308GTB passenger door will not open :-( | FerrariChat
Discussion in '308/328' started by micha1980, Mar 14, 2025.
  1. micha1980
    micha1980 Karting
    Feb 20, 2006
    93
    netherlands
    micha
    I am looking if somebody can help me with getting the passenger door open. I cannot open it from the outside or the inside.. i've tried it with the key to lock and unlock it, but no respons..
    It's also not possible to take off the door panel due screws on the outside of the panel which you cannot reach when the door is closed..
    Anybody who can give me some advice to get it open.
    Thanks for your help
  2. 85QVEuro
    85QVEuro Formula Junior
    Jan 15, 2021
    545
    NYC
    Joe
    This is what the door looks like with the door card removed. If you get inside the car and can get "something" down through the window/weatherstrip to grab on the horizontal rod that goes from the inside pull to the door latch (pull toward the front of the car), it may/should open...Hope this helps
  3. micha1980
    micha1980 Karting
    Feb 20, 2006
    93
    netherlands
    micha
    Thanks for the quick answer. I've got the door open..
    I've put down the window and lifted the door a little bit up pulled the door handle at the same time and that was the trick..
  4. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,808
    Cerritos, CA.
    If the door is sagging down, you might need a new door pins
    dinoart likes this.
