308QV surging on acceleration | FerrariChat
Discussion in '308/328' started by Andrew Bolton, Jul 22, 2008.
  1. Andrew Bolton
    Andrew Bolton Karting
    Aug 20, 2004
    155
    Spring, Texas
    Andrew Bolton
    Mentioned this in an earlier post, but I don't think anyone had a perfect idea of what's going on here.
    As I accelerate, I get a surging. Up to about 3500 to 4000, it seems to pull reluctantly, then I get a large surge of power (more than just the torque curve kicking in). As I continue to accelerate, the power surges up and down until I'm at speed. There does not seem to be any surging at a constant velocity in 4th or 5th gears--perhaps just a little.
    I've tried to think of everything, but am stumped. I've recently changed the O2 sensor (Bosch) and distributor caps. So what's the forum opinion here?
    Andrew
  2. Newman
    Newman F1 World Champ Consultant Owner Professional Ferrari Technician
    Dec 26, 2001
    14,472
    Canada
    Newman
    I would check my fuel pressures and verify my CIS WUR is functioning properly from cold start through the warm-up cycle then while it runs. Your fuel pressure could be fluctuating causing the surge, just a thought.
  3. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    Is it missing? Could be an ignition issue.
  4. Andrew Bolton
    Aug 20, 2004
    155
    Spring, Texas
    Andrew Bolton
    No Birdman, it doesn't "appear" to be missing, just surging. As for the CIS WUR, uhmm, yeah, right. Uh. . . what's that?
    Andrew
  5. spiderseeker
    spiderseeker Formula 3
    Jul 22, 2005
    1,718
    Colorado
    Steve
    * CIS is your fuel injection system (CIS = Continuous Injection System), the WUR is short for warm up regulator.
  6. Andrew Bolton
    Aug 20, 2004
    155
    Spring, Texas
    Andrew Bolton
    Ahh, well this happens well into a warm up as well as when cold. The surge is so "aburpt" that it could be an ignition issue (perhaps I should have it put onto a scope). This is just a bit unusual.
    Andrew
  7. thecarreaper
    thecarreaper F1 World Champ Silver Subscribed
    Sep 30, 2003
    18,076
    Savannah
    fuel pressure or bad spark plug extenders.
  8. regisgtb4
    regisgtb4 Formula Junior BANNED
    Mar 20, 2007
    463
    tx
    willis
    usually causes surge at steady throttle but i seen some old ones on bimmers that cause all kinds of bummers.
  9. Dr Tommy Cosgrove
    Dr Tommy Cosgrove Three Time F1 World Champ Owner Rossa Subscribed
    May 4, 2001
    36,447
    Birmingham, AL
    Tommy
    unplug your O2 sensor (very easy to do) and see if it still does it.
    I replaced my O2 sensor last year and my car did the same thing. It didn't before because it was never connected in the 10 years that I owned it. Once a new one was hooked up the surging began and it drove me crazy. I unplugged it and the problem went away again. It is going to STAY unplugged from now own too
  10. Andrew Bolton
    Aug 20, 2004
    155
    Spring, Texas
    Andrew Bolton
    Okay, I'm beginning to see that this might be an ignition problem. At lower rpms it pulls slowly and--I've now begin to notice that I get a single flash of my "slow down" light DURING acceleration at the lower rpms. If this means raw fuel into the cat during acceleration, then it likely is an ignition problem. (I'm thinking aloud here) As I said: at about 4K rpms, it suddenly pulls strongly BUT with a jerky power band. Coil wires, extenders, plugs, the coils themselves, etc? And don't answer "yes" to this question, lol.
    Andrew
  11. thecarreaper
    Sep 30, 2003
    18,076
    Savannah
    Tommy, i am still learning a bit about Ferrari CIS ( i want a QV), but with the 02 unplugged, wont the car run dead rich? this would be bad for a cat equipped car i would think? i know some of us are exempt, but i would be careful with a cat installed, as a rich mixture could cause a fire .
    just wondering out loud.
    michael
  12. Martin308GTB
    Martin308GTB F1 Rookie
    Jan 22, 2003
    4,259
    Black Forest Germany
    Martin N.
    I once had the very same issue on my carb car. The culprit was one bad spark plug out of a brandnew set. Since this may be the easiest solution, I would try this first.
    Replace all plugs and look whether the fault persists.
    Best Regards from Germany
    Martin
  13. Dr Tommy Cosgrove
    May 4, 2001
    36,447
    Birmingham, AL
    Tommy
    I suppose so but I ran a test pipe for years. I have a Hyperflow now.
    I have had problems with these O2 sensors on 3 cars with K-Jetronic. When I bought them YEARS ago(including the Ferrari) they were all disconnected and every shop I asked all said just forget about it. Leave it alone. I hooked it up again in 2 cars last year just to see and I got a terrible surging. The thing to do is make sure the CO is dead on correct and it should correct this problem but I never could get either one to smooth out. I disconnected them and, once again, they ran just perfectly again.
    You make a good point, though. Something to think about before you do it.
  14. thecarreaper
    Sep 30, 2003
    18,076
    Savannah
    thank you for the reply, good to know!
  15. Andrew Bolton
    Aug 20, 2004
    155
    Spring, Texas
    Andrew Bolton
    Well, I pulled the leads out of the coils and they looked old and weathered. I cleaned them up nicely and replaced them. I think it's working now! The surge appears gone! I really can't say too much right now because immediately after my first modest acceleration, I got pulled over by a cop 1/4 mile from the house. I took the car right back home after that. But this weekend, I'll test it to see if this is was a cure.
    If so, it's the 0 cent fix!
    Andrew
