328 tire valve question | FerrariChat
Discussion in '308/328' started by montreal328, Apr 4, 2010.
  1. montreal328
    montreal328 Formula Junior
    Nov 1, 2009
    428
    Qué
    Eric
    #1 montreal328, Apr 4, 2010
  2. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,534
    Cerritos, CA.
    I would just get a new valve, for the price of it it's worth the peace of mind.
  3. DGS
    DGS Six Time F1 World Champ
    60,493
    MidTN
    DGS
    You'll have to break the bead on the tire to replace the valve -- I expect it has a nut and washer on the inside, too.
  4. montreal328
    Nov 1, 2009
    428
    Qué
    Eric
    Question is more: can I use 14 mm socket to '' unscrew'' valve from rim, and I would replace it with valve from spare tire ( looks the same). The valve as is now, prevents me from filling the tire with air...
  5. montreal328
    Nov 1, 2009
    428
    Qué
    Eric
    #5 montreal328, Apr 4, 2010
  6. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,687
    Mike 996
    In a tubeless tire, the tire valve has to be inserted/removed from the rim after the tire is removed. l don't believe there is anyway to remove a tire valve and install a new one with the tire on the rim unless there are new types of tools/tire valves than I have ever seen.
  7. montreal328
    Nov 1, 2009
    428
    Qué
    Eric
    Thanks Mike, that pretty well seals it...
  8. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
    All you need to do is break the bead on the valve side and unscrew the nut from the top. Then push the valve stem into the rim and remove it. Insert the new or replacement valve stem and pull it through. There is no nut on the inside , it only has a rubber seal. If you do it this way you do not have to rebalance the wheel. The other option is take it to a tire dealer and they will pull the tire , replace the valve stem and reinstall/rebalance the tire.
