312PB technical specs | FerrariChat
Discussion in 'Vintage (thru 365 GTC4)' started by tomgt, May 21, 2004.
  1. tomgt
    tomgt F1 Veteran
    7,159
    Netherlands
    Tom Wiggers
    Does anybody know the wheelbase and rim sizes of the 312 PB's?
  2. Boudewijn
    Boudewijn F1 Rookie
    May 15, 2003
    4,133
    The Netherlands
    Boudewijn Berkhoff
    Wheelbase 2220 mm (87.4 inches), track 1560 mm (61.4 inches) front, track 1570 mm (61.8 inches) rear. Length 3770 mm (148.4 inches). Width 1960 mm (77.1 inches). Center lock Campagnolo cast magnesium-alloy slotted disc wheels, 13 inch front and rear (1971), 13 inch front and 13 or 15 inch rear (1972), 13 inch front and 13 or 15 inch rear (1973)
  3. model builder
    model builder Formula Junior
    Oct 15, 2003
    315
    Long Island, NY
    Edward Cervo
    I don't think the 312PB ever ran a rear tire with a 13 inch diameter. I have lots of pics from the early races but they are too large to post here. All show the car with larger diameter rear tires. I am pretty sure the fronts are 13's as you stated.
    Ed
  4. Boudewijn
    Boudewijn F1 Rookie
    May 15, 2003
    4,133
    The Netherlands
    Boudewijn Berkhoff
    I've absorbed the information about the disc wheels from Boxer, the Ferrari flat-12 racing and GT cars by Jonathan Thompson.
  5. Gilles
    Gilles Karting
    Aug 10, 2003
    236
    South of France
    In my doc, only the car (312P/B-74) seen in test at Paul Ricard in December 1973 seem had rear and front wheels identicals. But 13" or 15" ? Seems littles ??
    On the photo I have the first protopyp (Alu) had the same wheels as 312P.
    Gilles
  6. model builder
    Oct 15, 2003
    315
    Long Island, NY
    Edward Cervo
    His info on that page must be mistaken. I have the book. The info you quoted is as you said, on page 179. However if you go to page 122 and look at the very last paragraph he states the rears were 15's. No mention of 13's for the rear anywhere in the chapter. Also if you look on page 124 and 125 (in fact all the pics in that chapter) you can clearly see the size differences in the rims. I am sure the fronts are 13's as the 312PB is a very small car but also during that time they were experimenting with very small front tires. Remember the Shadow from Can Am? Looked like a toy.
    Ed
