308QV engine compartment | FerrariChat
Discussion in '308/328' started by RVIDRCI, May 22, 2006.
  1. RVIDRCI
    RVIDRCI Formula 3
    Dec 1, 2005
    1,576
    Long Beach / Phoenix
    Luigi
    #1 RVIDRCI, May 22, 2006
    I attended the LA Concours @ the Rose Bowl this last weekend (my 308 was not entered or displayed,..yet). I spent alot of time with 308 owners and judges pouring over details on the 308's entered, and found out some new facts about what is considered "original". I have a 85 Swiss spec Euro, and have known for some time about many Swiss specific differences, but on the engine compartment firewall insulation I am now stumped. The U.S. cars, and (according to judges I asked), the Euros also, have an aluminum sheet over the firewall insulation, and a sheet aluminum brake-bent sheild above the fuel crossover tube. My car has neither, but looks like pictures I have seen of early GTSI cars, and later 328's.
    I know this is a nit picky little detail, but I would like to have It correct on my car. This area needs to be restored anyway (see photo). I am bringing it to the forum in hopes of getting a definite answer, Any 100 point Swiss spec car owners want to post pics?
    Whadda you guys say about this?
  2. Impactco
    Impactco Formula 3
    Jan 29, 2006
    1,615
    #2 Impactco, May 22, 2006
  3. RVIDRCI
    RVIDRCI Formula 3
    Dec 1, 2005
    1,576
    Luigi
    Thanks Michael!
    The judges must be wrong. I'de like to get some more input though before I get the airbrush fired up to paint it. Do you have soft 3/4" thick raw foam on the firewall below the fuel crossover? And what color do you think is original,
    aluminum silver ?
  4. Impactco
    Impactco Formula 3
    Jan 29, 2006
    1,615
    No foam here.
  5. 308 GTB
    308 GTB F1 World Champ
    11,730
    New Jersey
    Barry Wolinsky
    #5 308 GTB, May 22, 2006
    Louis,
    What you're describing is present only on the European fiberglass GTBs:
  6. jwise
    jwise Formula Junior
    Apr 2, 2003
    781
    Portland Maine
    #6 jwise, May 23, 2006
  7. AHudson
    AHudson F1 Rookie
    2,781
    Florida
    Adams Hudson
    #7 AHudson, May 23, 2006
    My 1988.5 car definitely had the aluminum firewall shield. It was an insulated board with an aluminum sheet formed over it.
    It's hard to see (since I wasn't specifically aiming for it) but you can see the reflection off of it running near the top of the engine compartment all the way across. I took mine off and cleaned it a bit during my belt service.
    Hope this sheds some light.
  8. BigAl
    BigAl F1 Veteran
    Mar 17, 2002
    6,146
    TX
    GSgt Hartman
    where'd you get that oil filter cover? Is it more for dress up or to act as an insulator?
  9. RVIDRCI
    RVIDRCI Formula 3
    Dec 1, 2005
    1,576
    Luigi
    JWISE,
    Thanks. This helps alot and explains why the thick insulation foam that covers my firewall (the entire fire wall) has a melted/heat damaged area right where that sheild SHOULD be, to protect it from the unsheilded euro headers. I ain't got one of those. What is your vin #, if I might ask. It does not look like your car ever had the thick exposed foam like mine. Otherwise the upper area looks identical on both our cars.
    -Luigi
    PS- Your motor seems to be missing slightly.
  10. AHudson
    AHudson F1 Rookie
    2,781
    Florida
    Adams Hudson
    Both. I've used these on almost every 911 I've owned, for far more practical reasons, but I like the aesthetic as well. Owning Porsches will give you a new appreciation of heat dissipation, I promise. I own a mid engine boat and have one for it as well.
    After I installed this on my 328 though, the thing would get wicked hot to the touch, so I felt like it was doing its job, creating more surface area for heat to find it way elsewhere.
    As a side note, I'm looking for a 328 again, hopefully in blue or silver this time around. If anyone knows of one just email me.
