328 OEM Hood Strut | FerrariChat
328 OEM Hood Strut
Discussion in 'Technical Q&A' started by Ron328, Nov 25, 2003.
  1. Ron328
    Ron328 F1 Rookie
    2,609
    Willamette Valley, Oregon
    Ron
    For those who need new gas-charged lift support (hood struts) for their 328's (or Fcars for that matter). Check out the website (www.sachsna.com); they are the OEM. Their distributor in NJ is "Parts For Imports" (856)-665-2300.
    For 328's, it is Part # SG437002 ($34.46) for the front and #SG237001 ($41.75) for the rear. You'll pay at least $60 per piece if you get it from Ferrari sources. The labels are the same except that no "Ferrari" is imprinted on the former.
    I just installed a new one on my 328's front. It is a 5-minute procedure. Just make sure you put something below your workplace as the washers, nuts, and bolts may drop into the radiator compartment and may be difficult to retrieve. And do not overtighten the bolts...guaranteed to break. It is a perfect fit...even though the "main body" of the strut appears to be about 4mm longer.
    (One of our fellow fchatter, ShanB, installed new ones on his 348 and reported perfect fit, too).
    The rear maybe more difficult to install as the struts are not attached by simple "bolt and nut" mechanism. Has anyone done this? Any info would be appreciated.
    Thanks,
    Ron
  2. MARQ
    MARQ Formula 3
    Feb 9, 2002
    1,924
    East Coast US
    Marq
    #2 MARQ, Nov 25, 2003
  3. f355spider
    f355spider F1 World Champ
    17,860
    My mechanic sold me a oem "Ferrari" hood strut for my 328 front hood for $31...so not sure where the $60 comes from, maybe FNA dealers? I got mine from Alfa of Tacoma, in Tacoma, WA. 253.572.2532
    Carlo, the master technician and owner, recommends replacement of all 308's and early 328's to the gas strut to prevent bending of the hood. Some here have worried that based on the strength/resistance of the gas strut, there is still risk of bending the hood, but I seriously doubt that is the case...no problems for me in the past year since the change over.
  4. Ron328
    Ron328 F1 Rookie
    2,609
    Ron
    So how did you guys remove the "bolt and nut" mechanism
    to install the new rear struts?
  5. Ron328
    Ron328 F1 Rookie
    2,609
    Ron
    I couldn't edit or add to my post above.
    The pins (part # 60599500) and clips (#11087876) that mount
    the rear struts...are they reusable? (It is NOT THE SAME bolt and nut
    that is used to mount the front strut.) Anyone?
    Thnx.
