308QV ingnition problem | FerrariChat
Discussion in '308/328' started by ump, Sep 4, 2009.
  1. ump
    ump Rookie
    Sep 4, 2009
    10
    I have a 1984 308 which seems to run fine until BANG, half the cylinders shut off, a few moments go by, could last a few seconds to perhaps 30 seconds and then BOOM, it backfires and works fine again. We started with the distributers which had oil in them, this was repaired but I still have the same problem. My mechanic is not very Ferrari specific, so I'm trying to help him out. Is this a common problem? Where would you suggest we look?
  2. andy2175m4@yahoo.com
    [email protected] Formula Junior
    Dec 7, 2008
    473
    Los Angeles, CA
    Andy Rein
    Since it's intermittent, it would probably be an electrical ignition problem, and on one side of the engine, then it must be due to one distributor, or one coil, or one ignition module. Do you know if its' the front or rear bank of cylinders that is faulting.
    Check all the wires for tight connections, check the resistance of the coils, take off the high voltage lead that goes from the coil to the distributor, and check it for any intermittent breaks or loss of continuity.
    Check the coil low voltage wires. If you have a wiring diagram, see what wires or devices feed the coils, and check those devices (relays, fuses, etc).
    Also, could be a faulty Digiplex ignition module, or fault in the digiplex wiring harness. I have no clue how to dianose or fix those, and they are hard to find used. Worst case you can replace the digiplex modules with one of the many after-market ignitions discussed in this forum and eliminate the obsolescence problem there.
  3. ump
    ump Rookie
    Sep 4, 2009
    10
    Thank you very much for the response !!
    If I replace to aftermarket ignition will it overide those first problems you mentioned?
    How much does an aftermarket system cost?
  4. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    Simple system. Sensors > Module > Coil for each bank
    When one bank goes non-functioning, reversing components to see if systems also reverse.
    Reverse module connector to rule out the Ignition Module.
    Reverse coils to rule them out.
    Check sensors for resistance. Of 3 sensors the 2 TDC should
    indicate about 700ohms and the tach sensor about 750 ohms.
  5. Dr Tommy Cosgrove
    36,426
    Birmingham, AL
    Tommy
    Forget checking the coils, wires and caps, etc and go straight to the crank position sensors. There are three and I'll almost bet the bank this is your problem. Happened to me back in 06. One is dried up and cracked just like mine was. VERY common problem
  6. 308GTS
    308GTS Formula 3
    Dec 27, 2001
    2,223
    TN
    I second what Tommy says. I had one good bad while it was being test driven by the new owner. I knew exactly what it was. I checked mine with an ohm meter and the one that showed infinite ohms was the culprit. Pulled it out and sure enough it had cracked from age/heat. We replaced it, he bought the car and it ran great the entire trip home for him. It isn't an uncommon problem. I think they are $100 each now. I would replace all 3 just to be safe but if you don't want to do that at least replace both TDC sensors.
  7. ump
    ump Rookie
    Sep 4, 2009
    10
    Hey, THANKS A BUNCH!!
    I will do what you say along with all the other checks and get back to let you know.
    THANK YOU ALL!
    BTW, I've had this car since 1985 and have never really had any problems with it. I guess aged 25 years is starting to show.
  8. barcheta
    barcheta F1 Rookie
    Nov 15, 2003
    3,738
    Maryland
    Jim
    +3
  9. ump
    ump Rookie
    Sep 4, 2009
    10
    THANK YOU ALL!
    Changed the sensors and drove over 100 miles. Things are looking good.
    Thanks again !!
