30k major started! | Page 2 | FerrariChat
30k major started!
Discussion in '348/355' started by troy_wood, Oct 25, 2008.
  1. PAP 348
    Dec 10, 2005
    100,232
    Mount Isa, Australia
    Pap
    Cool pics man! :):)
    I thought you could leave the a/c comp in there. Someone once told me that you can and it was VERY VERY hard to leave it leave it in there and remove the engine. :):)
    But when I do mine, I was thinking of leaving it in there because my a/c is ICE COLD and I do not want to spend another $200+ getting it charged up again seeing as I only did it the start of this year. :):)
    Looking forward to hearing about your little trick Troy. ;);)
  2. fatbillybob
    Aug 10, 2002
    29,272
    socal
    Troy nicely done so far but you are doing way too much work. If all your new parts are ready you can just support the subframe on big wood blocks and never move it. With a lift you can lift the car right off and then do the service and lower the car right back on and the holes nearly line up perfectly. The moving dolly is great if you have to move the shell of the car to free up the lift or if you are doing the service without a lift.
  3. Oengus
    Oengus F1 World Champ
    Awesome pics Troy!
    Keep em comin
  4. saw1998
    saw1998 F1 Veteran
    Jun 8, 2008
    8,237
    San Antonio, Texas
    Scott
    Thanks for taking the time to post these pictures, Troy! Man, I envy you! I am really looking forward to my 30K service in 1.5 years, but I've got to get a lift ASAP. Hope everything continues to go "slick as snot"!
  5. troy_wood
    troy_wood Formula 3
    Apr 28, 2007
    1,457
    Nova Scotia, Canada
    Troy Wood
    Heya Pap - my aircon is just fine as well and I didn't want it touched. When I first contemplated leaving the compressor on the car my first thought was that the a/c tension adjustment bracket would have to come off to give the compressor tubes a pathway to rest against the firewall thus allowing the the engine to pass right by the still-connected compressor on removal. I didn't like this idea because of the extra time factor and I wanted to stay away from removing any nuts that affected gaskets (the tension adjustment bracket has 3 commonly shared nuts front crank cover that is obviously gasketed). So it looks impossible because the gap between the tip of tension adjustment bracket and the subframe is about 3/4" and the sleeved a/c tubes (very stiff compound) looked about 1-1/4". The answer was in sliding the insulation sleeves up as high as possible, putting a little grease on the exposed hoses and with a little pressure they will pop past the tension adjustment bracket and rest nicely against the firewall. While the car is being raised off the engine you can turn the compressor 90 degrees and the engine clears perfectly with no prying, banging or grinding. For some reason the hoses don't look like they will pass through this gap but they actually do quite easily.
  6. VIZSLA
    VIZSLA Four Time F1 World Champ
    Jan 11, 2008
    41,693
    Sarasota
    David
    Looks like a place where real work is done. Good luck and keep us posted.
  7. troy_wood
    troy_wood Formula 3
    Apr 28, 2007
    1,457
    Nova Scotia, Canada
    Troy Wood
    Thanks FBB... I didn't really know what to expect getting into this. When I saw Weasels cart I thought it looked like it would give me maximum flexibility if I was to run into any unforeseen problems either during removal or installation. I am a weekend warrior and a fair bit away from a stooge! The only other thing I was thinking about is that I like the idea of rolling it over to the threshold of the opened garage door to do the actual service - I like a lot of bright natural light so I can see and internalize every little detail of my engine. If I am going to degree my cams as you recommend (versus cheat and simply line up the marks) I am going to need all the advantages I can. (I still might wimp out on this one actually). I appreciate the input.
  8. troy_wood
    troy_wood Formula 3
    Apr 28, 2007
    1,457
    Nova Scotia, Canada
    Troy Wood
    Thanks Scott. I have been looking forward to mine for a long time now. I wasn't exaggerating on how fun it actually is. There's just something awesome about working on your own Ferrari. Lifts are cheap - mine is a 9'3" base plate model with a lifting capacity of 9000 lbs. Sweet 355 man!
  9. fatbillybob
    Aug 10, 2002
    29,272
    socal
    OK... just be careful the subassembly on 4 jacks on the cart is a potential hazard. I hope the jack feet are attached to the cart????? If they are free I could see the whole thing falling and killing you.
  10. troy_wood
    troy_wood Formula 3
    Apr 28, 2007
    1,457
    Nova Scotia, Canada
    Troy Wood
    lol - holes drilled in the jack bases going right into cart on all 4 posts.
  11. UConn Husky
    UConn Husky F1 Rookie
    Nov 11, 2006
    4,425
    CT
    Jay
    Great work Troy, keep the pics and tips coming!
