328gts 1988 ignition switch | FerrariChat
Discussion in '308/328' started by Theruse, Mar 11, 2025.
  1. Theruse
    Theruse Karting
    Jan 17, 2014
    171
    Maryland
    Prescott Russo
    My ignition switch needs replacement. Looking through past threads, BMW part 61 31 2 682 120 from a 2002 model was identified as a a replacement. Has anyone had experience with using this part as it is available while the Ferrari part appears to be unobtanium?
  2. Dave Bertrand
    Dave Bertrand Formula Junior
    823
    Castle Rock, CO
    I don't know about the BMW switch, but I can attest that a switch from a 400/412 works great, as I have one of those in my 89. Possibly also one from a Testarossa or Mondial.
  3. Sigmacars
    Sigmacars Formula 3
    1,187
    I think MG also uses that switch you have to do a little research
  4. Sergio Tavares
    Sergio Tavares Formula 3
    Nov 15, 2018
    1,212
    Sergio Tavares
    Is the failure in the mechanical part or the electrical part or is all mising?
    The electrical part can get damged by wrong liguids lubricants as they flow the spine shaft downed
  5. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,825
    Mike 996
    FWIW, I disassembled/cleaned the Ign switch in my '89 328 8-9 years ago to sort out an intermittent connection problem and it's been fine ever since. So that might be an option if it's an electrical problem/depending on what's wrong.
  6. Theruse
    Theruse Karting
    Jan 17, 2014
    171
    Maryland
    Prescott Russo
    I now think it is a mechanical problem. Initially, if I fiddled the white wires behind the switch the car would start. That no longer being the case, when I now turn the switch to the three position I don't feel the spring action and it won't start. So yes, I now think its mechanical. The long bolt that locks the steering wheel may put too much pressure on the mechanical side of the switch. Once its disassembled and we can fix the lockset if that is the issue I will also replace the electrical part with the BMW component.
    Sergio Tavares likes this.
  7. Theruse
    Theruse Karting
    Jan 17, 2014
    171
    Maryland
    Prescott Russo
    Dave,
    I also have a 400 and I know that switch is identical to the 2002 switch. What first tipped me off was that the 400 key is identical to the key I had on my 2002 many years back.
  8. Dave Bertrand
    823
    Castle Rock, CO
    I'm guessing it looks like mine
  9. Theruse
    Theruse Karting
    Jan 17, 2014
    171
    Maryland
    Prescott Russo
    That's it!
  10. Sergio Tavares
    Nov 15, 2018
    1,212
    Sergio Tavares
    Perhaps the back spring jump out of the retaineing hole?
    You need to remove the lock and look perhaps before buying the new part - many questions here will be solved
  11. Theruse
    Theruse Karting
    Jan 17, 2014
    171
    Maryland
    Prescott Russo
    It turned out to be the bolt for the steering lock that was preventing the ignition switch to the start position. The steering column was removed and the locking bolt was cleaned and lubricated. The spring was replaced and the electrical part of the ignition switch (NOS Bosch FER70000707). The picture shows the complete ignition/locking mechanism. The black part is the ignition switch and the shaft is where the locking bolt travels.
  12. Sergio Tavares
    Nov 15, 2018
    1,212
    Sergio Tavares
    that electrical part has gotten expensive
  13. Sergio Tavares
    Nov 15, 2018
    1,212
    Sergio Tavares
    Is NOS Bosch FER70000707 really over $700,00 USD or was it the Chinese reprod with no Bosch markings?
  14. Theruse
    Theruse Karting
    Jan 17, 2014
    171
    Maryland
    Prescott Russo
    It's an original Bosch part NOS for $331
  15. Sergio Tavares
    Nov 15, 2018
    1,212
    Sergio Tavares
    Very great price!
    All other are 600 Euro or higher
    Just for sure see BOSCH on black backside portion or for sure is Chinese one. Terrible mechanic to charge the $35 Chinese for $331 to customer
  16. Theruse
    Theruse Karting
    Jan 17, 2014
    171
    Maryland
    Prescott Russo
    I have the Bosch box as well. I know its from an NOS inventory from my Independent Ferrari shop. If you see it on Ebay for $700, it doesn't mean it sold for $700.
