News
328 water pump replacement
Discussion in 'Technical Q&A' started by Modena michael, Sep 28, 2005.
  1. Modena michael
    Sep 28, 2005
    3
    Help...4 bolts removed and 3 stud nuts removed. Problem..can not seem to dislodge water pumpcover with assembly from the water pump body. Rubber mallet will not dislodge it. Are 3 studs interfering with removal of pump housing? How can I get the pump out?
  3. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    10,521
    San Carlos, CA
    Mitchell Le
    The 308 and the 328 pumps are about the same, so three studs and four bolts are it. What's holding you up is the corrosion from the coolant keeping the water pump glued to the studs and not dislodging itself.
    Pound a little harder, soak it in some rust-free spray, or use heat.
  4. Modena michael
    Sep 28, 2005
    3
    Thanks, now that you mention it, I can see the corrosion around the stud
