308n gt4 heads | FerrariChat
308n gt4 heads
Discussion in '308/328' started by edjowseyracing, Aug 4, 2007.
  1. edjowseyracing
    edjowseyracing Rookie
    Apr 15, 2007
    2
    hi i have 2 remove the heads of our 308 and im not quite sure how 2 remove them once everything has been diconected?
    edwin
  2. dstacy
    dstacy F1 World Champ Owner Rossa Subscribed
    Jan 23, 2006
    11,998
    GMT -5 & GMT +1
    Dave
    Is it a 308 or a GT4 it makes a difference.
  3. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    the GT4 engine is virtually identical to all the 308's, especially once everything is stripped away. If the engine is not already removed, you would make life much easier on yourself to remove it from the car. The heads will most likely be corroded to the studs and will require great effort to remove. A steel plate can be fashioned to work as a head puller. DO NOT use tools or wedges to pry it off by driving tools into the head gasket area, you will do $$$$$ damage. If its not stuck awfully bad, you can gently pry against the bottom of the head where it hangs out over the block and use leverage against the studs out the front of the block, but be very gentle. If your putting enough strain to flex the studs, you prying to hard. Put some PB Blaster or some type of light oil down the studs and let it sit a day or so and try again. A solid piece of wood under the head overhang and a good whack or two with a mallet usually gets them moving.
  4. dstacy
    Jan 23, 2006
    11,998
    GMT -5 & GMT +1
    Dave
    Obviously I know that. The reason I asked is because it makes a difference how the engine comes out depending on which car it is.
  5. dstacy
    Jan 23, 2006
    11,998
    GMT -5 & GMT +1
    Dave
    Ed be very careful. Paul is right DON'T pry them apart.
    If your car is a GT4 search for Davidriver's thread on pulling a GT4 engine. There are quite a few on pulling a 308 engine. The big difference is how you have to tilt them, what has to be removed to clear the frame, and how you don't whack the GT4 backglass or trunk.
