Buy
308v4 or 328 intake CAD drawing
Discussion in 'Technical Q&A' started by atlantaman, May 26, 2004.
  1. atlantaman
    atlantaman Formula 3
    Mar 31, 2002
    1,726
    Roswell, Georgia
    Charles
    Anyone have an accurate CAD drawing of the top part of a 308v4 or 328 intake? I need to make some new gaskets from 1/4" rubber and need to get then water-jet cut. I did some aluminum spacers a while back and did some drawings in CAD but I would like to see what others may have done.
    Before i spend the $ to do the rubber pieces I want to be sure they are correct.
  3. FormulaRacer
    FormulaRacer Formula Junior
    Nov 18, 2003
    261
    Does the shop have a CMM? Just bring them the manifold if you have itoff,CMM it, and you can have one cut within the hour.
  4. atlantaman
    Mar 31, 2002
    1,726
    Roswell, Georgia
    Charles
    No CMM ---- I will probably have to machine an aluminum test piece from my drawing and try that--and make corrections----
    locally I have a company that does waterjet cutting of rubber gaskets and will take an autoCAD download--I just need it to be correct the first time.
  5. FormulaRacer
    Nov 18, 2003
    261
    Do you have access to any larger printers?
    You can print out straight drawings 1:1 of them, and tets fit them with paper before cutting them.
