30k 355F1 major engine out | FerrariChat
Discussion in '348/355' started by Extreme, Jan 21, 2012.
  1. Extreme
    Extreme F1 Rookie
    May 26, 2010
    2,515
    Northern Utah
    Erick
    #1 Extreme, Jan 21, 2012
    The engine is out! Now who wants to perform the major and put it back in for me?
    I spent the better part of 3 days getting this **** thing out. It was a lot more work than I expected. Next time I'm buying a lift.
    I missed one wire seems to be a ground wire or something, came out of the forward right corner and connected to the oil tank (I left the tank connected to the engine). Embarrassed to tell you about it, tore it in half. I've included a pic hopefully someone can tell me what it is for?
    I also discovered a wear spot in my power steering pipe. Not sure if it happened when removing the motor or was caused from friction with the bolt head, It was clearly caused by the bolt as you can see in the picture. I had originally disconnected the pipe from the pump and then after raising the car about 1 inch I realized I could get to the connection and undid it at the union on the firewall. I sure hope I can find a shop to build me a new one, because the Ferrari one is about $1k.
    looking at the pictures it appears the engine and cradle are sitting on the ground. They are on a furniture dolly. ;)
    It's late now and I am going to bed.:)
  2. FlyingAces
    FlyingAces Formula Junior
    Jun 2, 2011
    849
    LA 2 Vegas
    Joejoe
    Oh hell no,, looks like a headache from hell. Count me out.... though now is prob the best time for upgrades :)
  3. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    THAT'S WHAT I'M TALKING ABOUT!!!! Ata boy, way to man up and pull that sucker. You've gotten this far, you can surely do the rest. I know you can do it, just have confidence in yourself. Take your time and take plenty of pictures.
    As for that wire you busted, if a new one can't be made, I would just solder it back together and then put a heat shrink tube on it. But that is just me.
    Again, congratulations on the first step of your engine out major. Well done, and keep up the good work.
  4. mowater
    mowater Formula Junior
    May 24, 2004
    362
    this is so cool ... good luck with the est and be careful
    question: seeing as everything is out, will the car need to have the f1 bled and the clutch self calibrated again? or do you just bolt them back on
  5. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,546
    San Carlos, CA
    Mitchell Le
    Looks like the wire is the oil temperature sender connected to the bottom of the tank. And a lift will make that job much easier.
  6. TheMayor
    106,022
    Vegas baby
    If you think getting it out without a lift was a pain, try putting it back.
    Best of luck in your adventure!
  7. Ricambi America
    Sponsor Owner
    What is the engine resting on now? It almost looks like the engine is actually resting on the floor (or at least the brake discs look pretty darn close).
    p.s. In the final picture, I suspect the flash on your camera makes things look more 'rusty' than they actually are. If temps permit it, raise up the garage door and take a picture in some better light :)
  8. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,843
    Atlanta
    John!
    This is *the* best way to learn. Don't be discouraged and just be sure to keep yourself organized, clean, and ask lots of questions if something doesn't look right! Congrats to you. This is all part of the Ferrari IMO.
  9. White Knight
    White Knight Formula 3
    Aug 22, 2011
    1,531
    Ogden, UT
    Todd S.
    Looking good! Small steps in the right direction!
  10. Ovducati7
    Ovducati7 Karting
    Mar 27, 2011
    158
    Santa Barbara
    Oli
    So what do you need help with?? I might have that hose, I can look at the parts I have
  11. TexasKid
    TexasKid Formula Junior
    449
    Grabbing popcorn.
  12. ClydeM
    ClydeM F1 World Champ
    11,859
    Wayne, NJ
    Clyde E. McMurdy
    Think how much lighter your car will be without all those extra superfluous parts you'll have at the end of all this.
  13. sevminasyan
    sevminasyan Formula 3
    Jun 24, 2008
    1,156
    Glendale, CA
    Steve
    Looking good Erick
    I won't go into details now but a note for you when you put it back in. Once you remove the cradle, the subframe seems to split a bit. When its time to put it back in, help yourself and buy nylon strap from home depot if you don't have one yet and wrap it around the bottom rails where your six bolts are. You probably will need to pull the bottom rails closer together to be able to feed teh bottom six bolts it. This is due to having to install the cradle in the awkward position the car is sitting now. Just a strap, pull the frames closer together and feed teh bolts.
