328 solenoid click but starter not turning -- starter or solenoid? | Page 2 | FerrariChat
Discussion in '308/328' started by s219, Nov 2, 2024.
  1. Lawrence Coppari
    Lawrence Coppari Formula 3
    Apr 29, 2002
    2,194
    Kingsport, TN
    Lawrence A. Coppari
    Looking at your second picture, the male prong, the gap seems less than other prongs meaning the fit is not as tight. My 328 has exhibited this issue in the past. After spraying the connection with contact cleaner, I spread the prong a wee bit, then coated the connection with Stabilant 22. Problem vanished but could return in the future, I suppose.
  2. s219
    s219 Formula Junior
    Aug 26, 2021
    521
    I ordered a de-pin kit that seems like it has the correct keys to pop the pins out of the connectors, so I will give that a try before totally replacing/bypassing the connectors. At the very least it will let me take a closer look at the condition of the pins and their fit. These pins have two small barbs around the periphery that spring into place after the pin is pushed into the connector. A round "tube" style key should be able to slide over the pin and release the barbs if the fit is good.
  3. s219
    s219 Formula Junior
    Aug 26, 2021
    521
    I was only able to remove a few pins from each side of the connector, but enough to try a couple pairs to get an idea how well they were making contact. It was minimal contact, almost no friction when pushing the pins together and pulling them apart. I ended up spreading all the male pins as Lawrence suggested above, and also used Stabilant 22. We'll see how it goes. If I have any other problems with this connector in the future, I will replace it, either with individual blade connectors for each wire, or a new 15-pin connector. That will be an awkward job due to lack of slack on the engine-side harness and tight space in the wheel well to work, but should be doable (would be much easier if the engine is out). Another option is to just use butt-splices and eliminate the connector altogether, although the next guy who has to remove the engine will probably curse upon discovering that.
    For reference, if anyone wants to replace the 15-pin connector, this is the modern equivalent from Molex, available on Amazon for $12:
    https://amzn.to/4mTULPG
    A suitable crimp tool is required to work on those pins (it curls and crimps the wings on the connector to pinch the wire and insulation).
    I am not a fan of Ferrari's use of this connector or its location -- it's really awkward and asking for trouble in multiple ways. Looking back in mechanics' notes from the 1st and 2nd owners of my car (I am #3) I saw other mentions of trouble with that connector. Somewhere along the way, someone modified the bracket that holds the connector to the oil cooler duct. Upon assessing everything today, I removed the bracket altogether and replaced it with a couple cable clamps.
    Tomorrow, I will take a look at the final connection at the starter solenoid and make sure that is OK. I bought a new solenoid ($35 on eBay) just in case that ends up being suspect. If I still encounter issues after all this, the solenoid is probably the last thing to suspect.
  4. s219
    s219 Formula Junior
    Aug 26, 2021
    521
    #29 s219, Oct 9, 2025
    Well I am not sure I have learned anything after checking, cleaning, and prodding all the relevant connectors. This morning I cleaned all the connections going to the solenoid, as well as the main +12V disconnect under the car. The solenoid connections were definitely grimy but cleaned up well. While the car was still on Quickjacks, I turned the key and the engine started beautifully, so I buttoned everything up and dropped the car to the ground. Grabbed my hat to go out for a drive, but on the next attempt, no start!!
    Next, I did some testing of the solenoid itself.
    Across the internal coil, it measured 1.3 ohms resistance. The new spare solenoid I bought measures 1.2 ohms, so I don't think there is an internal issue with the coil on the old solenoid.
    I measured voltage at the white wire feeding the solenoid #50 input. With the wire disconnected, I measure 12.5V, which is only about 0.2V lower than the key switch voltage. So that suggests the wiring and connectors from the key switch all the way to the solenoid are OK.
    With the wire connected and the starter cranking (when it works!) to create load, I measure 10.2V at the solenoid #50 input. That's only 0.3V less than measured at the key switch. Again, that's a good sign I think, suggesting the wiring and connectors from the key switch all the way to the solenoid are OK even under load.
