News
328 ABS fuse missing ?
Discussion in 'Technical Q&A' started by F328GTS/GTB, Jun 19, 2009.
  1. F328GTS/GTB
    F328GTS/GTB Formula Junior
    May 3, 2005
    517
    France
    Denis
    #1 F328GTS/GTB, Jun 19, 2009
    One fuse seems to be missing on the black relay.
    I have only partial wiring diagram (scheme is missing) so I cannot check.
    What do you think about ?
    Thanks,
  3. No Doubt
    No Doubt Six Time F1 World Champ
    May 21, 2005
    67,323
    Vegas+Alabama
    Mr. Sideways
    Installing a 10 Amp fuse there should disable your ABS while driving, but allow trouble codes to be "flashed" onto your dash, presuming that you have a stock 1989 328 with the same ABS as the 1989 to 1995 348s.
  4. jonesdds
    jonesdds Formula 3
    Aug 31, 2006
    2,160
    SB,CA & Park City UT
    Jeff
    Mine is missing like that as well. I had no idea that you disable ABS that way. I'd be curious how the brakes feel without the ABS. I assume it would be easy to tell the difference. Mine have kind of an artificial feel to them, not the right word for what I feel but couldn't thick of anything more descriptive. Not a direct correlation between pressing the pedal and the amount of braking, a disconnected feeling. I assume it's the ABS as the 308's I've driven feel very different.
    Jeff
  5. fastradio
    fastradio F1 Rookie
    Professional Ferrari Technician BANNED
    Apr 26, 2006
    3,652
    New England
    David Feinberg
    With or without the fuse in, the brake pedal will feel the same on an ABS-equipped 328. Unlike the 308, the 328 with ABS does not use a vauum booster to reduce pedal efffort, but rather, in essence, a hydraulic-assist unit. In my opinion, a 328 with ABS has a very "hard" brake pedal, versus a much softer one as found in any 308, or non-ABS 328.
    David
  6. Marco Bussadori
    Marco Bussadori Formula Junior
    Aug 6, 2007
    430
    London
    Marco Bussadori
    Normal mode is no fuse installed. When the ABS unit is tested for maintenance, a 10A fuse is inserted and the ABS unit will go into test mode, flashing various codes as various pins are connected on a test board which is connected between the usual plug and the ABS unit.
    I have the full diagnostic sheets and test board for the 348, which uses the same Teves ABS unit.
    Marco
  8. F328GTS/GTB
    May 3, 2005
    517
    France
    Denis
    Thanks for all your answers Ferraristi.
  9. Jon22
    Jon22 Karting
    Sep 4, 2004
    110
    Uk
    Jon
    The missing fuse is only inserted to run tests on the ABS as it is is normal.
    The car is fine.