  11. BigAl
    BigAl F1 Veteran
    Mar 17, 2002
    6,146
    TX
    GSgt Hartman
    I'll search the net, but in the meantime, do you recall the name of it?
  12. AHudson
    AHudson F1 Rookie
    2,781
    Florida
    Adams Hudson
  13. BigAl
    BigAl F1 Veteran
    Mar 17, 2002
    6,146
    TX
    GSgt Hartman
  14. RVIDRCI
    RVIDRCI Formula 3
    Dec 1, 2005
    1,576
    Luigi
    very "cool" about the oil filter fins, but you hijacked my thread. (LOL)
    I still would like to know what is "original" to my Italian Swiss Calamity !!!!!
    I'm thinking the small stand off shield, but I must know for sure. I am obsessed man, I tell you OBSESSED !!!! Mwahhahahahaaaaaa....
    cleansing breath....
    Any more experts want to chime in? anyone, Beuhler, Little Old Winemaker, anyone????
  15. AP328
    AP328 Karting
    88
    Canada
    I have a 1989 328, that is also Swiss. It has the same material as your car on the firewall and has something similar on the engine cover (something I have seen on a TR of approximately the same vintage).
  16. RVIDRCI
    RVIDRCI Formula 3
    Dec 1, 2005
    1,576
    Luigi
    Thanks,
    Yes, I have the same foam insulation on the engine bonnet, Swiss only.
    Do you have the aluminum header shield to protect the firewall foam?
    Thanks for the info,
    -Luigi
  17. jwise
    Apr 2, 2003
    781
    Portland Maine
    No problem. I see no indication that I'm missing any foam, but I have only had the car three years. I've been told it's a swiss/german spec car by a Ferrari tech at Boston Sports Car in Mass., so I assume he would know.
    What other characteristics of a swiss car are you aware of? Mine has the mesh over the side intakes, etc.
    Car # is 48305.
  18. RVIDRCI
    RVIDRCI Formula 3
    Dec 1, 2005
    1,576
    Luigi
    Jwise,
    The intake screens are specific to German 308's only.
    Here is what I know about Swiss Euro 308's:
    -different gearbox, closer ratio 2nd thru 5th, lower 1st, taller final drive.
    (see Kieth Bluemel's book "original Ferrari V8") Love mine, great for canyon
    and mountain twistys.
    -sound insulation on engine bonnet, inner wheel wells and (apparently) the
    firewall.
    -Swiss specific quieter exhaust muffler system (mine weighs about 100 lbs)
    -Swiss specific horn tone, different pitch.
    -Swiss specific air duct between air box and exterior scoop (mine has a sort
    of "muffler" bump thing)
    -Swiss cars were only available delivered with Michelin TRX 390 metric tires
    and wheels (less road noise I think)
    -No rear fog light option as delivered from factory
    -No deep air front dam as delivered from factory
    Consult your parts manual if you have one, or get a ebay cd version. There are many many small parts that are CH only (the code for swiss spec )
    It seems to be all about noise generated.
    "and once again, the Swiss remain "Quietly" neutral"
    -Luigi
  19. jwise
    Apr 2, 2003
    781
    Portland Maine
    Luigi-
    Great information! I have none of those visible swiss characteristics, so my car must be german. Where did you dig this up? Any info on german QV's?
    Thanks again-
    jwise
  20. RVIDRCI
    RVIDRCI Formula 3
    Dec 1, 2005
    1,576
    Luigi
    Your very welcome. I have gotten most information from books, other owners and mechanics. Also f-chat. The original parts manual, if you study it close, has a ton of spec specific info. The 308 QV register is a cool website and Wade Nunez who runs it is a good guy. Kieth Bluemel's book "original ferrari V8" is a must have for 308/328/Mondial owners, tons of info. The factory site will give you alot of info on your car if you e-mail (or snailmail) them (registered owners).
    I have no further knowledge of German spec stuff.
    Best regards,
    -Lou
    PS- if you decode you entire vin it will tell you alot of info incl country of delivery. Do a search on "vin decode" here or on google.
