30k 355F1 major engine out | Page 2 | FerrariChat
Discussion in '348/355' started by Extreme, Jan 21, 2012.
  1. UConn Husky
    UConn Husky F1 Rookie
    Nov 11, 2006
    4,425
    CT
    Jay
    Nice work there! yes the F1 system is fine, I did my engine out in the garage a few yrs ago, no F1 issues.
    It's common for the cam belt covers to crack (are you missing one? I'd replace that). Luckily mine weren't cracked, but I wouldn't worry about it.
  2. Extreme
    Extreme F1 Rookie
    May 26, 2010
    2,515
    Northern Utah
    Erick
    I have never done any hydraulic work I just can't imagine a hose like this would be that hard to make. It's nothing abnormal, although for some reason rather long. Anyone know why?
    I am continually amazed at the cost of Ferrari parts, many (probably most) of them aren't even manufactured in house. They are simply purchased and relabeled with the name. Some of the simplest things like bolts costing $250 give me a break! Anyway can you sense my frustration? I know there is an entire thread or many dedicated to this matter, I just needed to vent for a minute.
  3. Darkhorse575
    Darkhorse575 Formula Junior
    Mar 20, 2005
    634
    Pasadena, CA
    DJ
    Since you have chosen the red pill I'm sensing a frustration in the matrix. Good work, keep going.
  4. treedee3d
    treedee3d F1 Rookie
    Apr 1, 2011
    3,726
    Montreal
    Fab
    Make sure you figure out the part number you need and google the part number and the word Ferrari. You'll be amazed at the price differences online depending on who you order from.
    Some parts have a current part number and 1 or 2 previous part number(s). Make sure you google all of them and check eBay also.
    As an example, a fuel pressure regulator costs 1068$ from Ferrari and Rockauto sells the same part for 179$.
    Make sure you also check the interchangeable thread.
    Good luck and please post lots of pictures, this is better entertainment than anything on TV...
  5. mowater
    mowater Formula Junior
    May 24, 2004
    362
    Thanks guys, that is reassuring. :) I just had my F1 system bled and I self-calibrated the clutch at home so I would hate to have the car move from one shop to another based on who would have the required computer tools.
    Amazed? I think the word you are looking for is APPALLED. I find it really disgusting in this day and age for them to keep at it, as well as the ADs marking up some more.
    It really does take away from the Fcar ownership treat, for me personally at least.
  6. xpensivewino
    xpensivewino Formula Junior
    Jan 26, 2008
    960
    Simi Valley CA
    Need to know basis
    You are doing a great job....just stick with it and take your time. Any reputable hydraulic hose shop can reproduce that line. I have had dozens produced over the years for high performance Turbo applications on my 911's, by Orme Bros. in North Hollywood California, without incident. Just shop around, and I'm sure you will find one in your local area.
  7. mikeyr
    mikeyr Formula 3
    Jun 17, 2004
    2,154
    Santa Barbara, CA.
    Mike Rambour
    How high do you have to get the backend of the car for the motor to slide out ? it does not look very high (ok, I am sure much higher than was fun to do) and I have been looking at a MaxJack 2 post lift but it only lifts 48" max ( http://maxjaxusa.com/specifications.html ) Would a MaxJack be high enough to remove the motor ?
    I doubt my wife would let me buy another full size lift as I already have a 4-post and I assume you can't do a engine out with the 4-post. The MaxJack seems to be the one for me, I could put it under the carport which is not as good as the garage but probably more convenient for using it often on oil changes on the daily's, right it always means moving cars around and the one on top of the lift does not run, so I end up changing oil on the ground. I do have a mid-rise lift also but I doubt it would work for the engine out, there is too much junk underneath, or has someone done it with a mid-rise ( http://www.bendpak.com/car-lifts/specialty-lifts/MD-6XP.aspx )
    Yeah, I don't have a 355 yet either but I could have the lift this week as the concrete pad is going to be poured Tuesday for the carport and I planned on a 2-post in that area. Before the wife said no to a ugly permanent lift.
  8. 166&456
    166&456 Formula 3
    Jul 13, 2010
    1,723
    Amsterdam
    #33 166&456, Jan 22, 2012
    Well done, nice work, should be very rewarding once it's all back together again. Interesting to see so many people here seem to scare away from work like this. Doing a major on this model without a lift is indeed brave though.
    As for the play in the cambelt, make sure to really check both lower cogs in the timing system for any play, the bearings behind them are known weak spots and if one fails it will cause you serious headaches. Good luck.
  9. Extreme
    Extreme F1 Rookie
    May 26, 2010
    2,515
    Northern Utah
    Erick
    It can and has been done with a four post lift.
    check out this thread. http://www.ferrarichat.com/forum/showthread.php?t=234071&highlight=bleeding+cooling+system+355
  10. JeremyJon
    JeremyJon F1 Veteran
    Jul 28, 2010
    7,569
    Calgary, Canada
    Erick, good on you man! :)
    ...it "is" just a car, like any other, meant to be serviced, sometimes with specific tools (my old 944 was bad for that), and can be worked on like any other
    :thumbsup:
  11. want2BSchumi
    want2BSchumi Karting
    May 22, 2008
    86
    Los Angeles, CA
    Russell
    #36 want2BSchumi, Jan 22, 2012
  12. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    I gotta get a MaxJax.
