308QV Won't Start | FerrariChat
308QV Won't Start
Discussion in '308/328' started by Andrew Bolton, Apr 15, 2009.
  1. Andrew Bolton
    Andrew Bolton Karting
    Aug 20, 2004
    155
    Spring, Texas
    Andrew Bolton
    After sitting for a few weeks, I'm trying to start my QV and it just turns over and over and over. I don't smell gas at the exhaust tips and spraying engine starter into the air box does bring it to life for a few seconds--until the starter fluid is used up. Any ideas? And don't say "you're not getting gas"--I figured that one out on my own ;).
    Thanks in advance.
    Andrew
  2. Steve Magnusson
    26,626
    Do a search on "308QV safety switch" -- should get you the information you need to start troubleshooting your fuel pump operation (you did check the fuse, right?).
  3. shawxhurst
    shawxhurst Formula Junior
    Nov 6, 2006
    672
    San Diego
    Steve Hawxhurst
    Do you have the plenum hose installed? The car won't start if you've got the hose off, like for squirting in starter fliud
  4. Andrew Bolton
    Aug 20, 2004
    155
    Spring, Texas
    Andrew Bolton
    Plenum hose = yes.
    Safety swich = ???? (will research that issue)
    Thanks.
  5. finnerty
    finnerty F1 World Champ
    May 18, 2004
    10,406
    #5 finnerty, Apr 17, 2009
    First thing to do ----
    Disconnect the safety switch (it's the blue, 2-pin, connector on the side of the fuel distributor), and turn the key to "ignition on" (not start) position. You should be able to hear the fuel pump running. If not, follow Steve's lead to start making systematic electrical checks.
    Second ----
    If the pump is running, pull an injector, push down on the air flow sensor plate to see if you're spraying fuel. If you are, you've most likely got an ignition problem. If you aren't, you'll need to do a systematic fuel delivery check --- lots of threads on that.
    Likewise, there are lots of threads to guide you through checking out the ignition system if required.
  6. gilligan308
    gilligan308 Karting
    Dec 8, 2008
    141
    S.W.Florida
    Brian
    I'm going through my 82 308 this week end.I'll let you know what I find(same problem)
  7. Andrew Bolton
    Aug 20, 2004
    155
    Spring, Texas
    Andrew Bolton
    I KNOW that it's not getting fuel because it runs fine so long as I keep the starter fluid spray going into the air box :( but why is the question.