  14. Extreme
    Extreme F1 Rookie
    May 26, 2010
    2,515
    Northern Utah
    Erick
    Not sitting on floor there is a funiture dolly under it. The rotors are about 3 inches off the floor, the camera plays tricks.
    There is a small amount of rust nothing major that I can see. The picture does look worse than actual condition.
  15. Extreme
    Extreme F1 Rookie
    May 26, 2010
    2,515
    Northern Utah
    Erick
    To get the engine out the F1 pump had to be unbolted from the car and the electrical connections unplugged. I don't think it should have to be bleed and calibrated since the hydraulics are still connected.
  16. Extreme
    Extreme F1 Rookie
    May 26, 2010
    2,515
    Northern Utah
    Erick
    Take your time eating as this is going to take a bit. :)
  17. Extreme
    Extreme F1 Rookie
    May 26, 2010
    2,515
    Northern Utah
    Erick
    #17 Extreme, Jan 21, 2012
    Here is the part I need: #21
    I am thinking a hydraulics shop should be able to fix it what do you guys say?
  18. jhfields
    jhfields Karting
    Jun 2, 2010
    102
    paducah ky.
    John H Fields
    Great job Eric i wish i lived closer i would be glad to help, i have a 348 spyder and ill do my engine out in 2013, i bought a used 2 post lift just for my car, look forward to more pics, Regards John
  19. Extreme
    Extreme F1 Rookie
    May 26, 2010
    2,515
    Northern Utah
    Erick
    #19 Extreme, Jan 21, 2012
    I noticed the drivers side cam belt seems loose.
    Sorry the only video camera I have is on my iphone and for some reason it shoots small video.
    [ame]http://www.youtube.com/watch?v=ovaXw7B8dGk&feature=g-upl&context=G2d0e62aAUAAAAAAAAAA[/ame]
  20. Extreme
    Extreme F1 Rookie
    May 26, 2010
    2,515
    Northern Utah
    Erick
    #20 Extreme, Jan 21, 2012
    I found a crack in the cam belt cover on the passenger side. Should I worry about it or just let it be?
    When I took the cover off I only found one spacer is there supposed to be 2 like the other side?
    I hope you guys don't mind all my questions... I really appreciate the help.
  21. yelcab
    Nov 29, 2001
    13,546
    San Carlos, CA
    Mitchell Le
    The belt can be that loose depending on the position of the belt with respect to the rotation cycle. Nevertheless, you are now in a position to get it all right.
    The crack can be JB welded.
    You can also buy that stuff, including the hose, used on Ebay. I would not bet that the hydraulic shop can fix it.
  22. ndnbill
    ndnbill Karting
    Mar 3, 2009
    70
    Las Vegas
    William
    My thoughts and prayers are with you and
    "by the living Gawd that made you
    you're a better man than I am, Gunga Din."
    with apologies to RK
    dallastide likes this.
  23. treedee3d
    treedee3d F1 Rookie
    Apr 1, 2011
    3,726
    Montreal
    Fab
    Oh the humanity!!!
    You are one courageous Mother F$&ker
  24. Extreme
    Extreme F1 Rookie
    May 26, 2010
    2,515
    Northern Utah
    Erick
    Some of you make me feel as though I'm going off to battle a three headed fire breathing dragon. Isn't it just a car after all?
    I'll admit it is a bit intimidating but after I got in so deep there was no turning back. I'm always up for a challenge, figure if there is something I don't understand I'll ask the brothers of fchat
  25. saw1998
    saw1998 F1 Veteran
    Jun 8, 2008
    8,237
    San Antonio, Texas
    Scott
    I seriously envy you. There is nothing more fun and rewarding than working on your own car and doing everything perfectly. You have no time constraints and no reason to rush. I've got to put up a prefabricated steel building with multiple bays and a good quality 2-point lift. Since my divorce, I'm in a townhouse. I have three garages, but they are so small I can barely get out of my car, let alone work on them. :(
