328 recalls | FerrariChat
328 recalls
Discussion in 'Technical Q&A' started by zebra308, Feb 4, 2004.
  1. zebra308
    zebra308 Formula 3
    Jan 14, 2004
    1,336
    All Flimmits
    Ruffis Leekin
    I recently aquired a 1986 328 GTS. What would be the best way to find out if the recalls have been performed. It had 3 previous owners and the maintenance records are not complete from day one.
    Thanks!
  2. Verell
    Verell F1 Veteran
    May 5, 2001
    7,017
    Groton, MA
    Verell Boaen
    Assuming it's a US Spec version, start by contacting your local Ferrari dealer. Ferrari of North America.They have a central database of service records.
    If it's an Euro model, then rotsaruck unless you can track down the POs & get them to tell you where it was serviced, & then tell the shop it's ok to give you a copy of the service records.
  3. f355spider
    f355spider F1 World Champ
    17,889
  4. zebra308
    zebra308 Formula 3
    Jan 14, 2004
    1,336
    All Flimmits
    Ruffis Leekin
  5. Ferrari_tech
    Ferrari_tech Formula 3
    Jul 28, 2003
    1,527
    Malcolm W
    If it is a Euro car let me have the chassis number and I will check for you
    MW
  6. wimeldo
    wimeldo Formula 3
    Jul 24, 2003
    1,297
    (Spain)
    Alfredo
    Hello, day ago, I bought in Ferrari UK the pieces #147829, thought that they are as the piece "A" and I have sent piece "B", your you think that it will serve?
    It is for a GTS Turbo of year 1987
    Nº27 ref. #147829 EXHAUST GASKET RING...
    plane:
  7. wimeldo
    wimeldo Formula 3
    Jul 24, 2003
    1,297
    (Spain)
    Alfredo
    "A" and "B"
  8. KurtK328
    KurtK328 Formula Junior
    Mar 6, 2001
    347
    Villeneuve-Loubet, France
    Kurt Kjelgaard
    Hmmm, what happened to the original post?
  9. wimeldo
    wimeldo Formula 3
    Jul 24, 2003
    1,297
    (Spain)
    Alfredo
    Also ;)
    The piece also will have to be changed in the 328. It is the same piece. All usually have problems with exhaust system.
    Regards
  10. f355spider
    17,889
    Wimeldo,
    I am not fully understanding your post (language difficulties) but I think you are inquiring if part B is an acceptable substitute for part A? If so, I think NOT. You need part A the proper exhaust gasket to seal properly. Part B is too thin, and will not take up the gap or space presented after the (old) part A is removed.
  11. wimeldo
    wimeldo Formula 3
    Jul 24, 2003
    1,297
    (Spain)
    Alfredo
    @davehanda
    Thank you very much,
    request excuses by my bad writing. Not to be written in English.
    You think correctly, that is the question.
    I believe that you are right, the piece is very thin; but why then, Ferrari UK has sent piece "B" with the correct reference.
    Regards
    Alfredo.
