News
308QV Bucket Tappet
Discussion in '308/328' started by utah4re, Mar 5, 2008.
  1. utah4re
    utah4re Karting
    Nov 1, 2005
    52
    Can anyone tell me what the dimensions are (diameter and height) of a 308QV tappet is.
  3. Steve Magnusson
    20,295
    Texas
    Are you asking for the diameter and thickness of the shims? (The bucket has more than a single height dimension to different features)
    If so, the nominal shim diameter is 29mm on the 4V heads, and the nominal shim thicknesses vary from a minimum of 3.7 mm to 4.35 mm
  4. utah4re
    utah4re Karting
    Nov 1, 2005
    52
    I would like the outside diameter of the tappet and the height. Not the shim. I am trying to determine if these can be adapted to a Lancia Stratos 4 valve engine.
  5. mk e
    mk e F1 World Champ
    Oct 31, 2003
    11,962
    The twilight zone
    The Butcher
    They are 33mm OD and about 28mm long/tall off the top of my head.
  6. duck.co.za
    duck.co.za Formula Junior
    Jan 9, 2007
    813
    Cape Town South Afri
    Dave
    The 16V integrale bucket is identical to the 2v 308 bucket ,I compared them just last week .
  8. Steve Magnusson
    20,295
    Texas
    #6 Steve Magnusson, Mar 11, 2008
    The 308QV/328 WSM gives the diameter as 32.984 min - 32.990 max
    The don't give the overall height, but perhaps you can scale the drawing on page B23 to confirm Mark's data:
  9. mk e
    mk e F1 World Champ
    Oct 31, 2003
    11,962
    The twilight zone
    The Butcher
    that's a 37mm OD then.
  10. mk e
    mk e F1 World Champ
    Oct 31, 2003
    11,962
    The twilight zone
    The Butcher
    The QV buckets measure 33mm OD x 30.22mm long
    The 2V buckets measure 37mm OD x 30.5mm long
  11. utah4re
    utah4re Karting
    Nov 1, 2005
    52
    I appreciate the feed back on the dimensions of the tappets. I won't be able to use the tappets as I need 35mm tappets for the 4 valve per cylinder heads. Thank you very much for the information.
