large throttle plate and it's 48mm oval exit. This makethe TB blend about perfect on the bottom side of the port, but on top there is a slight angle wherew the TB meets the manifold. I'll need to port the TB a touch to fix that.
    Second is the throttle plate, shaft and screws. The plate is thick and the shaft is round making it thick and the screws stick out. I need to mill flats on the shaft and switch to flat head screw that are cut flush as a fist step. I might also mill the plate thinner but I'd rather not if I don't have to.
  21. randyleepublic
    Dec 2, 2007
    825
    Beautiful Reno
    #2346 randyleepublic, Mar 30, 2009
    I understand that you have a predetermined optimum cone shape. But, forgive me if I beat a dead horse, I can't help but think that perhaps a little real world experimentation might be informative. Seems like it would only involve a relatively small amount of effort to test a few minor variations from optimum. If flows falls off with variance from optimum, you have your confirmation. But, if something else happens, then you may decide to go further, no? Also, 4 degrees is the angle you mention, but what about the length? Does it matter? A little or a lot? Again, please forgive my impertinence - you've probably already tried this with other engines, etc. Just throwing my 2 cents out there.
  22. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,819
    The twilight zone
    Ok, I think I understand the question. The answer is complicated because all the variables are interrelated and every decision ends up being a compromise.
    Port angle. The optimum angle for flow is about 30 degrees. The optimum angle for tuning the wave pulses in the intake track is zero degrees. Zero degrees causes a lot of flow loss in a high velocity port, but once the angle is opened up to 4 degrees the flow result because length independent. So a 4 degree port the is 4 inches long will flow the same as a 4 degree port that is 24 inches long…pretty much. The same is true for any angle over 4 up to about 30 degrees.
    Length. The track length is chosen to tune the wave pulses in the track to boost power at the rpm you are interested in with the cam you have and also to fit on the space available. Getting the length right is a pretty critical variable and there are a few choices. The wave pulses in the intake track bounce back and forth and damp out as they go. The strongest pulse is the 1st one, but tuning with it would require intake manifold runner that look like header tubes so that is almost never done. Normally a "long runner" intake is tuned to the 2nd pulse or harmonic and a "short runner" intake is tuned to the 3rd harmonic.
    If the port/runners were straight I would make more hp tuning to the weaker 3rd harmonic because of flow losses caused by the extra length needed to tune to the 2rd harmonic. This is the traditional solution. More recently the 4-5 degree angle has com in as "standard" design so its not flow loss that is the issue, it's port/runner volume gets so big it takes a lot of energy to get the air mass in the port moving so you never get the pulse strength you would with the shorter runner. The only way to be sure which is better is to test it on a dyno, but I'm not going to do that. I will be tuning to the 3rd harmonic primarily for space reasons and call it good enough.
  23. Etcetera
    Etcetera Two Time F1 World Champ
    24,341
    C6H14O5
    Tune it to the London Philharmonic and have a mechanical symphony!
  24. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,819
    The twilight zone
    Ok, he's got a lot of stuff all mixed up together and I' can't sort out what's doing what honestly.
    Keeping the air moving in the combustion chamber helps mix the fuel and lets you run higher compression. If the fuel is already mixed by proper injector placement and sizing and the compression ratio is limited by the cylinder pressure at the torque peak I'm not sure how any claim of improved low power output can be made and he isn't making any claim of improved peak hp.
    What I see is a baseline engine that is fitted with heads that are a flow restriction. Then a set of well ported heads is fitted and the engine makes more power everywhere, as expected. I don't know what else to make of it. He's been working on it for years and the patent is from 2003, I would think in all that time he would have been able to run an engine fitted with 2 matched flow heads, one with normal valves, the other with his polyquad setup and show us the improvement in a clear no questions way….but he hasn't done that.
    The polyquad concept get the "Wrong" stamp I think
    I did briefly consider fitting each valve with it's own TB so at low power I could just use 1 port, then progressively open the second port. That would without question bump up the low power hp/torque significantly. On the down side it's also a lot of work and work mean 36 injectors and 3 ecus to control it so this idea got the "wrong" stamp too.
  25. randyleepublic
    Dec 2, 2007
    825
    Beautiful Reno
    I see what you are saying. Thanks much for the explanation!
