News
328 Gear Knob Removal
Discussion in 'Technical Q&A' started by F328, Jul 29, 2004.
  1. F328
    F328 Karting
    Jul 7, 2004
    65
    Midlands UK
    Graham
    As a novice and not wanting to break anything is it easy getting the old gear knob off a 328 GTS. Tried unscewing but didn't seem to want to move.
    Any advice appreciated
  3. Ricambi America
    Sponsor Owner
    There's probably a little hex nut on the at the bottom of the shifter ball. Also, make sure you're not also turning the whole metal shaft while trying to turn the knob itself.
    My eyesight is kind of lame, so I put a small piece of masking tape on the shaft, then when I tried to turn the shift knob, I could tell if the whole shaft was turning.
  4. PWehmer
    PWehmer Formula 3
    Oct 15, 2002
    1,733
    Surrounded by Water
    If you look at the base of the shift arm there are wrench flats there- I think a 13mm. Hold the arm from torqueing.
    Loosen jam nut under the knob.
    A rubber strap wrench will turn the knob without damaging it.
  5. Robertb
    Robertb Formula 3
    Nov 19, 2003
    1,330
    South Oxfordshire, U
    Robert
    It just unscrews- the nut underneath the knob is to hold it in position i.e. so the shift diagram on top is oriented properly.
    Robert.
  6. F328
    F328 Karting
    Jul 7, 2004
    65
    Midlands UK
    Graham
    Thanks everyone for replies - looks like a bit more force required! I'll get the super glue out ready!
    Cheers
  8. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,074
    Southeast USA
    Mike Charness
    If you break yours, you can get a Ferrari-sized and threaded aluminum or titanium one from www.TeamVoodoo.com here in the USA or sponsor Paul Hill in the UK. Or a carbon fiber knob from sponsor Sodacom.
  9. jimpo1
    jimpo1 Two Time F1 World Champ
    Silver Subscribed Owner
    Jul 30, 2001
    22,080
    Dallas, TX
    Jim E
    Buy the team voodoo knob even if you don't break it. It's a great knob.
  10. BWS550
    BWS550 Wants to be a mod
    Apr 1, 2002
    8,933
    NEW JERSEY
    BRUCE WELLINGTON
    BUY THE SHIFTER KNOB FROM PAUL HILL, ITS A GREAT KNOB. :)
  11. jimpo1
    Jul 30, 2001
    22,080
    Dallas, TX
    Jim E
    And Bruce know's all about GREAT KNOBS! :D
  13. F328
    F328 Karting
    Jul 7, 2004
    65
    Midlands UK
    Graham
    Thanks guys - bought the knob from Paul Hill - should be here Monday.
    Cheers
  14. matkat
    matkat Formula 3
    Mar 18, 2003
    1,840
    Scotland
    Dave McGuire
    Graham,when I had a 328 I bought both the knob and a slick shift gear gate from Paul the shift gate is great to,you will not be disappointed.
    Dave Mc
  15. Jdubbya
    Jdubbya Two Time F1 World Champ
    22,131
    PNW
    Don't forget the gate lock and aluminum pedals!! Great products, even better People!!!
  16. F328
    F328 Karting
    Jul 7, 2004
    65
    Midlands UK
    Graham
    Dave
    Thanks for your advice. Had already ordered the gear knob which arrived today. Based on the quality of this I am ordering the quick shift now. Why didn't Ferrari put similar items on as standard?
    Regards
  17. Chiaro_Slag
    Chiaro_Slag F1 Veteran
    Oct 31, 2003
    7,731
    CA
    Jerry
    Yep, I had the Paul Hill knob also - It is great! Just use a wrench to hold the hex nut and the stock knob will turn.
