308QV Slow Down Light Issue | FerrariChat
Discussion in '308/328' started by Andrew Bolton, May 13, 2008.
  1. Andrew Bolton
    Andrew Bolton Karting
    Aug 20, 2004
    155
    Spring, Texas
    Andrew Bolton
    I've been out of commission for a few weeks with pneumonia. Today, however, I got in my QV and ran it down the road for a while. At first, as the car wound up in each gear, it was kinda "surgy" at the higher revs. But after a while it smoothed out and ran fine.
    Then about 7 to 9 miles down the road, I got an intermittant "slow down" light, so I nursed it back home. I had gotten this light a few weeks ago after sitting behind a train, and somehow talked myself out of thinking that there was a problem. Both times, upon arriving home, I felt near the grill around the catalytic converter and it felt waaay too hot (like the paint above the diaper was about to blister). Other than the short surging (which was gone 7 or so miles before the light ever came on), there was no other issue.
    What's the expert's guess here? Three years ago, I got a slow down light and a very hot cat and spent $1500.00 for a new flywheel sensor.
    I'd like to ask help from the gurus here, if any can offer it.
    Andrew
  2. spiderseeker
    spiderseeker Formula 3
    Jul 22, 2005
    1,718
    Colorado
    Steve
    I think the sensors are about $100. (if you do it yourself)
    If the slow down light error is legit, I think it usually means that one bank of cylinders is not firing, thus throwing unburned fuel into the hot cats, which can cause fire and ruin your day. Be sure to figure it out BEFORE driving again.
  3. jonesdds
    jonesdds Formula 3
    Aug 31, 2006
    2,163
    SB,CA & Park City UT
    Jeff
    No guru here but when I had slow down light issues it was a bank misfiring and was a worn rotor. Could be electrical or fuel related. I'd start with electrical starting with the simplest things first. Probably not individual cylinder issues like plugs, extenders. Check with timing light to see which bank is the culprit. Good hunting.
    Jeff
  4. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    You meant $150.00 for a new flywheel sensor, right?
  5. Kevinwi
    Kevinwi Karting
    Nov 21, 2006
    241
    I've got the same issue with my 85 308. In my case it takes an hour or two of highway driving before the light comes on. (I rarely drive the car that far) I called the dealership about it and they said it could be a number of things including the gas/air mixture. They said I should bring it in for diagnosis.
    Based upon that, I wouldn't jump to any immediate conclusions about the cause. I'd recommend taking it to a shop for an estimate. That way, it's diagnosed for you and you can also determine if you can do the repairs yourself or can afford to have them done there.
    Just my 2 cents.
    Kevinwi
  6. ebehrendsen
    ebehrendsen Karting
    Sep 26, 2007
    224
    Colorado
    Erik
    I had the same problem and it turned out to be a bad distributor rotor. Check both distributors first and see if that's the problem.
    Good Luck!
  7. jonesdds
    jonesdds Formula 3
    Aug 31, 2006
    2,163
    Jeff
    I'd agree too on getting it to a shop if your not handy at DIY. The problem I had when I did that was hours were spent testing the fuel system pressures and injectors that if the electrical system were first checked would have amounted to 30 minutes of diagnosis. So instead of 2-3 hours of labor it was more like 8. Common sense to me indicated an electrical problem most likely given the sudden onset of problems. Knowing it had to be a bank not working given the very poor running and having checked the individual extenders I would have started with the rotors, then coils, basically check upstream of the individual wiring to the cylinders. Checking there first would have uncovered the problem very quickly and the car would have been back quicker with a bill at least half as much. Looking back, I wish I had done this as it's something I could have tackled. Maybe the mechanic did right, but it sure seems like that's where he should have started. These kinds of problems I know can be difficult to diagnose, and many times take a lot of labor to figure out, I just think in my case it should have proceeded in a different order. Hope this helps.
    Jeff
  8. Andrew Bolton
    Aug 20, 2004
    155
    Spring, Texas
    Andrew Bolton
    Okay, I took it out again today and drove it 20+ mi. Again, it seems a bit surgy--not too much, but just a bit. It surges a tad until I get the throtle past the half way mark, then it appears to "catch' and pull strongly. On the other hand, during the drive the slow down light did NOT come on and the cat did not seem to get too hot (both highway and stop light driving).
    I'm going to check the rotors on the distributors first as they are the easiest things to replace, lol. If it's more than that, perhaps a shop is the best bet. I guess if this is a long-running electrical problem, then pulling the plugs might show me where, huh?
    Thanks.
    Andrew
  9. jonesdds
    jonesdds Formula 3
    Aug 31, 2006
    2,163
    Jeff
    I'd recommend not driving it until sorted out. When you say it surges, you mean it loses power not gains, correct? By it being "surgy" that would describe to me it suddenly gaining, not losing power. But , your third sentence seems to indicate los of power. I'd bet it's rotors or possibly coil but more likely the former.
    Jeff
  10. Andrew Bolton
    Aug 20, 2004
    155
    Spring, Texas
    Andrew Bolton
    I understand about driving it, but it's got to be run to check out. I was careful about the heat on the cats.
    Yeah, it is both of what you said, prior to meeting the half-way mark on the gas peddle, it is surging a small amount, but when you get to the half-way mark, it really catches on and the car pulls strongly from that point onward.
    I do plan on checking the rotors, etc. That's my real hope--a quicker, easier fix.
    Andrew