  12. fatbillybob
    Aug 10, 2002
    29,272
    socal
    Good! I see all kinds of crazy things. Not too long ago a guy on Fchat was using cinderblocks as jackstands
  13. PAP 348
    Dec 10, 2005
    100,232
    Pap
    Cool man! ;);)
  14. johan6504
    johan6504 Formula 3
    Jun 28, 2005
    1,168
    Sweden
    Johan
    Do you know if this can be done on the 355 as well?
  15. troy_wood
    troy_wood Formula 3
    Apr 28, 2007
    1,457
    Nova Scotia, Canada
    Troy Wood
    Not sure about the 355 Johan. Someone out there must know.
  16. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    I was curious about this as well as I will be doing my major out on my 355 this winter.
    I think I may unbolt the compressor to see how much latitude there is to move it around.
  17. PAP 348
    Dec 10, 2005
    100,232
    Pap
    Thats what I would do, have go and see what happens. :):)
  18. troy_wood
    troy_wood Formula 3
    Apr 28, 2007
    1,457
    Nova Scotia, Canada
    Troy Wood
    #43 troy_wood, Nov 8, 2008
    The new belt and tensioners are on - I was at it for a good 10 hour stint but finally got it done. Belt was going on difficult until I realized that the dynamic tensioner had to be compressed ALL THE WAY and held with a large tie strap. I also came to realize (with the help of a friend) that the tensioner had to be inserted only after the rest of the belt was seated and held in place with the help of delicately placed soft tip clamps. Yes, I had to take it off after the first attempt.
    The tensioner and idler bearings were bad - all kinds of play laterally. My engine is pretty dry with only the slightest of dry seapage around the front. I can't tell whether its from the cam seals or the rtv sealant. In any case I decided to leave it alone this time around. I know you all are probably thinking 'incomplete job' but I hand my hands pretty full for my first major. I have also come to realize that in order to really do the full meal deal (complete with detailing) you need a lot of time and you can't be rushed. I'm looking at the job Rick in doing and I feel like I am coming up short... The only other thing I am going to do is inspect the oil chain tensioner. Hopefully I will be okay with this scaled-down 30k.
    Two questions and I hope they are not a really stupid ones:
    1. After everything was back on I turned the crank 20-30 times to seat the belt and I noticed the belt alignment on all the cogs was different than that of my original belt. Is this okay?
    2. Is the timing belt directional?
    I will post pics tomorrow guys - I'm burnt.
  19. PAP 348
    Dec 10, 2005
    100,232
    Pap
    *cough cough* Use a degree wheel *cough cough* :D:D
    If that paticular belt is directional, it will have arrows on it telling you which way the belt goes. I have seen both, some with arrows, some without. If there isnt any arrows on the belt, I put them on with the stamped writing facing outwards (so you can read it). :):)
    Looking forward to it mate. :):)
  20. troy_wood
    troy_wood Formula 3
    Apr 28, 2007
    1,457
    Nova Scotia, Canada
    Troy Wood
    Heya Pap - sorry, not the timing marks, those are spot on. I mean't the whole belt is centered in the middle of the cam gears whereas the leading edge of the old belt came out flush with the edge of all the cam gears.
  21. PAP 348
    Dec 10, 2005
    100,232
    Pap
    Ohhhhhhh, dont worry about that! Thats nothing. ;);)
  22. troy_wood
    troy_wood Formula 3
    Apr 28, 2007
    1,457
    Nova Scotia, Canada
    Troy Wood
    cool - thanks.
  23. troy_wood
    troy_wood Formula 3
    Apr 28, 2007
    1,457
    Nova Scotia, Canada
    Troy Wood
    Just started my baby up after my 30k - I am walking on air right now... I took about 6 attempts to re-introduce the fuel but she burst right to life. Everything sounds, feels and smells as it should. There are no oil, fuel or coolant leaks yet - I will go look again after it cools down. I let it run for 30 minutes. I had one hell of a time bleeding my clutch.
    I have learned so bloody much from doing this service - I can't believe how much I know about the 348 now. Never would of happened if I didn't go through this.
    Anyway, I sort of abandoned my thread awhile back because things were going slow and I hit a lot of stumbling blocks but I have kept a diary of my whole 30k experience and I will add it shortly.
    This has been a huge accomplishment - alot of people around me said I was crazy for attemping an engine out service. I can't thank all you enough for doing some real heavy lifting for me.
    Yeehhaaaaa!
  24. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    Congratulations on the post 30k startup :)!!!!!
  25. saw1998
    saw1998 F1 Veteran
    Jun 8, 2008
    8,237
    San Antonio, Texas
    Scott
    #50 saw1998, Feb 20, 2009
    Troy:
    Congratulations!! You should really feel proud of yourself, as this is a serious accomplishment in the "mechanical arts". I know everybody says, it's just car car, but you're not looking at a 35K rebuild if you screw-up your Ford Focus! LOL! Plus, you're up in the "boonies" far, from Independent Ferrari Tech. I'll post this picture I stole from Pap:
