308qv efi manifold conversion | FerrariChat
Discussion in '308/328' started by Alex N, Jan 25, 2022.
  1. Alex N
    Alex N Karting
    Mar 29, 2021
    189
    Vincent Napoliello
    Who on here welds modern fuel injector bungs in the manifold to accept modern injectors and fuel rails, I want to get rid of cis
  2. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,332
    Dumpster Fire #31
    SMG
    There's a couple options on this.
    The biggest hurdle is the throttle body sitting right in the way of the fuel rail.
    The next one is injectors, majority of injectors now are the new molded plastic ones. The old metal body are getting harder to source.
    When I started with the EFI conversions I started with the metal body ones, made an adapter and had custom injectors machined with threading.... Then it got harder to source injectors.
    With the advent of printing, I now print custom parts that retain the modern injector in the port with no machining or welding needed.
    That still leaves the fuel rail issues... Depending on comfort level and budget, there's everything from custom hand bent lines that look OEM to the new manifold and throttle body we've been using on builds to just running a sectioned 'D' rail.
    Kinda comes down to what you're looking for.
  3. Alex N
    Alex N Karting
    Mar 29, 2021
    189
    Vincent Napoliello
    Ok thanks , I’m going to reach out to you guys in the coming days about my options on this, my car has a prancing horse twin kit on it and I want to do a full efi/ ignition conversion with water to air intercooler and upgraded turbos. The turbos I have now are IHI Rhb52. It would be nice to find some turbos that could bolt right up to the existing stuff if it was dimensionally the same. I’ll have to dig in on that subject.