  13. Extreme
    Extreme F1 Rookie
    May 26, 2010
    2,515
    Northern Utah
    Erick
    YEP!
  14. Extreme
    Extreme F1 Rookie
    May 26, 2010
    2,515
    Northern Utah
    Erick
    #39 Extreme, Jan 23, 2012
  15. since-15
    since-15 Formula 3
    Nov 26, 2008
    1,142
    Nicely done! Keep at it and take your time. I appreciate that you are sharing/documenting everything. I can't wait to see it finished. Outstanding!
  16. osuav8r
    osuav8r Karting
    Feb 16, 2005
    142
    Houston, TX
    Alan
    I'm not yet a Ferrari owner, but when my Viper needed the transmission pulled, we went ahead and bought a two post Eagle lift and it has been great. It is heavy gauge steel and seems to be really well made. The only issue I had with it was that one of the orings on the hydraulic fittings had been crushed and deformed so the connection leaked kind of bad until I put a new o-ring in there, but other than that, it is reliable, solid and a great help when working on vehicles. They were running a sale when I bought it and it was like $1450 plus like $200 for shipping to the freight terminal where I picked it up with a trailer. They loaded it onto the trailer with a forklift and we were able to partially unpack it on the trailer to reduce the weight and finish unloading it and installing it with a cherry picker and two guys. It uses 220 volts, but most lifts probably do. Install was pretty simple with the supplied instructions and after renting a large hammer drill to install the large anchor bolts into the concrete. If I had known how cheap they were, I would have got it a LONG time ago and I've already used it enough to have got my money's worth out of it. I always assumed a lift would be $5-6000 minimum, but this one has been more than adequate for anything I've thrown at it and I wholeheartedly recommend it to anyone with a shop in their home. Sorry for the drift, but I thought you guys trying to do your own engine outs might find it useful. I expect to be in your shoes one day :)
  17. Extreme
    Extreme F1 Rookie
    May 26, 2010
    2,515
    Northern Utah
    Erick
    Took the air boxes off today along with fuel rails and injectors. Mailed the injectors off to "Mr Injector" for a good cleaning. Not sure if they needed it or not just figured it couldn't hurt.
    I noticed my throttle bodies had some gunk on the butterfly valves. And when looking in could see a bit of gunk on the valve heads. Is there anything I could put in the throttle bodies to help clean them and the valves?
  18. Extreme
    Extreme F1 Rookie
    May 26, 2010
    2,515
    Northern Utah
    Erick
    Also I have been wondering if during reassembly there are any Bolts that need thread locker (locktite)?
  19. Saleen
    Saleen Karting
    May 30, 2005
    70
    Wisconsin
    C
    Putting a small amount of locktite on the obvious nuts and bolts wouldnt be a bad idea. Anything that holds parts together with a gasket would be the general rule. You don't want them loosening up and creating a seal leak.
  20. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Nope.
    Only nuts that need Loctite are inside the gearbox.
  21. Extreme
    Extreme F1 Rookie
    May 26, 2010
    2,515
    Northern Utah
    Erick
    Thats the info I was looking for
    thanks ernie
  22. cactussed
    cactussed Formula Junior
    Mar 12, 2008
    299
    Well done that man. I found getting the crank pulley bolt off a righ bugger, had to buy an impact gun for the job.
    Other than that, take your time as its a lot easier to work on when it's out.
    Make sure you do the obviou things like tensioner bearings as well as just belts. If the belt is loose, you may want to do the tensioners as well.
    I'd do the alternater tensioner bearing as well. It's cheap but is a bugger to do in-situ.
    Check the condition of engine and gearbox mounts.
    also, give the engine cradle/frame a thorough going over and check for any signs of rust, especially at the base of the uprights.
  23. UConn Husky
    Nov 11, 2006
    4,425
    CT
    Jay
    To clean the butterflies I used a GM 'top end' cleaner, recommended to me by DHelms. Works great, smells horrible ;)
  24. brian.s
    brian.s F1 Rookie
    Nov 3, 2003
    3,809
    Midwest
    Brian
    And becoming hard to find.
  25. Extreme
    Extreme F1 Rookie
    May 26, 2010
    2,515
    Northern Utah
    Erick
    Where do I find it, GM dealer?
    I'm currently waiting for my gaskets and belts to arrive from Ricambi then it’s time to put it back together. I had the injectors cleaned they should be here any day as should the water pump.
    As for the valve timing it seems deed on. I found TDC on #1 cylinder and all the cam marks line up perfectly with the factory marks. Should I do anything else? The car was running fine before. I would hate to mess something up. :)
