328GTs Door alignment | FerrariChat
Discussion in 'Technical Q&A' started by zapper/dapper, Feb 27, 2004.
  1. zapper/dapper
    zapper/dapper Rookie
    Feb 26, 2004
    47
    I have a 328 GTS and the driver's door is out of alignment and not able to
    lock door from outside. Inside. no problem, and once it is locked it will unlock, but the key doesn't seem to go far enough to lock the buttom down.
    Need advice on fixing.. as well as opeing up door panel to check the rods for the dorr.
    Thanx
  2. f355spider
    f355spider F1 World Champ
    17,860
    Your message is a bit confusing; is the door out of alignment, or is the lock a problem (key doesn't go in all the way) or both?
    Removing the door panel is very simple, just remove the lock pull on top (unscrew it), the trim screws around the perimeter, and the screws holding on the armrest assembly. You will also need to unplug the window switches as the panel comes off.
  3. carlrose
    carlrose Formula Junior
    Nov 25, 2003
    318
    Hi Z,
    Check the parts & service section. I posted a bit there about door panel removal.
    :) Carl
