328 OIL | FerrariChat
328 OIL
Discussion in 'Technical Q&A' started by Dla, Jul 21, 2004.
  1. Dla
    Dla Karting
    104
    Jacksonville FL
    Lee Anderson
    I know this subject has been worn out, but I am about to change the oil in my 88 328. I have a few 'spot' drips (leaks) now. I am thinking of using Mobile 1 15W50 synthetic. Does anyone have any recent info, stories, or increased leaks due to synthetic oil?
    Thanks,
    Dla
  2. AJS328
    AJS328 F1 Veteran
    Apr 23, 2003
    7,520
    New Jersey
    Augustine Staino
    My old 328 started to leak a little bit after I changed to the Mobil 1 15w50 syn but it was certainly not a worrying amount.
  3. RussF
    RussF Karting
    Nov 1, 2003
    222
    Washington
    I switched to Mobil 1 15-50 from dino oil. Interestingly with dino oil it leaked a little oil. Now with Mobil 1 it does not leak a drop. This is contrary to what I expected.
  4. f355spider
    f355spider F1 World Champ
    17,939
    No problem.
  5. MARQ
    MARQ Formula 3
    Feb 9, 2002
    1,924
    East Coast US
    Marq
    Agreed.....definitely not a problem.
  6. parkerfe
    parkerfe F1 World Champ
    Sep 4, 2001
    12,887
    Cumming, Georgia
    Franklin E. Parker
    The 328 came from the factory with synthetic oil, specifically Agip SINT2000. In fact, Agip SINT2000 should be specified in the OM as well as on a plate inside the engine compartment. You should note that "sint" is Italian for synthetic.
  7. dhs-9
    dhs-9 Formula Junior
    Feb 6, 2004
    292
    Factory oil is Agip 10W-40 SInt 2000 which is a semi sythetic it is bleneded with mineral based oil
  8. parkerfe
    Sep 4, 2001
    12,887
    Cumming, Georgia
    Franklin E. Parker
    dhs9, how do you know Agip's SINT2000 is semi rather than full synthetic? I have several bottles of Agip SINT2000 10w40 and no where on the bottle does is indicate it is less than full synthetic.
  9. AEHaas
    AEHaas Formula 3
    May 9, 2003
    1,461
    Osprey, Florida
    Ali E. Haas
  10. Dla
    Dla Karting
    104
    Jacksonville FL
    Lee Anderson
  11. Verell
    Verell F1 Veteran
    May 5, 2001
    7,017
    Groton, MA
    Verell Boaen
    Please do your homework.
    Search the Fchat & the 'Old FerrariChat Archives' for OIL in the subject. There are a dozen or so threads, each with 50 to 100 posts. Some of them by petrochem engineers.
    I think you'll find more detail than you ever wanted to know about oil & 3x8s.