    Now here's the odd one. I put a second multimeter across the solenoid input and output studs -- the two that get connected when the solenoid actuates, bridging the input +12V to the starter -- with the intention of measuring resistance to see if maybe the internal contacts were shot. To do this test, I disconnected both the input +12V line and the output line to the starter. The only wire connected to the solenoid was to the #50 input which I was monitoring with a voltmeter. When I turned the key to start, I heard the solenoid click and I measured 44 ohms across the studs, which to me suggests a very poor connection. Simultaneously, the voltmeter measuring voltage on the #50 pin read 8.8V. I repeated this test a couple times and got consistent results.
    I can't for the life of me figure out why the input #50 voltage would drop to 8.8V when only the solenoid was actuated and drawing power, when earlier I saw 10.2V with both the solenoid actuated *and* the starter turning. Does this make sense to anyone? Is this a clue? Am I an idiot? Seems odd to me.
    I did remove the solenoid (38 year old red loctite on the screws made it a real bear). On the bench I can manually press the plunger and get a zero ohm connection between the input and output studs, but that doesn't necessarily prove anything. I would like to swap in my new spare solenoid eventually but first I need to understand that 8.8V measurement since it could mean something important. Be glad to hear any advice! Thanks!
  5. moysiuan
    moysiuan F1 Rookie
    4,334
    Canada
    #30 moysiuan, Oct 10, 2025
    Image Unavailable, Please Login On these old starters, the copper field wires can degrade. Rebuilders will not generally deal with this, in that it is hard to measure/test when intermittent, they can look and test ok for shorts and resistence when cold but under heat and load can still be a probelm. So it sounds like it is time for a new starter. New Bosch units are available, I bought/imported from a truck supplier for a reasonable price. The new units are made in Hungary. Picture of the Bosch part details attached.
    I am assuming you have a new battery. Problems with a marginal feild coil would be exacerbated by a battery at other than peak charge.
  6. s219
    s219 Formula Junior
    Aug 26, 2021
    521
    @moysiuan I think the battery (2018) is OK mainly because it only drops into the 10.5V range under load when the starter does crank, and I think that is well within spec. A weak battery would probably draw down below 9V under load based on experience with other cars and boats.
    I may pull the old starter and give it a good inspection and bench test. I didn’t have any luck finding new equivalent Bosch replacements, even the part # you show is scarce and I bet tariffs would kill me if importing from Europe. The US Bosch part (SR488X) is also out of stock everywhere. So I may end up rebuilding it if I can track down the parts, or switch to a modern starter from IMI. If you have any sources for the Bosch unit, let me know. Thanks.
  7. Ehamilton
    Ehamilton F1 Rookie
    2,827
    Durham, NC; USA
    Eric Hamilton
    Many solenoids have two coils, one for high-current pull-in and one for lower-current holding. I don’t know offhand whether yours is this type, but what you describe is consistent with the holding coil not engaging, as is the unpleasantly high resistance across the two posts. If you are going to be pulling the starter anyways you might want to open up the solenoid and clean the contactor that connects the two posts.
  8. moysiuan
    moysiuan F1 Rookie
    4,334
    Canada
    https://as-pl.com/en/p/S01025(SEG)
    This might be helpful, 2 in stock in the UK (more in other Europe countries). I am in Canada, and I find my ship costs from the UK to be better than from the US in many cases. Might be worth getting them to confirm a shipped price.
    Your 7 year old battery, even though measuring out well, owes you nothing. I would consider a new battery before dealing with a new starter, albeit your starter may be due for a rebuild/replacement anyways.
  9. s219
    s219 Formula Junior
    Aug 26, 2021
    521
    Thanks, that is great info. When I ran that test, I did it with the main +12V battery input disconnected from the solenoid, so that would have prevented the pull-in coil from disengaging (it requires the main contacts to close so there is no difference in potential across the pull-in coil). I may have inadvertently created an aggravating condition that points to the solenoid being the problem.
    I took the starter out of the car today, and plan to do some bench testing tomorrow. I'll see if I can create a test for each coil to learn more. I did briefly operate the starter/solenoid hooked up to a battery pack as if it was in the car, with a switch to simulate the key trigger. The solenoid closed the circuit, threw the gear, and spun up the starter, so the nominal setup appears to be working. Hopefully I can isolate things tomorrow and maybe trace the problem more directly.
