328GTS stuck clutch | FerrariChat
328GTS stuck clutch
Discussion in 'Technical Q&A' started by SCHNELL, Nov 24, 2013.
  1. SCHNELL
    SCHNELL Rookie
    Apr 25, 2011
    9
    PA
    My disc is stuck to flywheel and/or pressure plate from sitting. Last time I was able 'pop' the clutch a few times to break it loose, no luck this time - any suggestions?
  2. brian.s
    brian.s F1 Rookie
    Nov 3, 2003
    3,809
    Midwest
    Brian
    Again? Next time put a broom handle on the pedal and keep the clutch depressed!
    Kidding, just keep trying, I've had to drive them around the block with the pedal pushed before now. Also, start with the pedal down, that starter can torque it free too.
  3. itiejim
    itiejim Karting
    Dec 9, 2008
    84
    James Ashton
    I've unlocked one on a Triumph TR6 engine before by starting the car with the wheels jacked off the floor. Get in and then get a friend to open drop the jack quickly. You need some space and I'm not sure I'd want to be so brutal with a Ferrari transmission though - but it's an option!
