308 with carbs | Page 2 | FerrariChat
308 with carbs
Discussion in '308/328' started by jackgt, Jan 28, 2015.
  1. jessup
    jessup Formula Junior
    Apr 26, 2014
    403
    Santa Clara CA USA
    Jessup
    Once I restored my engines tune and systems back to Factory, my Non Cat passed no problem. Only thing I changed after testing was remove smog pump and adjust base timing. No sweat.
  2. yvesolution
    yvesolution Karting
    Apr 26, 2010
    182
    Cabo Verde
    Hi there,
    something I always asked myself, is if it is possible to transform an injected 308 to carburators?
    greetings
    yvy
  3. _Yves_
    _Yves_ Karting
    Oct 5, 2008
    91
    Shanghai
    Yves Dumoulin
    Understood, then it makes sense.
    I have no idea about the regulations in China, thay cannot even import used cars here...
    My GT4 is in France
  4. Martin308GTB
    Martin308GTB F1 Rookie
    Jan 22, 2003
    4,301
    Black Forest Germany
    Martin N.
    Don't they plan to loosen those regulations.
    I remember, that I have read something about this not long ago.
  5. Albert-LP
    Albert-LP F1 Veteran
    8,187
    around Modena, Italy
    Alberto Mantovani
    Me too: I heard dome voices that China will open to vintage cars. If that will happen, prices will go up even quicker. But they are just voices, I haven't any reliable source info about that: it could be a bull****
    ciao
  6. VIZSLA
    VIZSLA Four Time F1 World Champ
    Jan 11, 2008
    41,693
    Sarasota
    David
    Carbs are wonderfully analog in a cold digital world.
    And they make your garage smell better.
  7. godabitibi
    godabitibi F1 Veteran
    Jan 11, 2012
    6,329
    Papineauville, Quebec
    Claude Laforest
    Sure the FI is way better than carbs. I wouldn't want to return to carbs for my DD. And sorry but they are VERY reliable.
    But talking about an old collector car, easy decision: CARBS
  8. jackgt
    jackgt Formula Junior
    Jan 27, 2015
    574
    california
    Jack
    Hope I did get anyone worked up. It was just an observation 30+ years ago. We had 2 chassis dynos and did a lot of performance work. Had a lot of fun with just carbs and distributors while it lasted. I now know why the 2v cars go for more
  9. godabitibi
    Jan 11, 2012
    6,329
    Claude Laforest
    Now you know it's because we love them.
  10. Martin308GTB
    Jan 22, 2003
    4,301
    Martin N.
    #35 Martin308GTB, Jan 29, 2015
    I agree with you both so much, that I made a display case for my completely rebuilt set of spare carbs, painted the base like a Steinway piano and put them into a display cabinet :)
    Unfortunately I have no air horns for them, because I never found a matching set of four original smooth ones. And the rough casted new ones are too expensive for what they are.... rough casted.
    Best Regards from Germany
    Martin
  11. Bullfighter
    Bullfighter Two Time F1 World Champ
    Jan 26, 2005
    22,614
    Gates Mills, Ohio
    Jon
    For an old collector car, I agree. I have carbs on my 356, and a great Porsche mechanic who keeps them in tune.
  12. Martin308GTB
    Jan 22, 2003
    4,301
    Martin N.
    Let a car with Bosch K-Jetronic sit for one year. Worse, in an environment, which is not dry as a bone. I have seen mundane K-Jetronic cars ( Volkswagen ), which were sitting for three months outside in the weather at dealers, which needed new injectors and - worst case - a new fuel distributor.
    These headaches and costs are in no way comparable with a carburettor rebuild.
    FI is o.k. for daily drivers, but not for extended periods of sitting in a garage.
    Some QV-owners can tell.
    Best Regards
    Martin
  13. HotShoe
    HotShoe F1 Veteran
    8,983
    Lake Worth, FL
    Anthony Lauro
    Yes. There us a gentleman here who converted his Mondial to carbs and did a thread.
  14. Martin308GTB
    Jan 22, 2003
    4,301
    Martin N.
    Search for threads started by user SNJ5. A lot of stuff to read. Have fun :)
    Best Regards
    Martin
  15. Bullfighter
    Jan 26, 2005
    22,614
    Gates Mills, Ohio
    Jon
    328s are K-Jet and are reliable over the long term, even with lower mileage (US cars seem not to get driven as much as European ones.)
    Maybe it's drier in the US.
  16. Albert-LP
    8,187
    Alberto Mantovani
    here we haven't many problems with 328: i did just 250 km last year with my 328 GTS so i do not start it often, but zero problem in almost one year.
    ciao
  17. RBV24961
    RBV24961 Formula Junior
    May 23, 2006
    290
    Rye, New York
    I just had mine rebuilt and setup to factory specs and the car has never ran better and oh what a sound!
  18. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,550
    Scottsdale AZ
    Stu Boogie
    The value increase is due to the vintage of the car. FI cars are a generation in front of carbs and this less vintage. As our cars get older they are valued more as a collector item than a fancy modern sports car. The 308/328 is in the former category. Carbed 308 are a generation in front of FI 308/328 and this more valuable as a collector item.
  19. ForzaV12
    ForzaV12 Formula 3
    Sep 15, 2006
    1,818
    Laguna Niguel
    Steve
    I've owned both. I enjoy carbs on collector vehicles and have found them to work quite well when set up properly(whether its an old Holley of a quartet of Webers).
    All the same, my 308GTBi runs fantastic in all weather conditions and has never had an issue. As to power, a few ponies one way or another doesn't really matter with these cars as none of them could be considered fast anymore.
  20. VIZSLA
    Jan 11, 2008
    41,693
    Sarasota
    David
    These days more often than not I'm the only car with a carb at local events so it's an exotic among exotics.
    And it's never thrown a code nor "limped Home".
  21. haisoodewa
    haisoodewa Karting
    Aug 14, 2011
    55
    Vermont
    Zach M
    Power is a big reason, sound is a big reason, and for me the throttle response might be the biggest reason. Noticeably faster response than the CIS systems; you just pay for it with terrible milage (nbd).
  22. dflett
    dflett Formula 3
    1,632
    NY
    David
    So true. On a run this summer mine was the only car with carbs and also the only car spitting blue flames out the back when lifting at high rpm on the entry into hairpins, much to the delight of the Miata driver following me.
    When I went shopping for a 308 a few years ago, I was only looking for a weber-equipped GTB. I'm not surprised to see the carb cars appreciating now.
  23. Martin308GTB
    Jan 22, 2003
    4,301
    Martin N.
    And low rpm torque is a reason. Though they masked this flaw a little bit with different gear ratios on the FI cars.
    Best Regards
    Martin
  24. Bullfighter
    Jan 26, 2005
    22,614
    Gates Mills, Ohio
    Jon
    #49 Bullfighter, Jan 29, 2015
    Road and Track Used Car Classic, US-spec 308s, with cats, from '78, '81 and '84.
    Listed fuel economy got cut off, but it was 15 mpg for the '78, 11.5 for the '81, and 16.0 for the QV.
  25. anastasio
    anastasio Karting
    Dec 9, 2011
    125
    mexico city
    anastasio
    how many sealed bearings per weber carburator?, I will buy them in a heart beat.
    thanks for the great information