  10. s219
    s219 Formula Junior
    Aug 26, 2021
    521
    Great, thanks, so I see that SEG bought out the Bosch starter business, which might make it easier to lookup the parts now.
  11. s219
    s219 Formula Junior
    Aug 26, 2021
    521
    I did a bunch of bench testing of the starter and solenoid today, both with old and new solenoid. Never saw any type of failure.
    The only oddity I spotted with the old solenoid occurred when testing the pull-in and holding coils (without hooking up the starter motor). I rigged up a couple switches so I could energize both coils to throw the gear forward and then de-energize the pull-in coil to verify that the holding coil was able to maintain position. No issues, it worked perfectly every time. But once the solenoid heated up after a dozen or so tests, the resistance of the pull-in coil went to zero (nominally it was 0.3 ohms before when the solenoid was room temperature).
    I think this must be some type of internal short and probably means the pull-in coil is touching ground in more than one spot internally. It did not affect solenoid or starter operation at all that I could tell during testing. However, I imagine this could greatly increase current draw when installed in the car, both because the pull-in coil could stay energized with a path to ground and also there might be additional direct paths to ground for voltage supplied to the #50 input. That would lower current available to the holding coil and starter motor.
    That is hypothesis and not fully backed up by real world experience since the starter and solenoid kept working fine on my bench even after it was not *and* I most often encounter the no-start problem on my car during initial start attempts when the solenoid is cold. So I can't say experience fits theory here. Be curious if anyone else has any thought on this.
    By the way, when I repeated the testing with the new solenoid, the resistance of the pull-in coil increased (from 0.3 ohms to 0.7 ohms) once it got hot. So its behavior was going in the opposite direction.
  12. s219
    s219 Formula Junior
    Aug 26, 2021
    521
    I reinstalled the starter with the new solenoid today and the car started OK 5 times in a row. However that is not nearly enough data to conclude the problem is fixed, since I'd gone months with no issues in the past, and it was sporadically behaving OK while I was trying to troubleshoot in the last couple weeks. So I'll just have to watch this for a few weeks with frequent testing, and let statistics tell me if the problem is cured. To avoid jinxing myself, I don't plan to put away my Quickjacks or tools until I am confident the problem is solved.
    I can't say I ever found a smoking gun, but for sure the old solenoid had some flakey characteristics and appeared to be shorting to ground internally when it got warm during bench testing. I confirmed that the wiring from the key switch to the starter solenoid seems to be OK -- it's got 0.1 ohm resistance from end to end and I never saw any changes when I wiggled the various sections of wire or the connectors. I cleaned and applied De-ox-it to both the main ground wire disconnect (front of car) and main positive disconnect (under car) and tested them to make sure contact was good. So in my mind, if the problem comes back, it's got to be the starter or the key switch. I'd suspect the key switch first, so I wired up a digital voltmeter display semi-permanently to the #50 output on the key switch and that may help me catch the problem in realtime if it happens again. And to double-jinx myself, I ordered a new key switch (BMW part # 61-31-2-682-120) to have on hand just in case. That part seems to have sporadic availability and the price has gone up considerably in recent years, so I figured it was a good investment to get one while I could ($307 from getBMWparts.com).
    I'll post some pics of the new solenoid below. The original Bosch part is NLA, but there are 3-4 companies making equivalents. The most common part number is 66-9126 for cross match. This maps to ZM-573 (what I got, $32 on eBay). Another good way to search is look for VW part # 026 911 287 or lookup the solenoid used on a 1982 VW Scirocco. That pulls up modern equivalents in most auto parts databases.
    One final note, the original screws attaching the solenoid were Phillips head and held in with red Loctite around the head of the screw. The Phillips head on one of my three screws got buggered up when trying to remove the old solenoid, so I replaced all three screws with flat head allen screws (35mm long). I had to turn the heads down a smidge to fit the countersink holes on the starter housing. Alternately, cap head allen screws would work too if a 45 degree bevel can be put on the underside of the cap to mate with the countersink hole. I put a couple dabs of red Loctite under the heads of the new screws before tightening down, like the originals had. I torqued the screws to 55 in-lb.
    moysiuan likes this.
