328 exhaust "electronics" question...... | FerrariChat
Discussion in '308/328' started by Fiat4Fun, Nov 3, 2017.
  1. Fiat4Fun
    Fiat4Fun Formula Junior
    Jul 1, 2008
    312
    Sunriver OR
    Bob
    Greetings all.
    Have been too busy working, but still getting the 328 out for a drive every now and then. Have not been active on the forums, so maybe I missed something. A while back, there was a discussion about reverse engineering the little black box that has a sensor in the exhaust that controls the "slow down" light.
    I wanted to see if that has been discussed anymore, or if someone actually has worked something out.
    On my last drive, my light was on / off for about five miles total, out of my 100 mile drive.
    Thinking that if someone has a option to replace the "black box" in the trunk, I might go do that this winter.
    Any advice would be appreciated.Enjoy
    Bob
  2. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,687
    Mike 996
    Cant help with the answer but DEFINITELY would like to see if any progress has been made in "re-creating" the slow down module. It's been quite a long time now since someone on the site posted that they had sussed it out and was going to be able to make the module but it all just faded away. I have a lot of experience with vintage electronic repair and, it seems to me, if someone figured out the specific circuitry/parts necessary, anyone that is capable with a soldering iron/circuit board could assemble the parts to do the job though, of course the module wouldn't look like the OEM module.
    But I, as you, are hoping that something eventually comes of this!
  3. Lawrence Coppari
    Lawrence Coppari Formula 3
    Apr 29, 2002
    2,151
    Kingsport, TN
    Lawrence A. Coppari
    Let me first state that I am not an electrical engineer so perhaps I oversimplify. But rather than attempting to reverse engineer the troublesome sealed module, why not merely design a circuit that turns on the slow down light when the leads from the thermocouple exhibit an emf that corresponds to a temperature that is above a safe threshold. The circuit would be completely independent of anything else.
  4. Motob
    Motob Formula 3
    Nov 11, 2003
    2,238
    Frederick, Maryland
    Brian Brown
    Both versions of the slow-down ECU 1985-87, and 1988 are shown to be available from Ricambi. Why don't you just buy a new one?
  5. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    12,661
    San Carlos, CA
    Mitchell Le
    And if there is overheating in the cat converter, then you definitely want to know about it.
    thorn likes this.
  6. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,687
    Mike 996
    If the module is now available from Ricambi, then, of course, that takes care of the issue! Last time I checked, which was probably a year ago, the only replacement modules were modules taken off an existing car and since they are well known to fail, it made no sense to buy a used one. That's why there was considerable interest here when someone said they had figured them out and could make them though nothing came of it.
  7. andyww
    andyww F1 Rookie
    Feb 7, 2011
    2,775
    London
    Back at the time this was discussed before I contacted Ferrariparts and asked if they would be interested in having these duplicated as an official part, for 355 specifically. The answer was they already had someone else working on it, so if they are now available it seems this was done.
  8. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,084
    SanFrancisco BayArea
    1983 US 308 GTS QV
  9. Fiat4Fun
    Jul 1, 2008
    312
    Sunriver OR
    Bob
    Thanks for the information. Sounds like factory ones are still an option, and that seems like the best way to go. I was curious if anyone has tried the "home made" version that was discussed earlier?
  10. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,687
    Mike 996
    I was under the impression - possibly incorrectly - that no one had actually produced a home made version that actually worked or, at least if they did, they didn't explain the circuitry so that the "rest of us" could cobble together a working replacement module.
  11. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,378
    The Cold North
    Tom
    There are many stand alone egt kits out there. And they are pretty cheap compared to the Ferrari stuff which is basicly junk anyway.
  12. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,687
    Mike 996
    AFAIK, there are NO stand-alone aftermarket egt kits that restore the OEM function of the slow-down light system on these cars. If you want something that provides the info and you are OK with a hang-on/bolt on display or gauge of some sort, then certainly, many options are available; there's one on Amazon for 20 bucks! It all comes down to whether you want it to work as OEM or you are OK with an added readout device somewhere in the cockpit.
  13. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,084
    1983 US 308 GTS QV
    #13 Brian A, Nov 14, 2017
    FChat member "jmaz" (Jim) has analyzed working modules from both his 328 and my 308 and has reverse-engineered working prototypes. He has schematic drawings (as well as his home-built prototypes) of the modules. He is a university professor and not much into production and marketing; he just likes figuring out how things work.
    As I posted earlier, here is the thread discussing the system:
    https://www.ferrarichat.com/forum/threads/interest-in-slow-down-light-cat-ecu-substitute.498691/
    As Jim explained to me, the modules don’t do much; they just receive the thermocouple voltage as an input and, at a trigger voltage, sent a power signal to the Slow Down Light bulbs. The modules could easily be made so that the lights begin blinking as the cats near critical temperature and then light constantly as the critical temperature, or could blink out messages in Morse code for that matter.
    I would suggest PMing jmaz and see what his plans are for building the modules or posting the schematics.
    EDIT:
    I have Jim's personal email id and have emailed him alerting him to this thread.
  14. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,084
    1983 US 308 GTS QV
    #14 Brian A, Nov 20, 2017
    I got an email response from Jim. He has not been checking FChat lately, but intends to post a reply sometime in the near future.
  15. Fiat4Fun
    Jul 1, 2008
    312
    Sunriver OR
    Bob
    Brian
    Thanks for your response and for getting the information.
    Look forward to hearing from Jim
    Enjoy your Thanksgiving........
  16. jmaz
    jmaz Formula Junior
    Jun 27, 2011
    350
    Colorado
    Jim
    Things are moving forward on the cat ECU replacement effort. I'll hopefully have some concrete news to post within a couple of months.
