308gtsi went to 3000rpm after warm up | FerrariChat
Discussion in 'Technical Q&A' started by LCARRS, Jul 20, 2014.
  1. LCARRS
    LCARRS Rookie
    Jul 20, 2014
    1
    Hello everyone , I had just started my 82 308gtsi and allowed it to warm up. The amber light had been on for the warm up and then shut off when the idle dropped down to normal. I was waiting for the cooling fans to cycle since the car sits a lot . After 10 minutes at normal idle the rpms suddenly jumped to 3100rpms for no reason without me being in the car . I shut the car off allowed it to rest for 3 min. and did a restart where it immediately went to 3000 rpms and no amber light . I think it must be a massive vacuum leak but don't know where to start. I normally work on antique corvettes but I have had this Ferrari since new and am in a panic!!! Larry
  2. Mantinger
    Mantinger Karting
    Jul 30, 2004
    145
    Netherlands, Drenthe
    H
    Try to block the hose beneath the expansion tank. It supplys air to the auxilary air valve.
    When this valve sticks open (or is not powered) it will give a throttle effect. Just put a clamp to it and see if it has any effect on the revs.
  3. ferrarioldman
    ferrarioldman Formula 3
    Professional Ferrari Technician Silver Subscribed
    Jun 19, 2002
    1,033
    Summerfield, NC
    Tom Jones
    #3 ferrarioldman, Jul 22, 2014
    The fast idle air valve is above the thermostat housing. Take the small vacuum hose coming from the vacuum switch to the valve and connect it directly to the vacuum port on the intake plenum thus bypassing the vacuum switch. This should close the valve while the engine is running. See it that helps.
    AND fill out your profile please.
  4. waymar
    waymar Formula 3
    Sep 2, 2008
    1,354
    Northeast, PA - USA
    Wayne Martin
    Larry you mentioned you had the car since new. If nothing was worked on recently, then I would agree with an air leak or solenoid. The fast idle air circuit mounted on the passenger side of the engine has many hoses and a few solenoids. The one valve can be closed by hand to test, the one with the vacuum line going to a solenoid. If the yellow light is out and the valve is open then one of two issues. Air vacuum or electric solenoid failure causing the valve not to close. Also check the temp switch on the water tank the one with just the wires make sure one did not get knocked off.
  5. finnerty
    finnerty F1 World Champ
    May 18, 2004
    10,406
    There is also a small, brass, 2-prong, on/off thermo switch screwed into the underside edge of the coolant expansion tank --- it controls the "fast idle warm up" functionality. Yours might be bad. You can test it by disconnecting the leads (to simulate the open condition), and then jumping them together (to simulate the closed condition), and seeing if that has any effect on the problem ---- if it does, the switch is bad.
  6. Robz328
    Robz328 F1 Veteran
    6,299
    ATL, Georgia
    Rob Hemphill
    I like this method. try it. Top be sure, this is not the "thermo-time" switch for the CSI, right?
    IIRC, the 328 switch on the expansion tank controls the AAV; might be same as GTS/Bi. 328s also have an oil temp switch on the bottom front of the engine block that governs the AAV.
  7. finnerty
    May 18, 2004
    10,406
    No, it is not. On the injected 308s, the thermo-time switch (for CSI) is on top of the engine block. It does several things, one of which is to control the open/close of the AAV.
    The switch I refer to (in the expansion tank) does several things ---- During the "cold start / fast idle warm up" condition, it sends a signal to the DigiPlexes which advances the ignition timing, and it also operates one of the manifold vacuum supplied electrovalves which in turn control the "cold start air valve" allowing more air to bypass the throttle ---- both changes are what make the engine automatically race up to about 3K RPM for a while until warmed up.
    All of this is for emissions control purposes, and only applies to the US-spec injected 308s.
    The 328 (for all markets) does not have any of this particular equipment --- it has an entirely different, and more sophisticated, set up for controlling "cold start idle" emissions, and thankfully does not employ the 3K cold race up function (which is not too great for wear on a "cold" engine, IMO).
    I have disconnected / removed this entire system on every 308 that I have owned.
  8. Steve Magnusson
    26,785
    Just a small clarification -- it applies to 1980 to 1983 US-spec injected 308s (which are K-Jet without Lambda); it does not apply to 1984-1985 US-spec injected 308s (which, like US-spec 328, are K-Jet with Lambda).
  9. finnerty
    May 18, 2004
    10,406
    @ LARRY ---
    Any luck ?
