328 GTS - How to remove passenger seat | FerrariChat
Discussion in 'Technical Q&A' started by RealMenDriveFerraris, May 23, 2018.
Tags:
  1. My car stereo no longer works, and I need to remove the passenger seat to get at the equipment. All I can see and get to are two bolts on the front of the rails. How do I get access to the back two bolts? I tried moving the seat all the way forward to no avail.
  2. Glassman
    Glassman F1 World Champ
    Same size bolts at the back. Just find them.
  3. ferrame
    ferrame Formula 3
    Mar 2, 2005
    1,193
    Orange, Calif
    The seat should be moved forward far enough to get access to the bolts unless the rail got stuck.
    I had removed both driver and passenger seats before.
  4. maurice70
    maurice70 F1 Rookie
    Jan 25, 2004
    4,313
    maurice T
    The stereo can be easily removed without removing the seats though..
  5. thorn
    thorn F1 Rookie
    3,322
    Tallahassee, FL
    Why? Just curious.
  6. dinonz308
    dinonz308 Formula Junior
    857
    Dean
    I'm guessing he has amps under the seat?
  7. Motob
    Motob Formula 3
    Nov 11, 2003
    2,238
    Frederick, Maryland
    Brian Brown
    Sometime the seat rails/mechanism will jam, not allowing full movement of the seat. You can try lubing the rails to see if it helps you allow access to the bolt. Even with full movement, there is not much access to the bolt heads. I have cut down an allen wrench to allow better access to the bolt head.
