308qv Distributor Rotor Arm Position | FerrariChat
Discussion in '308/328' started by sdsdesilva, May 24, 2018.
  1. sdsdesilva
    sdsdesilva Rookie
    Apr 10, 2005
    39
    Cambridge UK
    sdsdesilva
    I have removed the drive pin at the end of the camshaft to replace the o ring. I want to be 100% sure before I re-install the rotor arm drive pin, as this can be 180 deg out if I get it wrong.
    Can someone please confirm position of rotor arm for front and rear bank. Thank You
  2. kcabpilot
    kcabpilot Formula 3
    Apr 17, 2014
    1,608
    California SF bay area
    Paul
    Both of my cams are sitting on a table I can give you a picture/answer tonight if no one else chimes in first.
  3. sdsdesilva
    sdsdesilva Rookie
    Apr 10, 2005
    39
    Cambridge UK
    sdsdesilva
    yes please. Position of the rotors w.r.t cam alignment marks.
  4. kcabpilot
    kcabpilot Formula 3
    Apr 17, 2014
    1,608
    Paul
    looking at distributor end with sprockets at far end and alignment mark straight up at 0 deg
    1-4 rotor is 160 deg
    5-8 rotor is 240 deg
    My car is US 1983 QV
  5. kcabpilot
    kcabpilot Formula 3
    Apr 17, 2014
    1,608
    Paul
    Just to be clear I'm looking straight down the camshaft from the distributor end and these positions are clockwise from the index mark so it's kind of a backwards reference if you know what I mean.
  6. sdsdesilva
    sdsdesilva Rookie
    Apr 10, 2005
    39
    Cambridge UK
    sdsdesilva
    Thank You
