I just want to double check the part numbers on US Spec 328s for the basic kit: Clutch cover #121562 Clutch plate #134996 Clutch bearing(?) #100849/A Bearing carrier (t/o?) #116326 Are the rest: Bearing carrier #116326 Oil Seal #134714 Pilot bearing #103877 Shaft nut #153066 Crank oil seal #163989 Do you need all of them? Or just the first few? Which is the t/o bearing? I am going to get my clutch job done by WWOC in the spring; but I want to buy all the parts now since I am going to be buying other parts at the same time. Thanks for the heads up!
