308GTB QV Relays -what order & part#s? | FerrariChat
Discussion in 'Technical Q&A' started by NSXER, Jun 18, 2006.
  1. NSXER
    NSXER Formula 3
    Jan 4, 2004
    1,307
    Kansas
    I have an 84 308GTB QV and it is still not running correctly, I have narrowed it down to the relays for the jetronic unit (in the trunk). On that unit it has three relays, two on the side and one large silver one by itself (wehrle relay). I understand that this large relay has been discountinued. Does anyone know the replacement part and # for all three relays? Also, does anyone have a picture of the order with part numbers of the relays in the passenger compartment. I think that some of them are in the incorrect sockets and a good pic would help a ton. Thanks
  2. NSXER
    NSXER Formula 3
    Jan 4, 2004
    1,307
    Kansas
    I found a schematic that shows which relays go in each location, but does anyone have the correct part number for the large silver relay on the jetronic? Thanks
  3. M.James
    M.James F1 Rookie
    Jun 6, 2003
    2,721
    Worcester, MA
    Michael.C.James
    I used to know....I had the same issue. Probably the Lambda relay - its a Porsche 928 relay, but a pricey one....$120. The part number should be stamped on the relay itself, but if not, you may need to visit your Porsche parts counter and ask for a Lambda relay for an early 1980s 928 with Bosch K-Jetronic fuel injection....they can source it.
